跳转到主内容
Nintendo 3DS 2015 Lower Case Replacement
Ahmed Gouda
Ahmed Gouda4 其他贡献者
最后更新于 May 20, 2024
10分钟
中等
If your lower casing is broken you may need to replace it. Be careful to disconnect ribbon cables between the lower casing and the motherboard before removing the lower casing fully.
你所需要的
工具
查看更多...
  1. Nintendo 3DS 2015 Lower Case Replacement, Battery: 步骤 1 中的图像 1,1
    • Unscrew the two 3mm Phillips #1 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
  2. Nintendo 3DS 2015 Lower Case Replacement: 步骤 2 中的图像 1,2 Nintendo 3DS 2015 Lower Case Replacement: 步骤 2 中的图像 2,2
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
  3. Nintendo 3DS 2015 Lower Case Replacement: 步骤 3 中的图像 1,3 Nintendo 3DS 2015 Lower Case Replacement: 步骤 3 中的图像 2,3 Nintendo 3DS 2015 Lower Case Replacement: 步骤 3 中的图像 3,3
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
  4. Nintendo 3DS 2015 Lower Case Replacement, SD Card Reader: 步骤 4 中的图像 1,1
    • Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
    • The bottom of the SD card reader should slightly pop out after removing the screws.
  5. Nintendo 3DS 2015 Lower Case Replacement: 步骤 5 中的图像 1,1
    • Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
    • Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
    • Reorient the device so that the power jack faces you.
  6. Nintendo 3DS 2015 Lower Case Replacement: 步骤 6 中的图像 1,2 Nintendo 3DS 2015 Lower Case Replacement: 步骤 6 中的图像 2,2
    • Lift the SD card reader gently.
    • Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
    • Lift the SD card reader out off of the lower casing.
  7. Nintendo 3DS 2015 Lower Case Replacement, Lower Case: 步骤 7 中的图像 1,3 Nintendo 3DS 2015 Lower Case Replacement, Lower Case: 步骤 7 中的图像 2,3 Nintendo 3DS 2015 Lower Case Replacement, Lower Case: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    • Reorient the device so that the game slot now faces you.
    • Remove the two rubber bumpers along the top of the device using tweezers.
    • Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
  8. Nintendo 3DS 2015 Lower Case Replacement: 步骤 8 中的图像 1,2 Nintendo 3DS 2015 Lower Case Replacement: 步骤 8 中的图像 2,2
    • Lift the top edge of the lower case slightly off on the 3DS.
    • Don't pull the lower casing completely off, you may break those connections. There are ribbon cables that must be disconnected first.
    • Pry the ribbon cable socket under the right trigger using a plastic opening tool.
    • Pry the ribbon cable socket under the infrared receiver cover using a plastic opening tool.
  9. Nintendo 3DS 2015 Lower Case Replacement: 步骤 9 中的图像 1,3 Nintendo 3DS 2015 Lower Case Replacement: 步骤 9 中的图像 2,3 Nintendo 3DS 2015 Lower Case Replacement: 步骤 9 中的图像 3,3
    • Open the device slowly from its top edge. Be careful not to tug the ribbon cable connected near the bottom edge of the device.
    • Pry the last ribbon cable attached to the lower case using a plastic opening tool.
结论
另外一个人完成了本指南。
Ahmed Gouda
于10/06/16注册
291 声望
撰写一个指南
团队
Cal Poly, Team 4-6, Livingston Fall 2016 Cal Poly, Team 4-6, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S4G6
4 名成员
创作了35篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 38
过去 30 天: 119
总计 3,813
