Nokia 6310i Antenna Replacement
简介
转到步骤 1This guide is to instruct the reader about the steps on replacing the internal antenna. The phone will have to be disassembled to reach to the antenna. A proper set of Torx (Star) screw-driver is necessary to complete the procedures.
Press and hold the battery release button and slide the battery away from the Nokia logo
Unscrew and remove the four T6 Torx screws.
A comment for anyone wanting to clean the metal contacts to improve keypad response, make sure you spray iso alcohol onto a lint free cloth and wipe the contacts, not onto the device itself and definitely not onto the LCD screen, as it can leave a marl on the screen. Luckily it evaporated eventually but only after 48hrs...
Remove the screw holding the antenna to the circuit board.
Carefully lift off the antenna from the circuit board.
3等其他人完成本指南。
2条评论
Thanks for a nice and helpful instruction.
The rubber power-on button had broken down so I just removed the damaged parts. Now using a toothpick to push the microswitch directly.
Only using the phone indoors for nostalgic reasons, playing Snake :-)
Brgrds Ove
Thanks for antenna help
I have had about three 6310i’s and the on/off button was the failure problem in all three.
