跳转到主内容
加入维修社区 - 创建账户
Rug Doctor Spray Button Replacement
你所需要的
  1. Rug Doctor Spray Button Replacement, Handle: 步骤 1 中的图像 1,1
    • Before you begin disassembly, make sure that the Rug Doctor is not plugged in and that all reservoirs are empty of liquids.
    • Unclip the clear hose from the back of the Rug Doctor.
    添加评论
  2. Rug Doctor Spray Button Replacement: 步骤 2 中的图像 1,2 Rug Doctor Spray Button Replacement: 步骤 2 中的图像 2,2
    • Use a 7/16" (11 mm OK) wrench to hold the handle axle while you use a 7/16" socket to remove the cap nut securing the axle end.
    询问修复机器人
    添加评论
  3. Rug Doctor Spray Button Replacement: 步骤 3 中的图像 1,2 Rug Doctor Spray Button Replacement: 步骤 3 中的图像 2,2
    • Support the handle with one hand. It will be loose after this step.
    • Use fingers or pliers to pull out the handle axle.
    • If the axle feels hard to pull out, squeeze the handle release lever to release pressure on the axle.
    询问修复机器人
    添加评论
  4. Rug Doctor Spray Button Replacement: 步骤 4 中的图像 1,1
    • Detach the handle from the Rug Doctor and set it down.
    • If you need more cable slack, you can set the Rug Doctor on its side.
    询问修复机器人
    添加评论
  5. Rug Doctor Spray Button Replacement, Spray Button: 步骤 5 中的图像 1,2 Rug Doctor Spray Button Replacement, Spray Button: 步骤 5 中的图像 2,2
    • Uncoil the power cable from the handle.
    • Remove the sixteen Phillips fasteners of the following lengths:
    • Six 22.7 mm machine screws
    • Four 35.3 mm machine screws
    • Two 25.2 mm (thicker) machine screws
    • Two 48.4 mm bolts with washers
    • When reinstalling these, the order should be: bolt, washer, handle, washer, 3/8" nut.
    • Two 30.1 mm screws
    询问修复机器人
    添加评论
  6. Rug Doctor Spray Button Replacement: 步骤 6 中的图像 1,2 Rug Doctor Spray Button Replacement: 步骤 6 中的图像 2,2
    • Separate the bottom edge of the handle slightly until the spring-loaded plunger pops out of its socket.
    询问修复机器人
    添加评论
  7. Rug Doctor Spray Button Replacement: 步骤 7 中的图像 1,3 Rug Doctor Spray Button Replacement: 步骤 7 中的图像 2,3 Rug Doctor Spray Button Replacement: 步骤 7 中的图像 3,3
    • Re-assembly tip—Follow this step to re-seat the plunger.
    • Use your fingers to push the black plunger down towards the bottom of the handle into position. This may take significant force.
    • Once the plunger slips into position, squeeze the the two handle halves together.
    • If done correctly, the handle should close tightly without a gap and lock the plunger in place.
    • If that doesn't happen, check to see if the plunger is properly positioned, and that no wires are pinched.
    • Continue squeezing the two handle halves together while you reinstall the handle's lower screws.
    询问修复机器人
    添加评论
  8. Rug Doctor Spray Button Replacement: 步骤 8 中的图像 1,2 Rug Doctor Spray Button Replacement: 步骤 8 中的图像 2,2
    • Remove the two 11.4 mm long Phillips screws holding the cover plate on the handle.
    • Remove the cover plate.
    询问修复机器人
    添加评论
  9. Rug Doctor Spray Button Replacement: 步骤 9 中的图像 1,3 Rug Doctor Spray Button Replacement: 步骤 9 中的图像 2,3 Rug Doctor Spray Button Replacement: 步骤 9 中的图像 3,3
    • Use a pair of pliers to grasp the lip of the screw post close to the handle release lever.
    • While gripping the screw post, use a large flathead screwdriver to remove the machine screw mated to the other end of the screw post.
    添加评论
  10. Rug Doctor Spray Button Replacement: 步骤 10 中的图像 1,2 Rug Doctor Spray Button Replacement: 步骤 10 中的图像 2,2
    • Pull the two handle halves apart.
    询问修复机器人
    添加评论
  11. Rug Doctor Spray Button Replacement: 步骤 11 中的图像 1,2 Rug Doctor Spray Button Replacement: 步骤 11 中的图像 2,2
    • Re-assembly tip—Before you close the handle, check the following:
    • The lever mechanism components are properly stacked and oriented as shown.
    • Both brass bushings are in their sockets.
    询问修复机器人
    添加评论
  12. Rug Doctor Spray Button Replacement: 步骤 12 中的图像 1,3 Rug Doctor Spray Button Replacement: 步骤 12 中的图像 2,3 Rug Doctor Spray Button Replacement: 步骤 12 中的图像 3,3
    • Note how the switch is wired:
    • Red and black wires on the top sockets (order does not matter)
    • Two white wires on the bottom sockets
    • Use fingers or pliers to wiggle and pull the four connectors from the switch module.
    询问修复机器人
    添加评论
  13. Rug Doctor Spray Button Replacement: 步骤 13 中的图像 1,3 Rug Doctor Spray Button Replacement: 步骤 13 中的图像 2,3 Rug Doctor Spray Button Replacement: 步骤 13 中的图像 3,3
    • Use fingers or wide pliers to squeeze the black retainer tabs on each side of the button module.
    • While squeezing, wiggle and push the button module out of the front of the handle.
    • Remove the button module.
    • To install a replacement button, push the button in through the top of the handle until it clicks in place. It should not be loose or easily budged.
    添加评论
结论
To reassemble your device, follow these instructions in reverse order while noting the re-assembly tips.
取消:我没有完成这个指南。
11等其他人完成本指南。
Arthur Shi
于01/03/18注册
343,844 声望
创作了915篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了30,166篇指南
3指南评论
Remove the power cables strain relief at the handle for slack, not the 16 screws to split the handle. That takes all day and one time you will lose a screw or 2 or 4.
NICHOLAS - 回复 分享
could not use pliers, label was as thick as face on head, will end up replacing whole handle assembly, bad choice for fastener
JOSEPH - 回复 分享
cut a notch in the fastener with a dremel to get out the handle bolt
JEREMY - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 32
过去 30 天: 140
总计 8,113
