跳转到主内容
Nvidia Shield Tablet K1 Back Panel Replacement
Ryan Butler
Ryan Butler3 其他贡献者
最后更新于 February 3, 2020
3分钟
简单
This guide will walk you through the process of opening the Back Panel to your Nvidia Shield Tablet K1.
你所需要的
工具
  1. Nvidia Shield Tablet K1 Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Starting at the Micro SD Card Slot and using the blue plastic opening tool, begin to maneuver the tool around the edges while applying light pressure to lift the panel upwards.
  2. Nvidia Shield Tablet K1 Back Panel Replacement: 步骤 2 中的图像 1,2 Nvidia Shield Tablet K1 Back Panel Replacement: 步骤 2 中的图像 2,2
    • There are clips holding the back panel to the rest of the case. You must apply some force to lift the back panel off.
    • Continue lifting up the panel all the way around the edges of the tablet.
    • Once all of the panel clips are unfastened, gently remove the back panel.
结论
7等其他人完成本指南。
Ryan Butler
于02/09/16注册
1,727 声望
创作了9篇指南
团队
iFixit, Team 1-1, Weber Winter 2016 iFixit, Team 1-1, Weber Winter 2016 的会员
FIX-WEBER-W16S1G1
4 名成员
创作了37篇指南
2条评论
Hello, I’m planning on replacing the battery on my K1 soon, will the rear panel snap back in?
Scott - 回复
but wait theres flex cable your not showing thats attached to the cover it could be ripped off and bricked like mine because no one know the name of said cable
Christian Rogers - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 38
总计 5,176
