跳转到主内容
Nintendo Switch Lite Screen Replacement
你所需要的
  1. Nintendo Switch Lite Screen Replacement, Remove the back panel screws: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Before beginning this repair, make sure that the device is completely turned off.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
  2. Nintendo Switch Lite Screen Replacement, Remove the top and bottom back panel screws: 步骤 2 中的图像 1,2 Nintendo Switch Lite Screen Replacement, Remove the top and bottom back panel screws: 步骤 2 中的图像 2,2
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the back panel:
    • Two 3.6 mm-long screws on the top of the device
    • Two 3.6 mm-long screws on the bottom of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
  3. Nintendo Switch Lite Screen Replacement, Release the clips securing the back panel: 步骤 3 中的图像 1,2 Nintendo Switch Lite Screen Replacement, Release the clips securing the back panel: 步骤 3 中的图像 2,2
    • Insert an opening tool into the left speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips securing the back panel.
    • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
  4. Nintendo Switch Lite Screen Replacement, Continue releasing the clips around the device: 步骤 4 中的图像 1,2 Nintendo Switch Lite Screen Replacement, Continue releasing the clips around the device: 步骤 4 中的图像 2,2
    • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
  5. Nintendo Switch Lite Screen Replacement, Twist to release the clips: 步骤 5 中的图像 1,2 Nintendo Switch Lite Screen Replacement, Twist to release the clips: 步骤 5 中的图像 2,2
    • Insert an opening tool into the right speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips.
  6. Nintendo Switch Lite Screen Replacement, Slide and pry around the corners: 步骤 6 中的图像 1,2 Nintendo Switch Lite Screen Replacement, Slide and pry around the corners: 步骤 6 中的图像 2,2
    • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
  7. Nintendo Switch Lite Screen Replacement: 步骤 7 中的图像 1,2 Nintendo Switch Lite Screen Replacement: 步骤 7 中的图像 2,2
    • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
  8. Nintendo Switch Lite Screen Replacement, Remove the back panel: 步骤 8 中的图像 1,3 Nintendo Switch Lite Screen Replacement, Remove the back panel: 步骤 8 中的图像 2,3 Nintendo Switch Lite Screen Replacement, Remove the back panel: 步骤 8 中的图像 3,3
    • Lift the bottom edge of the back panel, opening it like a book.
    • Remove the back panel.
  9. Nintendo Switch Lite Screen Replacement, Remove the shield plate: 步骤 9 中的图像 1,1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following four screws:
    • Three 3.1 mm screws
    • One 4.5 mm screw
  10. Nintendo Switch Lite Screen Replacement: 步骤 10 中的图像 1,3 Nintendo Switch Lite Screen Replacement: 步骤 10 中的图像 2,3 Nintendo Switch Lite Screen Replacement: 步骤 10 中的图像 3,3
    • Use a spudger or your fingers to lift the shield plate up and out of the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • Clean off the old thermal paste from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the heat sink before reassembly.
  11. Nintendo Switch Lite Screen Replacement, Disconnect the battery: 步骤 11 中的图像 1,2 Nintendo Switch Lite Screen Replacement, Disconnect the battery: 步骤 11 中的图像 2,2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
  12. Nintendo Switch Lite Screen Replacement: 步骤 12 中的图像 1,2 Nintendo Switch Lite Screen Replacement: 步骤 12 中的图像 2,2
    • Do Not Use Metal Tweezers! Some fixers state that metallic tweezers can short circuit the ribbon cable/connector. It might be safer to just use nylon-tipped or ceramic-tipped tweezers.
    • Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard.
  13. Nintendo Switch Lite Screen Replacement: 步骤 13 中的图像 1,2 Nintendo Switch Lite Screen Replacement: 步骤 13 中的图像 2,2
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
  14. Nintendo Switch Lite Screen Replacement, Remove the heat sink: 步骤 14 中的图像 1,1
    • Use the flat end of a spudger or your fingers to carefully peel up the foam that's lightly adhered to the fan.
    • The foam only needs to be peeled back enough to clear the fan.
