跳转到主内容
加入维修社区 - 创建账户
OnePlus 8 Motherboard Replacement
你所需要的
  1. OnePlus 8 Motherboard Replacement, Heat the rear glass: 步骤 1 中的图像 1,1
    • Power off your phone and unplug any cables.
    • Heat an iOpener and apply it to the rear glass for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and internal battery, so proceed with care.
  2. OnePlus 8 Motherboard Replacement, Insert an opening pick: 步骤 2 中的图像 1,3 OnePlus 8 Motherboard Replacement, Insert an opening pick: 步骤 2 中的图像 2,3 OnePlus 8 Motherboard Replacement, Insert an opening pick: 步骤 2 中的图像 3,3
    • Apply a suction handle to the center of the bottom edge of the rear glass, as close to the edge as possible.
    • If your display is badly cracked, cover it with a layer of clear packing tape to help the suction cup adhere. Alternatively, you can pull using very strong tape instead of a suction cup. If all else fails, try supergluing the suction cup to the broken screen.
    • Pull up on the suction handle with strong, steady force to create a gap between the rear glass and frame.
    • Insert an opening pick into the gap.
  3. OnePlus 8 Motherboard Replacement, Slice the bottom edge adhesive: 步骤 3 中的图像 1,3 OnePlus 8 Motherboard Replacement, Slice the bottom edge adhesive: 步骤 3 中的图像 2,3 OnePlus 8 Motherboard Replacement, Slice the bottom edge adhesive: 步骤 3 中的图像 3,3
    • Slide the opening pick to the bottom right corner to slice the adhesive securing the rear glass.
    • Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
  4. OnePlus 8 Motherboard Replacement: 步骤 4 中的图像 1,3 OnePlus 8 Motherboard Replacement: 步骤 4 中的图像 2,3 OnePlus 8 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Insert a second opening pick under the bottom edge of the rear glass, into the gap you just created.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  5. OnePlus 8 Motherboard Replacement, Slice the left edge adhesive: 步骤 5 中的图像 1,3 OnePlus 8 Motherboard Replacement, Slice the left edge adhesive: 步骤 5 中的图像 2,3 OnePlus 8 Motherboard Replacement, Slice the left edge adhesive: 步骤 5 中的图像 3,3
    • If you have trouble slicing, reheat the iOpener and apply it to the edge for two minutes to soften the adhesive.
    • Insert a third opening pick under the bottom left corner of the rear glass.
    • Slide the opening pick up the left edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. OnePlus 8 Motherboard Replacement, Slice the top edge adhesive: 步骤 6 中的图像 1,3 OnePlus 8 Motherboard Replacement, Slice the top edge adhesive: 步骤 6 中的图像 2,3 OnePlus 8 Motherboard Replacement, Slice the top edge adhesive: 步骤 6 中的图像 3,3
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  7. OnePlus 8 Motherboard Replacement, Slice the right edge adhesive: 步骤 7 中的图像 1,3 OnePlus 8 Motherboard Replacement, Slice the right edge adhesive: 步骤 7 中的图像 2,3 OnePlus 8 Motherboard Replacement, Slice the right edge adhesive: 步骤 7 中的图像 3,3
    • Insert a fifth opening pick under the top right corner of the rear glass.
    • Slide the opening pick down the right edge to slice the remaining adhesive.
  8. OnePlus 8 Motherboard Replacement, Remove the rear glass: 步骤 8 中的图像 1,3 OnePlus 8 Motherboard Replacement, Remove the rear glass: 步骤 8 中的图像 2,3 OnePlus 8 Motherboard Replacement, Remove the rear glass: 步骤 8 中的图像 3,3
    • Remove the rear glass.
    • If the rear glass still feels stuck to the frame, slide an opening pick around the entire perimeter until the rear glass separates completely.
    • During reassembly:
    • Secure the rear glass with pre-cut adhesive or double-sided adhesive tape.
    • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
  9. OnePlus 8 Motherboard Replacement, Unfasten the motherboard cover: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    • A white sticker may cover a screw on the right edge of the motherboard cover. Pierce through it with the tip of your screwdriver or use tweezers to remove it.
    • Use a Phillips screwdriver to remove the eleven 3.3 mm-long screws securing the motherboard cover.
  10. OnePlus 8 Motherboard Replacement, Pry up the motherboard cover: 步骤 10 中的图像 1,3 OnePlus 8 Motherboard Replacement, Pry up the motherboard cover: 步骤 10 中的图像 2,3 OnePlus 8 Motherboard Replacement, Pry up the motherboard cover: 步骤 10 中的图像 3,3
    • The motherboard cover is secured by tight clips.
    • Insert the flat end of a spudger under the center of the motherboard cover's bottom edge.
    • Twist the spudger to release the clips.
    • Lever the motherboard cover up until you can grip it with your fingers.
  11. OnePlus 8 Motherboard Replacement, Remove the motherboard cover: 步骤 11 中的图像 1,2 OnePlus 8 Motherboard Replacement, Remove the motherboard cover: 步骤 11 中的图像 2,2
    • Remove the motherboard cover.
  12. OnePlus 8 Motherboard Replacement, Disconnect the battery cable: 步骤 12 中的图像 1,2 OnePlus 8 Motherboard Replacement, Disconnect the battery cable: 步骤 12 中的图像 2,2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket on the bottom left corner of the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  13. OnePlus 8 Motherboard Replacement, Rear Camera: 步骤 13 中的图像 1,2 OnePlus 8 Motherboard Replacement, Rear Camera: 步骤 13 中的图像 2,2
    • Disconnect the antenna cable connector on the right, using tweezers.
    • Disconnect the antenna cable connector on the left using tweezers.
  14. OnePlus 8 Motherboard Replacement: 步骤 14 中的图像 1,3 OnePlus 8 Motherboard Replacement: 步骤 14 中的图像 2,3 OnePlus 8 Motherboard Replacement: 步骤 14 中的图像 3,3
    • Use an opening tool to gently pry and disconnect the three camera press connectors.
  15. OnePlus 8 Motherboard Replacement: 步骤 15 中的图像 1,1
    • Remove the rear camera.
  16. OnePlus 8 Motherboard Replacement, Motherboard: 步骤 16 中的图像 1,2 OnePlus 8 Motherboard Replacement, Motherboard: 步骤 16 中的图像 2,2
    • Use an opening tool to pry up and disconnect the front camera press connector.
    • Remove the front camera.
  17. OnePlus 8 Motherboard Replacement: 步骤 17 中的图像 1,3 OnePlus 8 Motherboard Replacement: 步骤 17 中的图像 2,3 OnePlus 8 Motherboard Replacement: 步骤 17 中的图像 3,3
    • Use an opening tool to pry up and disconnect each of the three press connectors attached to the motherboard.
  18. OnePlus 8 Motherboard Replacement: 步骤 18 中的图像 1,1
    • Remove the motherboard by carefully pryinng it out with the opening tool, lifting the battery out to make removal easier.
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Mohsin Pannu
于09/19/24注册
97 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 20
过去 30 天: 56
总计 542
