跳转到主内容
RIDGID R84015 X2 Speed Switch Replacement
Evan Long
Evan Long6 其他贡献者
最后更新于 April 29, 2020
没有估计
中等
缺少前提条件
The speed (1-2) Switch is either stuck or won't change speed of rotation.
你所需要的
工具
  1. RIDGID R84015 X2 Speed Switch Replacement, RIDGID R84015 X2 Case Removal: 步骤 1 中的图像 1,2 RIDGID R84015 X2 Speed Switch Replacement, RIDGID R84015 X2 Case Removal: 步骤 1 中的图像 2,2
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Speed Switch Replacement: 步骤 2 中的图像 1,1
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Speed Switch Replacement: 步骤 3 中的图像 1,2 RIDGID R84015 X2 Speed Switch Replacement: 步骤 3 中的图像 2,2
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Speed Switch Replacement, Speed Switch: 步骤 4 中的图像 1,1
    • Locate small metal bar above plastic part of drill.
    • Attempt to move bar back and forth. If it wont move, try to move it while rotating the chuck. If it still will not move, there is a problem with the gears. For help see the Planetary Gear Replacement Guide
  5. RIDGID R84015 X2 Speed Switch Replacement: 步骤 5 中的图像 1,2 RIDGID R84015 X2 Speed Switch Replacement: 步骤 5 中的图像 2,2
    • If the bar moves, next check the small plastic switch that is numbered 1 and 2.
    • Make sure the small tabs on the underside of the switch that move the bar are intact.
    • Replace switch as needed.
结论
2等其他人完成本指南。
Evan Long
于04/15/10注册
274 声望
创作了4篇指南
团队
Cal Poly, Team 15-48, Garner Spring 2010 Cal Poly, Team 15-48, Garner Spring 2010 的会员
CPSU-GARNER-S10S15G48
6 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 3,695
