跳转到主内容
Nintendo Switch Lite Right Joystick Replacement
你所需要的
  1. Nintendo Switch Lite Right Joystick Replacement, Remove the back panel screws: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Before beginning this repair, make sure that the device is completely turned off.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
  2. Nintendo Switch Lite Right Joystick Replacement, Remove the top and bottom back panel screws: 步骤 2 中的图像 1,2 Nintendo Switch Lite Right Joystick Replacement, Remove the top and bottom back panel screws: 步骤 2 中的图像 2,2
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the back panel:
    • Two 3.6 mm-long screws on the top of the device
    • Two 3.6 mm-long screws on the bottom of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
  3. Nintendo Switch Lite Right Joystick Replacement, Release the clips securing the back panel: 步骤 3 中的图像 1,2 Nintendo Switch Lite Right Joystick Replacement, Release the clips securing the back panel: 步骤 3 中的图像 2,2
    • Insert an opening tool into the left speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips securing the back panel.
    • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
  4. Nintendo Switch Lite Right Joystick Replacement, Continue releasing the clips around the device: 步骤 4 中的图像 1,2 Nintendo Switch Lite Right Joystick Replacement, Continue releasing the clips around the device: 步骤 4 中的图像 2,2
    • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
  5. Nintendo Switch Lite Right Joystick Replacement, Twist to release the clips: 步骤 5 中的图像 1,2 Nintendo Switch Lite Right Joystick Replacement, Twist to release the clips: 步骤 5 中的图像 2,2
    • Insert an opening tool into the right speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips.
  6. Nintendo Switch Lite Right Joystick Replacement, Slide and pry around the corners: 步骤 6 中的图像 1,2 Nintendo Switch Lite Right Joystick Replacement, Slide and pry around the corners: 步骤 6 中的图像 2,2
    • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
  7. Nintendo Switch Lite Right Joystick Replacement: 步骤 7 中的图像 1,2 Nintendo Switch Lite Right Joystick Replacement: 步骤 7 中的图像 2,2
    • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
  8. Nintendo Switch Lite Right Joystick Replacement, Remove the back panel: 步骤 8 中的图像 1,3 Nintendo Switch Lite Right Joystick Replacement, Remove the back panel: 步骤 8 中的图像 2,3 Nintendo Switch Lite Right Joystick Replacement, Remove the back panel: 步骤 8 中的图像 3,3
    • Lift the bottom edge of the back panel, opening it like a book.
    • Remove the back panel.
  9. Nintendo Switch Lite Right Joystick Replacement, Remove the shield plate: 步骤 9 中的图像 1,1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following four screws:
    • Three 3.1 mm screws
    • One 4.5 mm screw
  10. Nintendo Switch Lite Right Joystick Replacement: 步骤 10 中的图像 1,3 Nintendo Switch Lite Right Joystick Replacement: 步骤 10 中的图像 2,3 Nintendo Switch Lite Right Joystick Replacement: 步骤 10 中的图像 3,3
    • Use a spudger or your fingers to lift the shield plate up and out of the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • Clean off the old thermal paste from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the heat sink before reassembly.
  11. Nintendo Switch Lite Right Joystick Replacement, Disconnect the battery: 步骤 11 中的图像 1,2 Nintendo Switch Lite Right Joystick Replacement, Disconnect the battery: 步骤 11 中的图像 2,2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
  12. Nintendo Switch Lite Right Joystick Replacement: 步骤 12 中的图像 1,2 Nintendo Switch Lite Right Joystick Replacement: 步骤 12 中的图像 2,2
    • Do Not Use Metal Tweezers! Some fixers state that metallic tweezers can short circuit the ribbon cable/connector. It might be safer to just use nylon-tipped or ceramic-tipped tweezers.
    • Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard.
  13. Nintendo Switch Lite Right Joystick Replacement: 步骤 13 中的图像 1,2 Nintendo Switch Lite Right Joystick Replacement: 步骤 13 中的图像 2,2
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
  14. Nintendo Switch Lite Right Joystick Replacement, Remove the heat sink: 步骤 14 中的图像 1,1
    • Use the flat end of a spudger or your fingers to carefully peel up the foam that's lightly adhered to the fan.
    • The foam only needs to be peeled back enough to clear the fan.
  15. Nintendo Switch Lite Right Joystick Replacement: 步骤 15 中的图像 1,1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
  16. Nintendo Switch Lite Right Joystick Replacement: 步骤 16 中的图像 1,3 Nintendo Switch Lite Right Joystick Replacement: 步骤 16 中的图像 2,3 Nintendo Switch Lite Right Joystick Replacement: 步骤 16 中的图像 3,3
    • Use a spudger or your fingers to lift the heatsink up and off of the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
  17. Nintendo Switch Lite Right Joystick Replacement, Remove the game card reader and headphone jack: 步骤 17 中的图像 1,2 Nintendo Switch Lite Right Joystick Replacement, Remove the game card reader and headphone jack: 步骤 17 中的图像 2,2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the game card reader cable's ZIF connector.
  18. Nintendo Switch Lite Right Joystick Replacement: 步骤 18 中的图像 1,1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the seven 3.1 mm screws securing the game card reader and headphone jack.
  19. Nintendo Switch Lite Right Joystick Replacement: 步骤 19 中的图像 1,3 Nintendo Switch Lite Right Joystick Replacement: 步骤 19 中的图像 2,3 Nintendo Switch Lite Right Joystick Replacement: 步骤 19 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers or your fingers to carefully lift the game card reader and maneuver it to the left to slide the cable out of its connector.
