跳转到主内容
Nokia 5165 Front Cover Replacement
Ethan Pikscher
Ethan Pikscher2 其他贡献者
最后更新于 May 7, 2024
1 - 2 分钟
简单
社区贡献指南
你所需要的
配件
工具
查看更多...
  1. Nokia 5165 Front Cover Replacement, Removing the Cover: 步骤 1 中的图像 1,1
    • Find the tab at the top of the phone and press down with your fingernail or the flat end of a spudger
  2. Nokia 5165 Front Cover Replacement: 步骤 2 中的图像 1,3 Nokia 5165 Front Cover Replacement: 步骤 2 中的图像 2,3 Nokia 5165 Front Cover Replacement: 步骤 2 中的图像 3,3
    • The top of the cover should pop out a little bit, pull the top of the cover out and the cover should come off
  3. Nokia 5165 Front Cover Replacement, Removing The Buttons: 步骤 3 中的图像 1,3 Nokia 5165 Front Cover Replacement, Removing The Buttons: 步骤 3 中的图像 2,3 Nokia 5165 Front Cover Replacement, Removing The Buttons: 步骤 3 中的图像 3,3
    • Pull off the number pad and store it some where safe, you'll need it for the new cover
    • Remove the power button with the flat end of a spudger by getting the spudger under the button and pulling it up by the red tabs
  4. Nokia 5165 Front Cover Replacement, Prepping The New Cover: 步骤 4 中的图像 1,3 Nokia 5165 Front Cover Replacement, Prepping The New Cover: 步骤 4 中的图像 2,3 Nokia 5165 Front Cover Replacement, Prepping The New Cover: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Put the number pad into the new cover and push it down
    • For the power button, I recommend using blunt nose tweezers to put the button in with the slope on the top of the button going down towards the speaker hole, then using a spudger to push it in
    • Using pointed tweezers can put holes in the power button and possibly break the button, only use blunt nose tweezers
  5. Nokia 5165 Front Cover Replacement, Attacing The New Cover: 步骤 5 中的图像 1,3 Nokia 5165 Front Cover Replacement, Attacing The New Cover: 步骤 5 中的图像 2,3 Nokia 5165 Front Cover Replacement, Attacing The New Cover: 步骤 5 中的图像 3,3
    • Make sure the two tabs at the bottom of the cover go into the phone first at an angle, the push the top of the cover in until it clicks and then you are done!
结论
Now you have a new cover!
Ethan Pikscher
于12/19/18注册
351 声望
创作了3篇指南
团队
Kid fixers Kid fixers 的会员
Community
184 名成员
创作了256篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 107