  15. Nintendo Switch Lite Screen Replacement: 步骤 15 中的图像 1,1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
  16. Nintendo Switch Lite Screen Replacement: 步骤 16 中的图像 1,3 Nintendo Switch Lite Screen Replacement: 步骤 16 中的图像 2,3 Nintendo Switch Lite Screen Replacement: 步骤 16 中的图像 3,3
    • Use a spudger or your fingers to lift the heatsink up and off of the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
  17. Nintendo Switch Lite Screen Replacement, Remove the game card reader and headphone jack: 步骤 17 中的图像 1,2 Nintendo Switch Lite Screen Replacement, Remove the game card reader and headphone jack: 步骤 17 中的图像 2,2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the game card reader cable's ZIF connector.
  18. Nintendo Switch Lite Screen Replacement: 步骤 18 中的图像 1,1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the seven 3.1 mm screws securing the game card reader and headphone jack.
  19. Nintendo Switch Lite Screen Replacement: 步骤 19 中的图像 1,3 Nintendo Switch Lite Screen Replacement: 步骤 19 中的图像 2,3 Nintendo Switch Lite Screen Replacement: 步骤 19 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers or your fingers to carefully lift the game card reader and maneuver it to the left to slide the cable out of its connector.
    • Remove the game card reader and headphone jack.
  20. Nintendo Switch Lite Screen Replacement, Remove the right trigger button assembly: 步骤 20 中的图像 1,1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the two 4.5 mm screws securing the right trigger button assembly to the motherboard.
  21. Nintendo Switch Lite Screen Replacement: 步骤 21 中的图像 1,2 Nintendo Switch Lite Screen Replacement: 步骤 21 中的图像 2,2
    • Remove the right trigger button assembly.
  22. Nintendo Switch Lite Screen Replacement: 步骤 22 中的图像 1,2 Nintendo Switch Lite Screen Replacement: 步骤 22 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers or your fingers to remove the right trigger button assembly's rubber pad if it didn't stay attached to the button assembly.
  23. Nintendo Switch Lite Screen Replacement, Disconnect the antenna cables: 步骤 23 中的图像 1,3 Nintendo Switch Lite Screen Replacement, Disconnect the antenna cables: 步骤 23 中的图像 2,3 Nintendo Switch Lite Screen Replacement, Disconnect the antenna cables: 步骤 23 中的图像 3,3
    • Use the point of a spudger to pry the black antenna cable straight up out of its socket on the motherboard.
    • Repeat the same process for the white antenna cable.
  24. Nintendo Switch Lite Screen Replacement, Disconnect the fan cable: 步骤 24 中的图像 1,1
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
  25. Nintendo Switch Lite Screen Replacement: 步骤 25 中的图像 1,2 Nintendo Switch Lite Screen Replacement: 步骤 25 中的图像 2,2
    • Use a pair of tweezers to slide out the fan cable from its connector on the motherboard.
  26. Nintendo Switch Lite Screen Replacement, Disconnect the screen cable: 步骤 26 中的图像 1,2 Nintendo Switch Lite Screen Replacement, Disconnect the screen cable: 步骤 26 中的图像 2,2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the screen cable's ZIF connector.
  27. Nintendo Switch Lite Screen Replacement: 步骤 27 中的图像 1,2 Nintendo Switch Lite Screen Replacement: 步骤 27 中的图像 2,2
    • Use a pair of tweezers to slide the screen cable out of its connector on the motherboard.
  28. Nintendo Switch Lite Screen Replacement, Disconnect the digitizer cable: 步骤 28 中的图像 1,2 Nintendo Switch Lite Screen Replacement, Disconnect the digitizer cable: 步骤 28 中的图像 2,2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
  29. Nintendo Switch Lite Screen Replacement: 步骤 29 中的图像 1,2 Nintendo Switch Lite Screen Replacement: 步骤 29 中的图像 2,2
    • Use a pair of tweezers to slide the digitizer cable out of its connector on the motherboard.
  30. Nintendo Switch Lite Screen Replacement, Disconnect the right joystick cable: 步骤 30 中的图像 1,2 Nintendo Switch Lite Screen Replacement, Disconnect the right joystick cable: 步骤 30 中的图像 2,2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the right joystick cable's ZIF connector.
