跳转到主内容
加入维修社区 - 创建账户
Nintendo GameCube Controller Rumble Motor Replacement
你所需要的
    1. Nintendo GameCube Controller Rumble Motor Replacement, Back Panel: 步骤 1 中的图像 1,1
      • Place the controller (buttons down) on a solid surface.
      • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
      询问修复机器人
      添加评论
    2. Nintendo GameCube Controller Rumble Motor Replacement: 步骤 2 中的图像 1,1
      • Gently lift the back panel up, separating it from the front panel.
      • Some of the buttons may fall out if they are knocked around.
      添加评论
    1. Nintendo GameCube Controller Rumble Motor Replacement, Z Button: 步骤 3 中的图像 1,2 Nintendo GameCube Controller Rumble Motor Replacement, Z Button: 步骤 3 中的图像 2,2
      • Grab the Z-button by the peg with tweezers and lift it out of the controller.
      • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
      添加评论
    1. Nintendo GameCube Controller Rumble Motor Replacement, Circuit Board: 步骤 4 中的图像 1,1
      • Carefully unhook the cable that is looped around the peg.
      添加评论
    2. Nintendo GameCube Controller Rumble Motor Replacement: 步骤 5 中的图像 1,1
      • Lift the circuit board out of the controller.
      • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
      询问修复机器人
      添加评论
    1. Nintendo GameCube Controller Rumble Motor Replacement, Rumble Motor: 步骤 6 中的图像 1,2 Nintendo GameCube Controller Rumble Motor Replacement, Rumble Motor: 步骤 6 中的图像 2,2
      • Press the tip of the soldering iron against one of the leads and wait until solder is viscous. Carefully pull wire away from lead.
      • Repeat for the second lead and wire.
      • During reassembly, solder the white wire to (+) lead on the right side, and the black wire to the (-) lead on the left side.
      • For more information, please refer to this soldering guide.
      询问修复机器人
      添加评论
    2. Nintendo GameCube Controller Rumble Motor Replacement: 步骤 7 中的图像 1,1
      在这个步骤中使用的工具:
      • Using tweezers, unhook the wires from the small black bracket keeping them attached to the circuit board.
      询问修复机器人
      添加评论
    3. Nintendo GameCube Controller Rumble Motor Replacement: 步骤 8 中的图像 1,1
      • Lift the motor out of the bracket.
      • Remember to not pull by the wires! This can make your repair a lot more complicated.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Sean Michel
于01/14/13注册
2,750 声望
创作了8篇指南
团队
Cal Poly, Team 19-44, Regan Winter 2013 Cal Poly, Team 19-44, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G44
4 名成员
创作了99篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 39
过去 30 天: 168
总计 18,033
