跳转到主内容
Nvidia Shield Tablet Rear Case Replacement
Molly Bauer
Molly Bauer5 其他贡献者
最后更新于 March 7, 2024
15 - 20 分钟
中等
The case of any device is always the first line of defense against any kind of external damage. The Shield Tablet in particular is known to be susceptible to casing cracks, specifically at the corners. This guide will show you the step-by-step instructions required to replace your cracked case.
你所需要的
工具
  1. Nvidia Shield Tablet Rear Case Replacement, Rear Case: 步骤 1 中的图像 1,2 Nvidia Shield Tablet Rear Case Replacement, Rear Case: 步骤 1 中的图像 2,2
    • First, remove the stylus from your tablet.
    Which website I can buy battery?
    Hang Chetha - 回复
  2. Nvidia Shield Tablet Rear Case Replacement: 步骤 2 中的图像 1,3 Nvidia Shield Tablet Rear Case Replacement: 步骤 2 中的图像 2,3 Nvidia Shield Tablet Rear Case Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
  3. Nvidia Shield Tablet Rear Case Replacement: 步骤 3 中的图像 1,2 Nvidia Shield Tablet Rear Case Replacement: 步骤 3 中的图像 2,2
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
结论
5等其他人完成本指南。
Molly Bauer
于08/27/15注册
1,442 声望
创作了6篇指南
团队
USF Tampa, Team 2-2, Blackwell Fall 2015 USF Tampa, Team 2-2, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S2G2
3 名成员
创作了11篇指南
一条评论
I snapped the cable of the dabbler on the rear case coz i didnt know there was one!
Anyone knows where can i get a new one?
damjannedelkovski - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 24
总计 3,420
