跳转到主内容
Nokia 5310b XpressMusic LCD Screen Replacement
Max Kirby
Max Kirby3 其他贡献者
最后更新于 January 20, 2025
15 - 20 分钟
中等
不正确的工具
语法警察
要点符号!
更好的介绍
你所需要的
工具
  1. Nokia 5310b XpressMusic LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the back cover down with your thumb.
    • *Note: the battery cover is not shown in this picture
  2. Nokia 5310b XpressMusic LCD Screen Replacement: 步骤 2 中的图像 1,2 Nokia 5310b XpressMusic LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Gently lift the battery with a fingernail and remove it from its housing.
    • *Note: the battery may be replaced or repaired at this step
  3. Nokia 5310b XpressMusic LCD Screen Replacement, Keypad: 步骤 3 中的图像 1,3 Nokia 5310b XpressMusic LCD Screen Replacement, Keypad: 步骤 3 中的图像 2,3 Nokia 5310b XpressMusic LCD Screen Replacement, Keypad: 步骤 3 中的图像 3,3
    • On some models, the front case is screwed down from the back. Follow steps 5 and 6 FIRST to remove the camera cover and two T6 screws, before removing the faceplate.
    • Use the Spudger to gently pry up the edges of the front face plate
    • At the center of the faceplate edge below the music keys there is a small latch on each side.
    Before doing this step, first remove the camera cover and the two t6 screws from the back (steps 5 and 6). Otherwise you will break the cover. This may be a factor only for some revisions (RM-304)
    s c - 回复
  4. Nokia 5310b XpressMusic LCD Screen Replacement: 步骤 4 中的图像 1,2 Nokia 5310b XpressMusic LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Lift up the keypad from the bottom with either the spudger or your finger.
    • Note: at this time the keypad can be removed and replaced
  5. Nokia 5310b XpressMusic LCD Screen Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Gently unsnap the back camera cover from the phone.
    • Lift the cover from the phone after it is unsnapped.
  6. Nokia 5310b XpressMusic LCD Screen Replacement: 步骤 6 中的图像 1,2 Nokia 5310b XpressMusic LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Use the T6 torx screwdriver head to remove the 2 screws on either side of the camera
    • Flip over the phone and again us the T6 torx head to remove the 4 screws located at each corner of the white keypad base
  7. Nokia 5310b XpressMusic LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Unclip the faceplate plug (ribbon) located in the lower left corner of the motherboard
  8. Nokia 5310b XpressMusic LCD Screen Replacement: 步骤 8 中的图像 1,2 Nokia 5310b XpressMusic LCD Screen Replacement: 步骤 8 中的图像 2,2
    • Use the Spudger to pry up the 2 metal clips located near the center of the motherboard on both the left and right
    • At this point the phone should come apart into 2 pieces, the motherboard/LCD screen and the faceplate
  9. Nokia 5310b XpressMusic LCD Screen Replacement, LCD Screen: 步骤 9 中的图像 1,1
    • Unclip the ribbon plug located on the top of the LCD screen that connects it to the motherboard.
结论
6等其他人完成本指南。
Max Kirby
于05/01/11注册
518 声望
创作了4篇指南
团队
Cal Poly, Team 15-14, Regan Spring 2011 Cal Poly, Team 15-14, Regan Spring 2011 的会员
CPSU-REGAN-S11S15G14
3 名成员
创作了8篇指南
1指南评论
Thank you much! As efficient & thorough as it gets!
REDACTED FREE PRESS - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 22
总计 9,218
