跳转到主内容
PDP Victrix Gambit Prime Joystick Cover Replacement
Tessa Baldwin
Tessa Baldwin 另一个贡献者
最后更新于 December 18, 2024
6 - 10 分钟
简单
Replacing the joystick covers will enhance productivity and result in more accurate outputs. In the steps provided below, we have shown you how to efficiently remove and replace the joystick covers.
你所需要的
工具
  1. PDP Victrix Gambit Prime Joystick Cover Replacement, Joystick Cover: 步骤 1 中的图像 1,1
    • Insert an opening tool in the gap between the rear and front case.
    • Pry around the perimeter until the front case releases.
    • Remove the front case.
    • If your device has a circular Directional Pad, remove it first to access the faceplate.
  2. PDP Victrix Gambit Prime Joystick Cover Replacement: 步骤 2 中的图像 1,1
    • Firmly grasp the joystick cover and pull it straight up and off of the controller.
  3. PDP Victrix Gambit Prime Joystick Cover Replacement: 步骤 3 中的图像 1,1
    • Align the new joystick with the controller's socket; press down until it clicks into place.
结论
另外一个人完成了本指南。
1指南评论
Helpful and clear instructions given by the Author. Although an opening tool is definitely overkill for removing the faceplate as it's held on by a few magnets and requires little effort. If the faceplate doesn't come off easily it's probably because you need to remove the circular D-Pad (which the Author mentions in Step 1 - "i")
Nate Allen - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 31
总计 133
