跳转到主内容
PowerShot G7 X Mark II LCD Screen Replacement
Brandon
Brandon4 其他贡献者
最后更新于 June 10, 2024
10 - 15 分钟
简单
动态照片拍摄
需要更多图片
This guide will show how to replace the LCD screen on the camera. This replacement is useful if the LCD screen has been cracked or has stopped working.
你所需要的
工具
查看更多...
  1. PowerShot G7 X Mark II LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,1
    • Use a Philips #000 screwdriver to remove the three 2mm screws on the bottom of the LCD screen.
  2. PowerShot G7 X Mark II LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Tilt the LCD screen all the way up and use a Phillips #000 screwdriver to remove the three 4mm screws from the back of the LCD screen.
  3. PowerShot G7 X Mark II LCD Screen Replacement, Remove back panel from LCD screen: 步骤 3 中的图像 1,1
    • Use a spudger tool to release the ribbon cable from the ZIF connector.
    • The cable is thin and delicate. Detach with care.
    • Gently pry off the screen until the double-sided tape behind the back panel gives in.
  4. PowerShot G7 X Mark II LCD Screen Replacement: 步骤 4 中的图像 1,1
    • The screen is detached and can now be replaced.
结论
4等其他人完成本指南。
Brandon
于02/15/17注册
626 声望
创作了4篇指南
团队
USF Tampa, Team 12-3, Eyestone Spring 2017 USF Tampa, Team 12-3, Eyestone Spring 2017 的会员
USFT-EYESTONE-S17S12G3
3 名成员
创作了4篇指南
5指南评论
Are there any problems with the replacement screen? It’s a touch screen, just making sure the functionality of the screen is still intact.
Andrew Baez - 回复
These directions do not give enough information. The screed is glued into the frame. The replacement parts do not come with the circuit board.
alan saltus - 回复
Did you successfully replace the screen? I took off the screws, and got to the detaching the wire stage but then discovered as you said “the glue”. Any further insight would be appreciated!
rachelkernali -
My G7X lost one of the 2 screws holding the screen: do you know where I can find them?
paolofarinella - 回复
on ebay or amazon. you can order it
nicole -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 131
总计 9,374
