跳转到主内容
加入维修社区 - 创建账户
Retina MacBook 2017 Display Assembly Replacement
你所需要的
    1. Retina MacBook 2017 Display Assembly Replacement, Disable Auto Boot: 步骤 1 中的图像 1,3 Retina MacBook 2017 Display Assembly Replacement, Disable Auto Boot: 步骤 1 中的图像 2,3 Retina MacBook 2017 Display Assembly Replacement, Disable Auto Boot: 步骤 1 中的图像 3,3
      • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
      • Power on your Mac and launch Terminal.
      • Copy and paste the following command (or type it exactly) into Terminal:
      • sudo nvram AutoBoot=%00
      • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
      • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
      • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
      • sudo nvram AutoBoot=%03
      添加评论
    1. Retina MacBook 2017 Display Assembly Replacement, Unfasten the lower case: 步骤 2 中的图像 1,1
      在这个步骤中使用的工具:
      Magnetic Project Mat
      $19.95
      • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
      • Remove the following eight screws securing the lower case:
      • Two 1.8 mm P5 Pentalobe screws
      • Four 2.9 mm P5 Pentalobe screws
      • Two 6.1 mm P5 Pentalobe screws
      • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      添加评论
    2. Retina MacBook 2017 Display Assembly Replacement: 步骤 3 中的图像 1,3 Retina MacBook 2017 Display Assembly Replacement: 步骤 3 中的图像 2,3 Retina MacBook 2017 Display Assembly Replacement: 步骤 3 中的图像 3,3
      • Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges.
      • Lift the lower case only slightly to avoid damaging the cables that connect the lower case to the upper case.
      • Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
      • You may experience a lot of resistance when lifting the lower case. If necessary, slide an opening pick or other ESD-safe pry tool down the side edges of the lower case to pop the two hidden retaining clips free.
      • During reassembly, to re-engage the clips, press firmly near both side edges of the lower case (near where the pick is inserted in the third image) until you hear the clips snap into place.
      询问修复机器人
      添加评论
    3. Retina MacBook 2017 Display Assembly Replacement: 步骤 4 中的图像 1,1
      • While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
      询问修复机器人
      添加评论
    4. Retina MacBook 2017 Display Assembly Replacement: 步骤 5 中的图像 1,2 Retina MacBook 2017 Display Assembly Replacement: 步骤 5 中的图像 2,2
      • Lift the upper case and display together from the front edge and raise it to about a 45˚ angle.
      • It may be helpful to prop the MacBook open in this position for the next step.
      添加评论
    5. Retina MacBook 2017 Display Assembly Replacement: 步骤 6 中的图像 1,3 Retina MacBook 2017 Display Assembly Replacement: 步骤 6 中的图像 2,3 Retina MacBook 2017 Display Assembly Replacement: 步骤 6 中的图像 3,3
      • Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
      • If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
      • If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
      • This step ensures the MacBook is fully powered down and safe to work on.
      添加评论
    6. Retina MacBook 2017 Display Assembly Replacement: 步骤 7 中的图像 1,1
      • Close the MacBook and carefully flip it upside-down.
      询问修复机器人
      添加评论
    7. Retina MacBook 2017 Display Assembly Replacement: 步骤 8 中的图像 1,1
      • Lifting from the front edge, open the lower case to an angle of about 45°.
      • Take care not to damage the ribbon cables that still attach the lower case to the MacBook.
      询问修复机器人
      添加评论
    8. Retina MacBook 2017 Display Assembly Replacement: 步骤 9 中的图像 1,2 Retina MacBook 2017 Display Assembly Replacement: 步骤 9 中的图像 2,2
      在这个步骤中使用的工具:
      • Use tweezers to peel back the tape covering the trackpad cable ZIF connector.
      添加评论
    9. Retina MacBook 2017 Display Assembly Replacement: 步骤 10 中的图像 1,3 Retina MacBook 2017 Display Assembly Replacement: 步骤 10 中的图像 2,3 Retina MacBook 2017 Display Assembly Replacement: 步骤 10 中的图像 3,3
      • Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
      添加评论
    10. Retina MacBook 2017 Display Assembly Replacement: 步骤 11 中的图像 1,2 Retina MacBook 2017 Display Assembly Replacement: 步骤 11 中的图像 2,2
      • Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
      询问修复机器人
      添加评论
    11. Retina MacBook 2017 Display Assembly Replacement: 步骤 12 中的图像 1,3 Retina MacBook 2017 Display Assembly Replacement: 步骤 12 中的图像 2,3 Retina MacBook 2017 Display Assembly Replacement: 步骤 12 中的图像 3,3
      • Carefully close the MacBook and flip it over once again, so that the Apple logo faces up.
