跳转到主内容
加入维修社区 - 创建账户
Nintendo 3DS 2015 Motherboard Replacement
你所需要的
  1. Nintendo 3DS 2015 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Unscrew the two 3mm Phillips #1 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
    询问修复机器人
  2. Nintendo 3DS 2015 Motherboard Replacement: 步骤 2 中的图像 1,2 Nintendo 3DS 2015 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
    询问修复机器人
  3. Nintendo 3DS 2015 Motherboard Replacement: 步骤 3 中的图像 1,3 Nintendo 3DS 2015 Motherboard Replacement: 步骤 3 中的图像 2,3 Nintendo 3DS 2015 Motherboard Replacement: 步骤 3 中的图像 3,3
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
    询问修复机器人
  4. Nintendo 3DS 2015 Motherboard Replacement, SD Card Reader: 步骤 4 中的图像 1,1
    • Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
    • The bottom of the SD card reader should slightly pop out after removing the screws.
  5. Nintendo 3DS 2015 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
    • Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
    • Reorient the device so that the power jack faces you.
    询问修复机器人
  6. Nintendo 3DS 2015 Motherboard Replacement: 步骤 6 中的图像 1,2 Nintendo 3DS 2015 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Lift the SD card reader gently.
    • Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
    • Lift the SD card reader out off of the lower casing.
  7. Nintendo 3DS 2015 Motherboard Replacement, Lower Case: 步骤 7 中的图像 1,3 Nintendo 3DS 2015 Motherboard Replacement, Lower Case: 步骤 7 中的图像 2,3 Nintendo 3DS 2015 Motherboard Replacement, Lower Case: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    • Reorient the device so that the game slot now faces you.
    • Remove the two rubber bumpers along the top of the device using tweezers.
    • Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
    询问修复机器人
  8. Nintendo 3DS 2015 Motherboard Replacement: 步骤 8 中的图像 1,2 Nintendo 3DS 2015 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Lift the top edge of the lower case slightly off on the 3DS.
    • Don't pull the lower casing completely off, you may break those connections. There are ribbon cables that must be disconnected first.
    • Pry the ribbon cable socket under the right trigger using a plastic opening tool.
    • Pry the ribbon cable socket under the infrared receiver cover using a plastic opening tool.
    询问修复机器人
  9. Nintendo 3DS 2015 Motherboard Replacement: 步骤 9 中的图像 1,3 Nintendo 3DS 2015 Motherboard Replacement: 步骤 9 中的图像 2,3 Nintendo 3DS 2015 Motherboard Replacement: 步骤 9 中的图像 3,3
    • Open the device slowly from its top edge. Be careful not to tug the ribbon cable connected near the bottom edge of the device.
    • Pry the last ribbon cable attached to the lower case using a plastic opening tool.
    询问修复机器人
  10. Nintendo 3DS 2015 Motherboard Replacement, Circle Pad: 步骤 10 中的图像 1,3 Nintendo 3DS 2015 Motherboard Replacement, Circle Pad: 步骤 10 中的图像 2,3 Nintendo 3DS 2015 Motherboard Replacement, Circle Pad: 步骤 10 中的图像 3,3
    • Locate the joystick assembly near the top right corner of the motherboard.
    • Remove the two 8mm Phillips #00 screws from the back of the joystick.
    • Use the flat end of the spudger to pry off the joystick pad from its plastic housing.
    询问修复机器人
  11. Nintendo 3DS 2015 Motherboard Replacement: 步骤 11 中的图像 1,2 Nintendo 3DS 2015 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Lift the joystick pad and place it on its back. This will reveal the ribbon cable connected to the joystick pad.
    • Use the flat end of the spudger to pry up the retaining flap for the ribbon cable.
    • Lift the joystick out of the device.
    询问修复机器人
  12. Nintendo 3DS 2015 Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,3 Nintendo 3DS 2015 Motherboard Replacement, Motherboard: 步骤 12 中的图像 2,3 Nintendo 3DS 2015 Motherboard Replacement, Motherboard: 步骤 12 中的图像 3,3
    • Remove the power cable, indicated by the black and red wires, by gently pulling it up and out of the connector.
    • Gently pull the ribbon cables out of the 4 ZIF connectors.
    • Do not lift up on the tabs on these ZIF connectors. Lifting these tabs will break the connectors.
  13. Nintendo 3DS 2015 Motherboard Replacement: 步骤 13 中的图像 1,2 Nintendo 3DS 2015 Motherboard Replacement: 步骤 13 中的图像 2,2
    在这个步骤中使用的工具:
    • Pull up gently on the blue wifi antenna.
    • Pry the retaining tab on the connector behind the infrared receiver and gently pull the ribbon cable from the connector with tweezers.
    询问修复机器人
  14. Nintendo 3DS 2015 Motherboard Replacement: 步骤 14 中的图像 1,3 Nintendo 3DS 2015 Motherboard Replacement: 步骤 14 中的图像 2,3 Nintendo 3DS 2015 Motherboard Replacement: 步骤 14 中的图像 3,3
    • Lift the retaining tab and remove the large ribbon cable on the left side of the motherboard.
    • Lift the retaining tab and remove the large ribbon cable on the top of the motherboard behind the infrared receiver.
    • Lift the retaining tab and remove the large ribbon cable on the top of the motherboard just above the joysitck housing.
    询问修复机器人
  15. Nintendo 3DS 2015 Motherboard Replacement: 步骤 15 中的图像 1,3 Nintendo 3DS 2015 Motherboard Replacement: 步骤 15 中的图像 2,3 Nintendo 3DS 2015 Motherboard Replacement: 步骤 15 中的图像 3,3
    • Double check that all motherboard connection on the top of the board have been disconnected.
    • Remove the three, 3mm Phillips #00 screws that secure the motherboard to the device housing.
    • Lift the motherboard gently by the headphone jack.
    • Remove the two ribbons on the back of the device by lifting the retaining tabs on the ZIF connectors.
结论
6等其他人完成本指南。
Tyler Starr
于10/06/16注册
1,772 声望
创作了7篇指南
团队
Cal Poly, Team 4-6, Livingston Fall 2016 Cal Poly, Team 4-6, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S4G6
4 名成员
创作了45篇指南
1指南评论
Step #15 is incorrect. There are only two motherboard screws. The third screw circled, the right side of the console, is a passthrough for the rear housing screws.
Killy728 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 56
过去 30 天: 363
总计 14,578
