跳转到主内容
Oral-B White Pro 1000 Battery Replacement
Carl Kinsey
Carl Kinsey2 其他贡献者
最后更新于 May 27, 2024
25 - 30 分钟
困难
特色学生指南
Battery Replacement guide for Oral-B White Pro 1000 rechargeable electric toothbrush due to faulty battery. This guide illustrates the disassembly of the Oral-B White Pro 1000 electric toothbrush. Use caution not to short the positive (+) and negative (-) terminals when handling the battery. This guide also requires the use of a soldering tool which reaches high temperatures. Refer to this helpful guide for some soldering and desoldering tips.
你所需要的
工具
查看更多...
  1. Oral-B White Pro 1000 Battery Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Remove the brush head by pulling the top away from the base.
  2. Oral-B White Pro 1000 Battery Replacement: 步骤 2 中的图像 1,3 Oral-B White Pro 1000 Battery Replacement: 步骤 2 中的图像 2,3 Oral-B White Pro 1000 Battery Replacement: 步骤 2 中的图像 3,3
    • Pry open the end cap from the toothbrush body.
    • Remove the spring.
  3. Oral-B White Pro 1000 Battery Replacement: 步骤 3 中的图像 1,2 Oral-B White Pro 1000 Battery Replacement: 步骤 3 中的图像 2,2
    • Apply pressure on the brush shaft to release the toothbrush internals.
    • Remove the internals through the bottom of the toothbrush body.
  4. Oral-B White Pro 1000 Battery Replacement: 步骤 4 中的图像 1,2 Oral-B White Pro 1000 Battery Replacement: 步骤 4 中的图像 2,2
    • Use flat head screwdriver to remove power button pressure plate.
  5. Oral-B White Pro 1000 Battery Replacement: 步骤 5 中的图像 1,3 Oral-B White Pro 1000 Battery Replacement: 步骤 5 中的图像 2,3 Oral-B White Pro 1000 Battery Replacement: 步骤 5 中的图像 3,3
    • Desolder the coil wire from the motherboard.
    • Check out this helpful guide for some soldering and desoldering tips.
    • Squeeze and remove coil from motherboard.
  6. Oral-B White Pro 1000 Battery Replacement: 步骤 6 中的图像 1,2 Oral-B White Pro 1000 Battery Replacement: 步骤 6 中的图像 2,2
    • Desolder the motor from motherboard.
    • Remove motherboard and battery from body of toothbrush internals.
  7. Oral-B White Pro 1000 Battery Replacement: 步骤 7 中的图像 1,2 Oral-B White Pro 1000 Battery Replacement: 步骤 7 中的图像 2,2
    • Desolder the battery connections from the motherboard.
    • Remove motherboard from battery holder.
  8. Oral-B White Pro 1000 Battery Replacement, Battery: 步骤 8 中的图像 1,2 Oral-B White Pro 1000 Battery Replacement, Battery: 步骤 8 中的图像 2,2
    • Pull to slide battery from battery housing.
    • Remove battery.
结论
24等其他人完成本指南。
Carl Kinsey
于11/08/17注册
609 声望
撰写一个指南
团队
IUPUI, Team S5-G4, Baechle Fall 2017 IUPUI, Team S5-G4, Baechle Fall 2017 的会员
IUPUI-BAECHLE-F17S5G4
3 名成员
创作了8篇指南
14条评论
This guide also works for Oral-B genius 9000. Thank You!! On mine, the coil wires was losen. Just soldered it back and works fine again.
polken - 回复
Same with mine: coil was loose. I guessed it because the red blinking light would not react (turn off) by putting the toothbrush on the charger. (checked also a second charger, never through away older parts, using as spare…) ;)
Karsten -
This guide also works for Oral B PRO 2950N. Thank you so much!
I had the same issue, the coil was broken on one side, and it doesn't charge. Adding a little bit of solder to weld the broken end was enough for making it charge again
Jacobo Ventosinos -
What type of battery is that? It's not listed under “parts.”
Andrew Rothman - 回复
I’ve wrote it in another comment as well, but in case you didn’t see it: As far as I know, these are 4/5 AA batteries with about 1200 mAh and U-shaped solder tails. So the size of the battery is roughly 42x14mm . But as mentioned in the comments, regular AA size batteries worked in my case as well, just had to cut the spacers in the battery retainer. AA batteries are cheaper to get obviously and most likely they’ll have more capacity as well.
benn_i -
添加评论
浏览统计数据:
过去 24 小时: 32
过去 7 天: 199
过去 30 天: 873
总计 64,140
