跳转到主内容
Nokia 3310 3G Keyboard Replacement
Aaron LeBlanc
Aaron LeBlanc3 其他贡献者
最后更新于 April 5, 2023
20分钟
中等
This guide shows a step by step guide to fully access the keyboard, to clean it if it is sticking or completely replace the keypad if it is broken.
你所需要的
工具
查看更多...
  1. Nokia 3310 3G Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 Nokia 3310 3G Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. Nokia 3310 3G Keyboard Replacement: 步骤 2 中的图像 1,2 Nokia 3310 3G Keyboard Replacement: 步骤 2 中的图像 2,2
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
  3. Nokia 3310 3G Keyboard Replacement, Frame: 步骤 3 中的图像 1,3 Nokia 3310 3G Keyboard Replacement, Frame: 步骤 3 中的图像 2,3 Nokia 3310 3G Keyboard Replacement, Frame: 步骤 3 中的图像 3,3
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
  4. Nokia 3310 3G Keyboard Replacement, Motherboard: 步骤 4 中的图像 1,3 Nokia 3310 3G Keyboard Replacement, Motherboard: 步骤 4 中的图像 2,3 Nokia 3310 3G Keyboard Replacement, Motherboard: 步骤 4 中的图像 3,3
    • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
  5. Nokia 3310 3G Keyboard Replacement, Keyboard: 步骤 5 中的图像 1,3 Nokia 3310 3G Keyboard Replacement, Keyboard: 步骤 5 中的图像 2,3 Nokia 3310 3G Keyboard Replacement, Keyboard: 步骤 5 中的图像 3,3
    • Using a spudger, unclip the bottom left snap to unplug the keyboard. The image shows the motherboard rotated 90 degrees counterclockwise
    I need this keypad flex or full keypad with
    ad k - 回复
    I'm from India and I need it very
    ad k - 回复
  6. Nokia 3310 3G Keyboard Replacement: 步骤 6 中的图像 1,1
    • Using your thumb, push the tab on the right side of the motherboard over to the right and then push downward to unclip the keyboard. It should fall away.
结论
5等其他人完成本指南。
Aaron LeBlanc
于10/24/18注册
735 声望
创作了5篇指南
团队
UMass Dartmouth, Team S3-G3, Peak Fall 2018 UMass Dartmouth, Team S3-G3, Peak Fall 2018 的会员
UMASSD-PEAK-F18S3G3
3 名成员
创作了16篇指南
1指南评论
Very useful and to the point
OrangeShoe - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 55
总计 2,484
