跳转到主内容
加入维修社区 - 创建账户
OontZ Angle 3 Battery Replacement
你所需要的
    1. OontZ Angle 3 Battery Replacement, Back Case: 步骤 1 中的图像 1,3 OontZ Angle 3 Battery Replacement, Back Case: 步骤 1 中的图像 2,3 OontZ Angle 3 Battery Replacement, Back Case: 步骤 1 中的图像 3,3
      • Make sure that the OontZ Angle 3 is powered off before starting the disassembly.
      • Use the plastic opening tool to remove the rubber caps from each end of the speaker.
      添加评论
    2. OontZ Angle 3 Battery Replacement: 步骤 2 中的图像 1,1
      • Remove four (4) 11.7 mm Phillips #0 screws from each side at the bottom of the speaker.
      询问修复机器人
      添加评论
    3. OontZ Angle 3 Battery Replacement: 步骤 3 中的图像 1,2 OontZ Angle 3 Battery Replacement: 步骤 3 中的图像 2,2
      • Use the plastic opening tool on one of the corners to separate the bottom piece from the speaker, and then remove the piece.
      添加评论
    1. OontZ Angle 3 Battery Replacement, Battery: 步骤 4 中的图像 1,3 OontZ Angle 3 Battery Replacement, Battery: 步骤 4 中的图像 2,3 OontZ Angle 3 Battery Replacement, Battery: 步骤 4 中的图像 3,3
      • Begin by removing the bottom piece, revealing the inner compartment with the speaker cables and battery.
      • Remove two (2) 11.7mm Phillips #0 screws from each side of the speaker plate.
      • Remove speaker plate from the front of the battery.
      询问修复机器人
      添加评论
    2. OontZ Angle 3 Battery Replacement: 步骤 5 中的图像 1,3 OontZ Angle 3 Battery Replacement: 步骤 5 中的图像 2,3 OontZ Angle 3 Battery Replacement: 步骤 5 中的图像 3,3
      • Locate the soldering points for the battery on the motherboard face of the speaker.
      • Use a soldering iron to carefully disconnect the battery from the motherboard.
      • Learn more about soldering here.
      • Remove the battery from the inside compartment for replacement.
      • Be careful when soldering the new battery into the correct position on the motherboard, as a bad connection can cause the battery to overheat or catch on fire.
      添加评论
结论
取消:我没有完成这个指南。
16等其他人完成本指南。
团队
USF Tampa, Team 15-6, Remmell Spring 2016 USF Tampa, Team 15-6, Remmell Spring 2016 的会员
USFT-REMMELL-S16S15G6
4 名成员
创作了8篇指南
27指南评论
What is the kind of battery used? Thanks!
Rodrigo Lopez - 回复 分享
Hi Rodrigo, the Oontz Angle 3 uses a rechargeable 2200mAh lithium-ion battery. Happy Fixing!
Kelsea Weber - 回复 分享
can i upgrade it to 4300mah?
klien klaus - 回复 分享
the one that I have has a "circuit board" attached to the battery. Is this what controls the recharging? If so, where do you get the battery with these?
Rob - 回复 分享
Hi Rob,use soldering iron disconnect the circuit board which come with old battery you going to replace, and soldering iron the disconnected circuit board back onto your new battery. The so called circuit board is to protect the battery from over discharge or over charge. Hope this help.
benckbenck - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 34
过去 30 天: 149
总计 30,272
