跳转到主内容
Philips Norelco OneBlade Exterior Casing Replacement
Joshua Etchberger
Joshua Etchberger 另一个贡献者
最后更新于 July 16, 2024
2 - 5 分钟
简单
Replacing the exterior casing on a Philips Norelco OneBlade requires little time, no tools, and a replacement casing.
你所需要的
  1. Philips Norelco OneBlade Exterior Casing Replacement, Exterior Casing: 步骤 1 中的图像 1,3 Philips Norelco OneBlade Exterior Casing Replacement, Exterior Casing: 步骤 1 中的图像 2,3 Philips Norelco OneBlade Exterior Casing Replacement, Exterior Casing: 步骤 1 中的图像 3,3
    • Ensure razor is off, and razor blade has been removed.
  2. Philips Norelco OneBlade Exterior Casing Replacement: 步骤 2 中的图像 1,2 Philips Norelco OneBlade Exterior Casing Replacement: 步骤 2 中的图像 2,2
    • Locate crease in bottom third of razor.
    • Hold razor in both hands, and place thumbs near crease.
    • Slightly bend the razor near crease.
    • Pull top razor apart.
    • Caution, device may turn on upon removal. Turn off razor before continuing.
  3. Philips Norelco OneBlade Exterior Casing Replacement: 步骤 3 中的图像 1,1
    • Power button should face forward in same direction as circuit board. The crease on each casing component should line up.
结论
Please dispose of exterior casing properly. For recycling information, please contact your local waste management facilities or visit www.recycle.philips.com
团队
IUPUI, Team S3-G3, Harley Fall 2017 IUPUI, Team S3-G3, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S3G3
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 20
过去 30 天: 102
总计 3,651
