跳转到主内容
SSD M.2 Drive Replacement
你所需要的
  1. SSD M.2 Drive Replacement, Unplug all cables: 步骤 1 中的图像 1,2 SSD M.2 Drive Replacement, Unplug all cables: 步骤 1 中的图像 2,2
    • Turn off your computer if it is on.
    • Unplug all cables at the back and the front of your computer.
    • Make sure to turn off the power supply by putting the switch at the "O" position.
  2. SSD M.2 Drive Replacement, Remove the side panel: 步骤 2 中的图像 1,3 SSD M.2 Drive Replacement, Remove the side panel: 步骤 2 中的图像 2,3 SSD M.2 Drive Replacement, Remove the side panel: 步骤 2 中的图像 3,3
    • Remove the side panel to gain access to the inside of your computer. To access the side panel, (except as described below) you need to remove the screws on the rear of the case, then slide the case to remove it.
    • In my case, with a DarkWitcher case from Empire Gaming, I need to unscrew 4 screws to lift and remove the side panel.
    • Locate the M.2 slot on your motherboard. If you don't see it, it may be hidden under the graphics card, you can check in the motherboard's manuel to find where it is.
  3. SSD M.2 Drive Replacement, Unplug the GPU power cable: 步骤 4 中的图像 1,3 SSD M.2 Drive Replacement, Unplug the GPU power cable: 步骤 4 中的图像 2,3 SSD M.2 Drive Replacement, Unplug the GPU power cable: 步骤 4 中的图像 3,3
    • If the M.2 slot is accessible without having to remove the graphics card, you can proceed immediately to step 6.
    • Otherwise, unplug the power cable from the graphics card by levering the clip on the connector and remove it.
  4. SSD M.2 Drive Replacement, Remove the GPU: 步骤 5 中的图像 1,3 SSD M.2 Drive Replacement, Remove the GPU: 步骤 5 中的图像 2,3 SSD M.2 Drive Replacement, Remove the GPU: 步骤 5 中的图像 3,3
    • Remove the screws holding the graphics card in place.
    • Push on the clip at the right of the GPU slot.
    • Remove the graphics card by gently lifting it out. You can use a plastic spatula to do this.
  5. SSD M.2 Drive Replacement, Remove the heat sink: 步骤 6 中的图像 1,3 SSD M.2 Drive Replacement, Remove the heat sink: 步骤 6 中的图像 2,3 SSD M.2 Drive Replacement, Remove the heat sink: 步骤 6 中的图像 3,3
    • If your motherboard has no heat sink on you SSD, you can go the next step.
    • If not, remove the screw holding the heatsink in place.
    • Then remove the heat sink by lifting it up.
    • The thermal pad glued to the heatsink may stick slightly to the SSD, so don't be afraid to lift it.
    • Place the heat sink on the opposite side to the one to which the thermal pad is glued.
  6. SSD M.2 Drive Replacement, Remove the SSD Drive: 步骤 7 中的图像 1,3 SSD M.2 Drive Replacement, Remove the SSD Drive: 步骤 7 中的图像 2,3 SSD M.2 Drive Replacement, Remove the SSD Drive: 步骤 7 中的图像 3,3
    • Remove the screw securing the disk in place.
    • Once the screw has been removed, the drive will lift itself.
    • Pull the drive to the left to take it out of the slot.
  7. SSD M.2 Drive Replacement, Insert the new drive: 步骤 8 中的图像 1,2 SSD M.2 Drive Replacement, Insert the new drive: 步骤 8 中的图像 2,2
    • Align the notch on the slot with the notch on the drive.
    • Insert the new drive in the slot.
  8. SSD M.2 Drive Replacement, Screw the screw: 步骤 9 中的图像 1,2 SSD M.2 Drive Replacement, Screw the screw: 步骤 9 中的图像 2,2
    • Press slightly on the disc to engage. Align the semi-circle at the end of the disc with the hole in the screw.
    • Screw the screw.
结论
To reassemble you device, follow the instructions in reverse order beginning by the sixth step.
6等其他人完成本指南。
由衷感谢以下译者:
fr en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Gaëtan Suss
于12/01/22注册
2,211 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 17
过去 7 天: 137
过去 30 天: 593
总计 17,029
