跳转到主内容
Razer Blade RZ09-0102 Battery Replacement
你所需要的
  1. Razer Blade RZ09-0102 Battery Replacement, Rear Panel: 步骤 1 中的图像 1,1
    • Before you begin, be sure to turn off your laptop.
    • Using a Torx T5 screwdriver, remove the ten 1/8 inch screws securing the back cover.
    • Remove the back cover.
  2. Razer Blade RZ09-0102 Battery Replacement, Battery: 步骤 2 中的图像 1,2 Razer Blade RZ09-0102 Battery Replacement, Battery: 步骤 2 中的图像 2,2
    • Remove the seven screws holding the battery in place using a Phillips #0 screwdriver.
  3. Razer Blade RZ09-0102 Battery Replacement: 步骤 3 中的图像 1,1
    • Unlock the ZIF connectors securing the right ribbon cable.
    • To unlock a ZIF connector, use an opening tool or your fingernail to flip up the small, hinged locking flap.
    • Carefully pull the two ribbon cables out of their sockets.
  4. Razer Blade RZ09-0102 Battery Replacement: 步骤 4 中的图像 1,1
    • Use an opening tool to unlock the ZIF connector securing the white ribbon over the battery.
  5. Razer Blade RZ09-0102 Battery Replacement: 步骤 5 中的图像 1,2 Razer Blade RZ09-0102 Battery Replacement: 步骤 5 中的图像 2,2
    • Carefully pull out the two connectors out of their sockets.
    • Pull parallel to the motherboard, not straight up.
  6. Razer Blade RZ09-0102 Battery Replacement: 步骤 6 中的图像 1,2 Razer Blade RZ09-0102 Battery Replacement: 步骤 6 中的图像 2,2
    • Pull the wide battery connector towards the battery to disconnect it from the motherboard.
  7. Razer Blade RZ09-0102 Battery Replacement: 步骤 7 中的图像 1,2 Razer Blade RZ09-0102 Battery Replacement: 步骤 7 中的图像 2,2
    • Remove the battery from the laptop.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
6等其他人完成本指南。
2指南评论
Hey Nicole, thank you for writing this fantastic guide. Do you have any recommendations for vendors or websites for this specific battery replacement?
Erfan Moradi - 回复
My dudes, anyone can tell me what model is the RZ09-0102 battery connector and where to order the motherboard side?
A friends laptop got the connector melted *moisture* and I can’t identify this dense 30-pin oedipus.
Giorgi Kikuashvili - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 51
总计 26,425
