跳转到主内容
Philips Sonicare DiamondClean Motor Replacement
Caleb Watson
Caleb Watson2 其他贡献者
最后更新于 April 17, 2022
30分钟
中等
特色学生指南
This guide will show you how to replace the motor on your Philips Sonicare DiamondClean electric toothbrush. If the motor fails to produce movement or makes excessive noise during function, you may be able to restore your toothbrush by replacing the motor. The motor will need to be desoldered from the circuit board in order to be removed, so be sure to check out our How to Solder and Desolder Connections guide if you are unfamiliar with best practices!
你所需要的
工具
查看更多...
  1. Philips Sonicare DiamondClean Motor Replacement, Motor: 步骤 1 中的图像 1,2 Philips Sonicare DiamondClean Motor Replacement, Motor: 步骤 1 中的图像 2,2
    • Pull the toothbrush head off the toothbrush.
  2. Philips Sonicare DiamondClean Motor Replacement: 步骤 2 中的图像 1,1
    • Use a spudger to pry the chrome cap from the base of the toothbrush.
    In einem anderen Tutorial habe ich gesehen, dass jemand mit Heißkleber eine Klebestange daran geklebt hat. Diese hatte er als Griff zum herausziehen verwendet. Durch diese Methode gibt es keine Macken am Gehäuse und man kann den Heiskleber wieder gut entfernen.
    Jens Lattke - 回复
  3. Philips Sonicare DiamondClean Motor Replacement: 步骤 3 中的图像 1,2 Philips Sonicare DiamondClean Motor Replacement: 步骤 3 中的图像 2,2
    • Place the toothbrush upside down on a solid object and firmly, but gently, push down on the toothbrush until the internal components and case separate.
    • Note that there are clips inside the case but they are hard to access and unneeded to separate the components.
  4. Philips Sonicare DiamondClean Motor Replacement: 步骤 4 中的图像 1,2 Philips Sonicare DiamondClean Motor Replacement: 步骤 4 中的图像 2,2
    • Remove the rubber covers from the circuit board and battery.
  5. Philips Sonicare DiamondClean Motor Replacement: 步骤 5 中的图像 1,1
    • Using a soldering iron, remove the solder from the positions marked 1 and 2 on the circuit board.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices!
  6. Philips Sonicare DiamondClean Motor Replacement: 步骤 6 中的图像 1,1
    • Slide and separate the two components of the internals from each other.
  7. Philips Sonicare DiamondClean Motor Replacement: 步骤 7 中的图像 1,1
    • Gently remove the spring and rubber component.
  8. Philips Sonicare DiamondClean Motor Replacement: 步骤 8 中的图像 1,2 Philips Sonicare DiamondClean Motor Replacement: 步骤 8 中的图像 2,2
    • Remove the two 4mm Phillips #00 screws on both sides of the upper component.
  9. Philips Sonicare DiamondClean Motor Replacement: 步骤 9 中的图像 1,2 Philips Sonicare DiamondClean Motor Replacement: 步骤 9 中的图像 2,2
    • Gently bend and position the brackets to remove the motor.
  10. Philips Sonicare DiamondClean Motor Replacement: 步骤 10 中的图像 1,1
    • Remove the motor and replace.
结论
另外一个人完成了本指南。
2指南评论
Do you have a part number for the motor?
Suraj Daryapurkar - 回复
Double check if the vibrating end on step 4 is screwed tight. On my unit, I though the motor had an issue, whereas it just was that a screw on the vibrating end that had gotten loose.
Marsya Kaustentein - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 33
过去 30 天: 188
总计 7,489