  31. Nintendo Switch Lite Screen Replacement: 步骤 31 中的图像 1,2 Nintendo Switch Lite Screen Replacement: 步骤 31 中的图像 2,2
    • Use a pair of tweezers to slide the right joystick cable out of its connector on the motherboard.
  32. Nintendo Switch Lite Screen Replacement, Remove the motherboard assembly: 步骤 32 中的图像 1,1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following six screws securing the motherboard:
    • Three 4.5 mm screws
  33. Nintendo Switch Lite Screen Replacement: 步骤 33 中的图像 1,3 Nintendo Switch Lite Screen Replacement: 步骤 33 中的图像 2,3 Nintendo Switch Lite Screen Replacement: 步骤 33 中的图像 3,3
    • Insert a spudger in the gap between the frame and the motherboard and lift the motherboard up and out of its recess.
    • Remove the motherboard assembly.
  34. Nintendo Switch Lite Screen Replacement, Remove the right joystick: 步骤 34 中的图像 1,1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the two 3.5 mm screws securing the joystick.
  35. Nintendo Switch Lite Screen Replacement: 步骤 35 中的图像 1,2 Nintendo Switch Lite Screen Replacement: 步骤 35 中的图像 2,2
    • Use your fingers to remove the joystick.
    • There is a thin black gasket around the hole where the joystick pokes through the frame. Try not to disturb this gasket as you remove the joystick.
  36. Nintendo Switch Lite Screen Replacement, Remove the left speaker module: 步骤 36 中的图像 1,2 Nintendo Switch Lite Screen Replacement, Remove the left speaker module: 步骤 36 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers or your fingers to pull the left speaker cable straight up and out of its socket on the daughterboard.
    • Do not pull from the wires, or else you risk ripping the wires off the connector.
  37. Nintendo Switch Lite Screen Replacement: 步骤 37 中的图像 1,1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the 4.5 mm screw securing the left speaker module.
  38. Nintendo Switch Lite Screen Replacement: 步骤 38 中的图像 1,3 Nintendo Switch Lite Screen Replacement: 步骤 38 中的图像 2,3 Nintendo Switch Lite Screen Replacement: 步骤 38 中的图像 3,3
    • Use your fingers to lift the speaker module up and out of its recess to remove it.
    • Part of the speaker module sits underneath a delicate ribbon cable. Take care not to snag the speaker module on the cable as you remove it.
  39. Nintendo Switch Lite Screen Replacement, Disconnect the motherboard interconnect cable: 步骤 39 中的图像 1,2 Nintendo Switch Lite Screen Replacement, Disconnect the motherboard interconnect cable: 步骤 39 中的图像 2,2
  40. Nintendo Switch Lite Screen Replacement: 步骤 40 中的图像 1,2 Nintendo Switch Lite Screen Replacement: 步骤 40 中的图像 2,2
    • Use a pair of tweezers to slide the motherboard interconnect cable out of its connector on the daughterboard.
  41. Nintendo Switch Lite Screen Replacement, Disconnect the screen and volume button cables: 步骤 41 中的图像 1,2 Nintendo Switch Lite Screen Replacement, Disconnect the screen and volume button cables: 步骤 41 中的图像 2,2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flaps on the two ribbon cable ZIF connectors.
  42. Nintendo Switch Lite Screen Replacement: 步骤 42 中的图像 1,3 Nintendo Switch Lite Screen Replacement: 步骤 42 中的图像 2,3 Nintendo Switch Lite Screen Replacement: 步骤 42 中的图像 3,3
    • Use a pair of tweezers to slide the daughterboard screen cable out of its connector on the motherboard.
    • Repeat this procedure for the volume buttons cable.
  43. Nintendo Switch Lite Screen Replacement, Remove the volume buttons: 步骤 43 中的图像 1,2 Nintendo Switch Lite Screen Replacement, Remove the volume buttons: 步骤 43 中的图像 2,2
    • Use a pair of tweezers or your fingers to remove the volume buttons.
