跳转到主内容
Packard Bell EasyNote TJ65-CU-030GE Battery Replacement
Jasmin
Jasmin 另一个贡献者
最后更新于 January 9, 2020
20秒
非常容易
The removal of the battery is one of the easiest tasks on the Packard Bell EasyNote TJ65-CU-030GE. It is strongly recommended to remove the battery before conducting repairs on the laptop. No tools are needed.
  1. Packard Bell EasyNote TJ65-CU-030GE Battery Replacement, Battery: 步骤 1 中的图像 1,2 Packard Bell EasyNote TJ65-CU-030GE Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • The battery is located on the top left corner of the backside of the device.
    • On the left side underneath the battery drawer, you can see two battery lock switches located in the shape of a T.
    • At the beginning, both switches should be switched to the locked position.
  2. Packard Bell EasyNote TJ65-CU-030GE Battery Replacement: 步骤 2 中的图像 1,3 Packard Bell EasyNote TJ65-CU-030GE Battery Replacement: 步骤 2 中的图像 2,3 Packard Bell EasyNote TJ65-CU-030GE Battery Replacement: 步骤 2 中的图像 3,3
    • Slide the vertical battery lock switch downwards to the image of the unlocked padlock.
    • Now you can move the horizontal battery lock switch to the right.
    • You need to apply some pressure to fully move over the switch. At the hardest part, the battery drawer will spring open.
    • Now you can remove the battery block completely.
    • By doing this, the horizontal switchlock will jump back to its original position on the left side.
结论
5等其他人完成本指南。
Jasmin
于02/17/16注册
407 声望
撰写一个指南
团队
iFixit EU Team iFixit EU Team 的会员
Staff
39 名成员
创作了1,147篇指南
4指南评论
I am trying to find out how I have managed to turn off the battery on my packardbell easy note ENTG71BM. Any ideas?
julie crockford - 回复
I am tring to turn on the pc, but the only thing it does is making noise of the fan repeatedly without lighting the screen.
siyabonga - 回复
Solution could be as simple as selecting the right video output mode, follow the first hint from the most useful answer in this thread https://it.ifixit.com/Risposte/Visualizz.... If it helped you solve your problem, please feel free to leave a feedback to the author of the post, otherwise I suggest you try asking directly in the above-mentioned dedicated topic
Simone -
I’m trying to switch on my pc but it says diagnosing pc then it goes on and say attempting repairs I don’t know what to do
Anelisiwe - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 96
总计 8,107