      • Lifting from the front edge, raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
      • Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
      • It's possible to open the MacBook all the way and lay both sides down flat, but this may damage the flex cables and is not recommended.
      询问修复机器人
      添加评论
    12. Retina MacBook 2017 Display Assembly Replacement: 步骤 13 中的图像 1,1
      • Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
      添加评论
    13. Retina MacBook 2017 Display Assembly Replacement: 步骤 14 中的图像 1,2 Retina MacBook 2017 Display Assembly Replacement: 步骤 14 中的图像 2,2
      在这个步骤中使用的工具:
      Battery Blocker
      $5.95
      • As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
      添加评论
    1. Retina MacBook 2017 Display Assembly Replacement, USB-C and Audio Jack Disconnect: 步骤 15 中的图像 1,1
      • Remove the two screws securing the USB-C port cable bracket:
      • 1.1 mm Phillips #00 screw
      • Some variations of this model may use a Tri-point Y00 screw.
      • 3.5 mm T5 Torx screw
      添加评论
    2. Retina MacBook 2017 Display Assembly Replacement: 步骤 16 中的图像 1,2 Retina MacBook 2017 Display Assembly Replacement: 步骤 16 中的图像 2,2
      • Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board.
      • To reconnect this cable, first line up the metal bracket over the screw holes, then press down on the middle of the bracket. Make sure it's aligned correctly, or you may damage the connector.
      添加评论
    3. Retina MacBook 2017 Display Assembly Replacement: 步骤 17 中的图像 1,2 Retina MacBook 2017 Display Assembly Replacement: 步骤 17 中的图像 2,2
      • Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector.
      询问修复机器人
      添加评论
    4. Retina MacBook 2017 Display Assembly Replacement: 步骤 18 中的图像 1,2 Retina MacBook 2017 Display Assembly Replacement: 步骤 18 中的图像 2,2
      • Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
      • During reassembly, orient the ribbon cable so the white stripe faces you. Insert the cable until the white line disappears under the socket.
      • At this point it is possible to open the macbook all the way and to lay it flat on a table without causing any damage to the flex cables.
      添加评论
    1. Retina MacBook 2017 Display Assembly Replacement, Lower Case Assembly Removal: 步骤 19 中的图像 1,2 Retina MacBook 2017 Display Assembly Replacement, Lower Case Assembly Removal: 步骤 19 中的图像 2,2
      在这个步骤中使用的工具:
      • Use tweezers to peel back the tape covering the display cable connector.
      添加评论
    2. Retina MacBook 2017 Display Assembly Replacement: 步骤 20 中的图像 1,2 Retina MacBook 2017 Display Assembly Replacement: 步骤 20 中的图像 2,2
      • It's possible the metal retaining flap on the display cable connector may flip open, remaining stuck to the tape.
      • If so, use the flat end of a spudger to hold down the retaining flap while peeling the tape away with the tweezers.
      询问修复机器人
      添加评论
    3. Retina MacBook 2017 Display Assembly Replacement: 步骤 21 中的图像 1,1
      • Use the flat end of a spudger to flip open the retaining flap on the display cable connector.
      • Try to keep it clear of the tape, or it may re-adhere and make cable removal difficult.
      添加评论
    4. Retina MacBook 2017 Display Assembly Replacement: 步骤 22 中的图像 1,3 Retina MacBook 2017 Display Assembly Replacement: 步骤 22 中的图像 2,3 Retina MacBook 2017 Display Assembly Replacement: 步骤 22 中的图像 3,3
      在这个步骤中使用的工具:
      iOpener
      $14.95
      • Carefully slide the flat end of a spudger underneath the display cable to separate the adhesive holding it to the lower case.
      • Take care not to damage the cable. If the adhesive is very strong, heat the case directly beneath the cable with an iOpener to soften the adhesive, and then try again.
      添加评论
    5. Retina MacBook 2017 Display Assembly Replacement: 步骤 23 中的图像 1,3 Retina MacBook 2017 Display Assembly Replacement: 步骤 23 中的图像 2,3 Retina MacBook 2017 Display Assembly Replacement: 步骤 23 中的图像 3,3
      • Hold the retaining flap open.
      • Disconnect the display cable by gently pulling it straight out of its connector.
      • Immediately close the retaining flap. Keep it closed throughout your repair.
      • During reassembly, keep the flap closed while you insert the display cable. Remember to orient the cable so its gold contacts face down, making sure not to crimp or fold it—it'll click into place when it's connected.
      添加评论
    6. Retina MacBook 2017 Display Assembly Replacement: 步骤 24 中的图像 1,1
      • Separate the upper case assembly from the lower case assembly.