  44. Nintendo Switch Lite Screen Replacement, Disconnect the joystick cable: 步骤 44 中的图像 1,2 Nintendo Switch Lite Screen Replacement, Disconnect the joystick cable: 步骤 44 中的图像 2,2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the left joystick cable's ZIF connector.
  45. Nintendo Switch Lite Screen Replacement: 步骤 45 中的图像 1,2 Nintendo Switch Lite Screen Replacement: 步骤 45 中的图像 2,2
    • Use a pair of tweezers to slide the left joystick cable out of its connector on the daughterboard.
  46. Nintendo Switch Lite Screen Replacement, Remove the left trigger button assembly: 步骤 46 中的图像 1,1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the two 4.5 mm screws securing the left trigger button assembly.
  47. Nintendo Switch Lite Screen Replacement: 步骤 47 中的图像 1,2 Nintendo Switch Lite Screen Replacement: 步骤 47 中的图像 2,2
    • Remove the left trigger button assembly.
  48. Nintendo Switch Lite Screen Replacement, Remove the daughterboard: 步骤 48 中的图像 1,1
    • Two 4.5 mm screws
    • Two 6 mm screws
  49. Nintendo Switch Lite Screen Replacement: 步骤 49 中的图像 1,2 Nintendo Switch Lite Screen Replacement: 步骤 49 中的图像 2,2
    • Use your fingers to lift the daughterboard up and out of its recess to remove it.
  50. Nintendo Switch Lite Screen Replacement, Remove the left joystick: 步骤 50 中的图像 1,1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the two 3.5 mm screws securing the left joystick.
  51. Nintendo Switch Lite Screen Replacement: 步骤 51 中的图像 1,3 Nintendo Switch Lite Screen Replacement: 步骤 51 中的图像 2,3 Nintendo Switch Lite Screen Replacement: 步骤 51 中的图像 3,3
    • Use the flat end of a spudger to lift the joystick up and out of its recess.
  52. Nintendo Switch Lite Screen Replacement, Unfasten the midframe assembly: 步骤 52 中的图像 1,1
    • Use a JIS 000 driver or an official iFixit PH000 driver to remove the four screws securing the midframe assembly:
    • Three 2.5 mm screws
    • One 6 mm screw
  53. Nintendo Switch Lite Screen Replacement, Remove the midframe assembly: 步骤 53 中的图像 1,3 Nintendo Switch Lite Screen Replacement, Remove the midframe assembly: 步骤 53 中的图像 2,3 Nintendo Switch Lite Screen Replacement, Remove the midframe assembly: 步骤 53 中的图像 3,3
    • Use a spudger to pry the midframe assembly up until you can grip it with your fingers.
    • Grip the midframe assembly and pull up to remove it.
  54. Nintendo Switch Lite Screen Replacement, Remove the remaining buttons: 步骤 54 中的图像 1,2 Nintendo Switch Lite Screen Replacement, Remove the remaining buttons: 步骤 54 中的图像 2,2
    • Remove any remaining buttons that are loose in the frame.
  55. Nintendo Switch Lite Screen Replacement, Heat the left edge: 步骤 55 中的图像 1,1
    • Flip the frame over so the screen is facing up.
    • Heat an iOpener and apply it to the left edge of the screen for two minutes.
    • Alternatively, you can use a hair dryer on the Low heat setting.
    • If you're using a hair dryer, only heat the screen a few seconds at a time or you may warp the plastic shell.
  56. Nintendo Switch Lite Screen Replacement, Insert an opening pick: 步骤 56 中的图像 1,3 Nintendo Switch Lite Screen Replacement, Insert an opening pick: 步骤 56 中的图像 2,3 Nintendo Switch Lite Screen Replacement, Insert an opening pick: 步骤 56 中的图像 3,3
    • Lightly bend the left side of the frame away from the screen to create a gap in the bottom left corner.
    • If you're having difficulty creating a gap, reapply a heated iOpener for two minutes and try again.
    • Insert an opening pick in the gap.
    • Don't insert your pick more than 3 mm to avoid damaging the screen.
