跳转到主内容
Philips PD9000 37 Battery Replacement
Kendal Cler
Kendal Cler3 其他贡献者
最后更新于 December 18, 2015
15 - 30 分钟
困难
This guide will help users to replace the inner battery of the Philips PD9000/37 DVD Player.
你所需要的
工具
查看更多...
  1. Philips PD9000 37 Battery Replacement, White Outer Housing: 步骤 1 中的图像 1,3 Philips PD9000 37 Battery Replacement, White Outer Housing: 步骤 1 中的图像 2,3 Philips PD9000 37 Battery Replacement, White Outer Housing: 步骤 1 中的图像 3,3
    • Lay the player flat so the bottom outside is showing. Using the Phillips #0 screwdriver, unscrew all the housing screws on the bottom of the player.
    • Have the player sitting upright, remove the rubber stoppers in order to get to the screw. Unscrew the inside screws by the screen using the Philips #0 screwdriver.
    • Remove the rubber stoppers for the bottom two screws as well. Unscrew the middle two screws.
    Can you provide one for the bad motor and how to fix the problem. Please, email me at syaiugligs@gmail.com when you have the guidelines available.
    Thank you!
    Sylvester Yaiuglig - 回复
    The screws on the top of the screen and bottom are not necessary
    grace nicosin - 回复
  2. Philips PD9000 37 Battery Replacement: 步骤 2 中的图像 1,2 Philips PD9000 37 Battery Replacement: 步骤 2 中的图像 2,2
    • Open the disc flap and remove the screws inside with the Phillips #0 screwdriver. There will be three screws.
  3. Philips PD9000 37 Battery Replacement: 步骤 3 中的图像 1,3 Philips PD9000 37 Battery Replacement: 步骤 3 中的图像 2,3 Philips PD9000 37 Battery Replacement: 步骤 3 中的图像 3,3
    • Start removing the inside black face plate of the player by using a prying method between the white outer housing and the black face plate with a metal spudger.
    • Pull the black face plate off once you have pried it from the white housing. The bottom inside layer should pop off.
    • Using the same prying method with the metal spudger, start prying off the screens white outer housing.
  4. Philips PD9000 37 Battery Replacement: 步骤 4 中的图像 1,3 Philips PD9000 37 Battery Replacement: 步骤 4 中的图像 2,3 Philips PD9000 37 Battery Replacement: 步骤 4 中的图像 3,3
    • The light panel on the front can just pop right off.
    • To remove the metal bar against the battery, unscrew the screws with the phillips #0 screwdriver.
    • After unscrewing you can just lift the metal bar off.
  5. Philips PD9000 37 Battery Replacement, Battery: 步骤 5 中的图像 1,2 Philips PD9000 37 Battery Replacement, Battery: 步骤 5 中的图像 2,2
    • Take the metal rounded rectangle spudger and place under battery edge.
    • Avoid breaking plastic cover.
    • press down hard on held end of spudger, you will hear the battery un-stick.
  6. Philips PD9000 37 Battery Replacement: 步骤 6 中的图像 1,2 Philips PD9000 37 Battery Replacement: 步骤 6 中的图像 2,2
    • Use a soldering iron to melt the metal connecting the battery wires to the mother board.
    • Quickly remove each wire after melting the metal
    • Soldering iron is HOT and will burn you.
    • Wires will get HOT and may burn you.
  7. Philips PD9000 37 Battery Replacement: 步骤 7 中的图像 1,1
    • Properly dispose of battery as soon as possible
    • If battery is not disposed of, it may bloat and explode
    • If battery leaks, dispose of right away and wash hands.
结论
5等其他人完成本指南。
Kendal Cler
于09/28/15注册
969 声望
创作了6篇指南
3指南评论
Where can this battery be bought? After a year using, playing time is down to 3 hours
L.Johnson - 回复
Yeah. Where can I get the battery?
Bryan Allen - 回复
This tutorial is completely worthless if one doesn't have a battery to replace the one removed. Now two people have asked where to get a replacement yet you have not responded. Undoubtedly countless others have come by looking for a suitable replacement and saw that there was no response and no solution. Congratulations on helping no one. It would seem you're nothing more than a blowhard, a big show off, “Oh look at me I am fixing my bad battery. Aren't you impressed?” I'm not.
kurt - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 48
总计 7,778