      询问修复机器人
      添加评论
    1. Retina MacBook 2017 Display Assembly Replacement, Audio Jack Board: 步骤 25 中的图像 1,2 Retina MacBook 2017 Display Assembly Replacement, Audio Jack Board: 步骤 25 中的图像 2,2
      • Use a spudger to flip open the ZIF connector retaining flap for the dual microphone assembly ribbon cable.
      询问修复机器人
      添加评论
    2. Retina MacBook 2017 Display Assembly Replacement: 步骤 26 中的图像 1,2 Retina MacBook 2017 Display Assembly Replacement: 步骤 26 中的图像 2,2
      • Disconnect the microphone assembly ribbon cable by pulling it straight out of its connector.
      添加评论
    3. Retina MacBook 2017 Display Assembly Replacement: 步骤 27 中的图像 1,1
      • Remove the two 3.2 mm T5 Torx screws securing the audio jack board to the case.
      询问修复机器人
      添加评论
    4. Retina MacBook 2017 Display Assembly Replacement: 步骤 28 中的图像 1,1
      • Remove the audio jack board.
      添加评论
    1. Retina MacBook 2017 Display Assembly Replacement, USB-C Port: 步骤 29 中的图像 1,1
      • Remove two 2.5 mm Phillips #00 screws securing the USB-C port.
      添加评论
    2. Retina MacBook 2017 Display Assembly Replacement: 步骤 30 中的图像 1,3 Retina MacBook 2017 Display Assembly Replacement: 步骤 30 中的图像 2,3 Retina MacBook 2017 Display Assembly Replacement: 步骤 30 中的图像 3,3
      在这个步骤中使用的工具:
      • Use tweezers to lift the USB-C port just over the hinge screws.
      • Slide the port out and up over the display hinge to remove it.
      • There's very little clearance when removing and installing the USB-C port. If there's not enough room, don't force it. Try removing the display hinge screws and moving the hinges for additional clearance, if necessary.
      添加评论
    1. Retina MacBook 2017 Display Assembly Replacement, Display Assembly: 步骤 31 中的图像 1,3 Retina MacBook 2017 Display Assembly Replacement, Display Assembly: 步骤 31 中的图像 2,3 Retina MacBook 2017 Display Assembly Replacement, Display Assembly: 步骤 31 中的图像 3,3
      • Remove the two 3.3 mm T5 Torx screws securing the display cable assembly.
      • Take care not to lose the small retaining bracket located under the right screw. If it comes loose, note the orientation shown here for reassembly. The small tab on the outer left edge should be hooked under the perforated metal shield.
      询问修复机器人
      添加评论
    2. Retina MacBook 2017 Display Assembly Replacement: 步骤 32 中的图像 1,1
      • Fully open the display.
      • Set the MacBook down on its right edge with the display facing away from you, as shown.
      添加评论
    3. Retina MacBook 2017 Display Assembly Replacement: 步骤 33 中的图像 1,2 Retina MacBook 2017 Display Assembly Replacement: 步骤 33 中的图像 2,2
      • Remove the four 4.8 mm T8 Torx screws securing the display hinges.
      • There may be a rubber cover on the hinge screws. Remove this before removing the screws and replace it during reassembly.
      添加评论
    4. Retina MacBook 2017 Display Assembly Replacement: 步骤 34 中的图像 1,3 Retina MacBook 2017 Display Assembly Replacement: 步骤 34 中的图像 2,3 Retina MacBook 2017 Display Assembly Replacement: 步骤 34 中的图像 3,3
      • Holding the display assembly with one hand and the upper case with the other, push them together slightly to move the hinges out of their recesses in the the upper case.
      • There are only a few millimeters of play between the hinges and the case, so you won't need to push far.
      • Push the upper case forward while pulling back gently on the display.
      • Once the two display hinges have cleared the upper case, remove the display and set it aside.
      添加评论
结论
取消:我没有完成这个指南。
17等其他人完成本指南。
Tobias Isakeit
于03/31/14注册
134,809 声望
创作了189篇指南
团队
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 的会员
Business
1 名成员
创作了1,480篇指南
4指南评论
Does anyone know the cross year compatibility of these screens. Some vendors list them as 2017 specific, some as 2016-17 and some as 2015-17?
andrew - 回复 分享
I have a 2017 macbook upgraded to i7 etc and i love it, today i fitted an adhesive cover top and bottom but tried to trim excess where I hadn’t done a good fit with a craft knife AND I appear to have sliced into a cable joining top to bottom, it appears to be 1 of 4 around the centre of the mac, been quoted £600 to replace complete top ,is this necessary? , all advice gratefully appreciated.
guerdeval - 回复 分享
This doesn't seem to be the 2017 a1708 model.
Ricardo Varela - 回复 分享
No, it's the 12" MacBook, A1534. The A1708 is the 13" MacBook Pro.
rogerh - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 37
过去 30 天: 173
总计 32,919