  57. Nintendo Switch Lite Screen Replacement, Slice the left adhesive: 步骤 57 中的图像 1,2 Nintendo Switch Lite Screen Replacement, Slice the left adhesive: 步骤 57 中的图像 2,2
    • Throughout this repair, don't insert your pick more than 3 mm to avoid damaging the screen.
    • Slide the opening pick along the left edge.
    • Leave the pick inserted in the top left corner to prevent the adhesive from resealing.
  58. Nintendo Switch Lite Screen Replacement, Heat the top edge: 步骤 58 中的图像 1,1
    • Apply a heated iOpener to the top edge of the screen for two minutes.
    • You can also use a hair dryer, but remember not to heat the screen more than a few seconds at a time.
  59. Nintendo Switch Lite Screen Replacement, Slice the top adhesive: 步骤 59 中的图像 1,2 Nintendo Switch Lite Screen Replacement, Slice the top adhesive: 步骤 59 中的图像 2,2
    • Rotate the opening pick around the top left corner.
  60. Nintendo Switch Lite Screen Replacement: 步骤 60 中的图像 1,2 Nintendo Switch Lite Screen Replacement: 步骤 60 中的图像 2,2
    • Slide the opening pick along the top edge.
    • Leave the opening pick inserted in the top right corner.
  61. Nintendo Switch Lite Screen Replacement, Heat the right edge: 步骤 61 中的图像 1,1
    • Apply a heated iOpener to the right edge of the screen for two minutes.
  62. Nintendo Switch Lite Screen Replacement, Slice the right adhesive: 步骤 62 中的图像 1,2 Nintendo Switch Lite Screen Replacement, Slice the right adhesive: 步骤 62 中的图像 2,2
    • Rotate the opening pick around the top right corner.
  63. Nintendo Switch Lite Screen Replacement: 步骤 63 中的图像 1,2 Nintendo Switch Lite Screen Replacement: 步骤 63 中的图像 2,2
    • Slide the opening pick along the right edge.
    • Leave the opening pick inserted in the bottom right corner.
  64. Nintendo Switch Lite Screen Replacement, Heat the bottom edge: 步骤 64 中的图像 1,1
    • Apply a heated iOpener to the bottom edge of the screen for two minutes.
  65. Nintendo Switch Lite Screen Replacement, Slice the bottom adhesive: 步骤 65 中的图像 1,2 Nintendo Switch Lite Screen Replacement, Slice the bottom adhesive: 步骤 65 中的图像 2,2
    • Rotate the opening pick around the bottom right corner.
  66. Nintendo Switch Lite Screen Replacement: 步骤 66 中的图像 1,2 Nintendo Switch Lite Screen Replacement: 步骤 66 中的图像 2,2
    • Slide the opening pick along the bottom edge.
  67. Nintendo Switch Lite Screen Replacement, Separate the adhesive: 步骤 67 中的图像 1,2 Nintendo Switch Lite Screen Replacement, Separate the adhesive: 步骤 67 中的图像 2,2
    • Grip the frame and push up on the underside of the screen's left edge to separate the adhesive securing it.
  68. Nintendo Switch Lite Screen Replacement, Remove the screen: 步骤 68 中的图像 1,3 Nintendo Switch Lite Screen Replacement, Remove the screen: 步骤 68 中的图像 2,3 Nintendo Switch Lite Screen Replacement, Remove the screen: 步骤 68 中的图像 3,3
    • The digitizer cables prevent the screen from being lifted straight up from the frame.
    • Lift the left side of the screen to a 45-degree angle and remove it.
    • If the screen is still stuck to the frame, slide an opening pick around the perimeter and try again.
    • During reassembly, follow this guide to replace the screen adhesive.
结论
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
22等其他人完成本指南。
Spencer Day
于09/14/22注册
154,988 声望
创作了1,033篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,758篇指南
2指南评论
Thanks for your guide - it was very helpful, first time I took screen off without breaking it off :). I also bought the iFixit kit with the heat pad. I can now see that the trick was not so much a lot of heat, but heat evenly along the whole side
Angelo Felix - 回复
omg you are a lifesaver thank you so much
Adien Richards - 回复
添加评论
浏览统计数据:
过去 24 小时: 79
过去 7 天: 426
过去 30 天: 1,902
总计 54,056
