简介
Use this guide to remove or replace the battery on your Xiaomi Poco X3 Pro.
If your battery is swollen, take appropriate precautions.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You’ll need replacement adhesive to reattach components when reassembling the device.
你所需要的
Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick to the bottom right corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a second opening pick at the bottom edge of your phone.
Slide the opening pick to the bottom left corner to slice the adhesive.
Insert a third opening pick at the bottom left corner of your phone.
Slide the opening pick along the left edge of your phone to slice the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Use a Phillips screwdriver of the correct size to remove the eleven 3.9 mm-long screws securing the motherboard cover.
Insert the tip of an opening pick underneath the bottom right edge of the motherboard cover.
Slide the opening pick along the right edge of the motherboard cover to unhinge the plastic clips and pry it up.
Insert the opening pick underneath the top edge of the motherboard cover and pry it up.
Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
在这个步骤中使用的工具:Tweezers$4.99
Use a spudger to disconnect the power and volume button flex cable by prying the connector straight up from its socket.
Use a pair of tweezers or your fingers to carefully fold the power and volume button flex cable to the side in order to get free access to the battery.
Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
Fold the interconnect flex cable towards the charging port in order to get access to the battery pull tabs.
Use a pair of blunt nose tweezers or a clean fingernail to peel the orange adhesive strip labelled with an A off the battery.
Use a pair of blunt nose tweezers or a clean fingernail to peel the orange adhesive strip labelled with a B off the battery.
Grab both pull–tab ends labelled with an A and pull up on the orange adhesive strip to lift the battery out of its recess and swing it up to an upright position.
Peel the battery off the remaining adhesive.
Remove the battery.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
For optimal performance, calibrate your newly installed battery after completing this guide.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
47等其他人完成本指南。
10指南评论
Big thanks!! 🍻🍻💪💪
Big thanks excellent tutorial 🙂
ماذا عن الجو بارد جدا انا حقا محتار من هاتف كهذا
Hello, do you lose fast charging with the battery replacement?