    • Remove the game card reader and headphone jack.
  20. Nintendo Switch Lite Right Joystick Replacement, Remove the right trigger button assembly: 步骤 20 中的图像 1,1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the two 4.5 mm screws securing the right trigger button assembly to the motherboard.
  21. Nintendo Switch Lite Right Joystick Replacement: 步骤 21 中的图像 1,2 Nintendo Switch Lite Right Joystick Replacement: 步骤 21 中的图像 2,2
    • Remove the right trigger button assembly.
  22. Nintendo Switch Lite Right Joystick Replacement: 步骤 22 中的图像 1,2 Nintendo Switch Lite Right Joystick Replacement: 步骤 22 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers or your fingers to remove the right trigger button assembly's rubber pad if it didn't stay attached to the button assembly.
  23. Nintendo Switch Lite Right Joystick Replacement, Disconnect the antenna cables: 步骤 23 中的图像 1,3 Nintendo Switch Lite Right Joystick Replacement, Disconnect the antenna cables: 步骤 23 中的图像 2,3 Nintendo Switch Lite Right Joystick Replacement, Disconnect the antenna cables: 步骤 23 中的图像 3,3
    • Use the point of a spudger to pry the black antenna cable straight up out of its socket on the motherboard.
    • Repeat the same process for the white antenna cable.
  24. Nintendo Switch Lite Right Joystick Replacement, Disconnect the fan cable: 步骤 24 中的图像 1,1
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
  25. Nintendo Switch Lite Right Joystick Replacement: 步骤 25 中的图像 1,2 Nintendo Switch Lite Right Joystick Replacement: 步骤 25 中的图像 2,2
    • Use a pair of tweezers to slide out the fan cable from its connector on the motherboard.
  26. Nintendo Switch Lite Right Joystick Replacement, Disconnect the screen cable: 步骤 26 中的图像 1,2 Nintendo Switch Lite Right Joystick Replacement, Disconnect the screen cable: 步骤 26 中的图像 2,2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the screen cable's ZIF connector.
  27. Nintendo Switch Lite Right Joystick Replacement: 步骤 27 中的图像 1,2 Nintendo Switch Lite Right Joystick Replacement: 步骤 27 中的图像 2,2
    • Use a pair of tweezers to slide the screen cable out of its connector on the motherboard.
  28. Nintendo Switch Lite Right Joystick Replacement, Disconnect the digitizer cable: 步骤 28 中的图像 1,2 Nintendo Switch Lite Right Joystick Replacement, Disconnect the digitizer cable: 步骤 28 中的图像 2,2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
  29. Nintendo Switch Lite Right Joystick Replacement: 步骤 29 中的图像 1,2 Nintendo Switch Lite Right Joystick Replacement: 步骤 29 中的图像 2,2
    • Use a pair of tweezers to slide the digitizer cable out of its connector on the motherboard.
  30. Nintendo Switch Lite Right Joystick Replacement, Disconnect the right joystick cable: 步骤 30 中的图像 1,2 Nintendo Switch Lite Right Joystick Replacement, Disconnect the right joystick cable: 步骤 30 中的图像 2,2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the right joystick cable's ZIF connector.
  31. Nintendo Switch Lite Right Joystick Replacement: 步骤 31 中的图像 1,2 Nintendo Switch Lite Right Joystick Replacement: 步骤 31 中的图像 2,2
    • Use a pair of tweezers to slide the right joystick cable out of its connector on the motherboard.
  32. Nintendo Switch Lite Right Joystick Replacement, Remove the motherboard assembly: 步骤 32 中的图像 1,1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following six screws securing the motherboard:
    • Three 4.5 mm screws
  33. Nintendo Switch Lite Right Joystick Replacement: 步骤 33 中的图像 1,3 Nintendo Switch Lite Right Joystick Replacement: 步骤 33 中的图像 2,3 Nintendo Switch Lite Right Joystick Replacement: 步骤 33 中的图像 3,3
    • Insert a spudger in the gap between the frame and the motherboard and lift the motherboard up and out of its recess.
    • Remove the motherboard assembly.
  34. Nintendo Switch Lite Right Joystick Replacement, Remove the right joystick: 步骤 34 中的图像 1,1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the two 3.5 mm screws securing the joystick.
  35. Nintendo Switch Lite Right Joystick Replacement: 步骤 35 中的图像 1,2 Nintendo Switch Lite Right Joystick Replacement: 步骤 35 中的图像 2,2
    • Use your fingers to remove the joystick.
    • There is a thin black gasket around the hole where the joystick pokes through the frame. Try not to disturb this gasket as you remove the joystick.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
73等其他人完成本指南。
Craig Lloyd
于02/10/16注册
38,614 声望
创作了82篇指南
27条评论
Not for the faint of heart and will take much longer than the indicated time. In the end bring it to a professional, as the battery does NOT come off as indicated. I now have an even more expensive repair as the battery socket came off the motherboard.
Craig Osman - 回复
This is for a joy stick repair...
No Name -
This looked a bit daunting at first, but as you start going you get into a flow and as long as you follow the instructions slowly and carefully you shouldnt have a problem. I would say i finished in the recommended time.
Dom Swooz - 回复
Great guide - completed with no issues easily within the recommended time.
Abelard Snazz - 回复
I did not need to take out the heat sink. It’s a bit difficult. I used this guide and another to replace both buttons.
henreeg - 回复
添加评论
浏览统计数据:
过去 24 小时: 61
过去 7 天: 435
过去 30 天: 2,023
总计 99,453
