跳转到主内容
加入维修社区 - 创建账户
Nikon D7000 Mirror Box & Viewfinder Replacement
你所需要的
    1. Nikon D7000 Mirror Box & Viewfinder Replacement, Motherboard: 步骤 1 中的图像 1,1
      • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
      • Remove the following 5 screws securing the bottom cover to the camera body:
      • Four 6 mm J000 screws.
      • One 8 mm J000 screw (under lens mount).
      添加评论
    2. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 2 中的图像 1,1
      • Remove three 6 mm J000 screws from under the battery cover.
      添加评论
    3. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 3 中的图像 1,2 Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 3 中的图像 2,2
      • Gently pull the bottom cover off of the camera body.
      添加评论
    4. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 4 中的图像 1,1
      • Remove the following screws from the port area:
      • Two 3.5 mm J000 screws.
      • One 6 mm J000 screw (right above ports).
      添加评论
    5. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 5 中的图像 1,1
      在这个步骤中使用的工具:
      • Peel the rear rubber piece off with tweezers.
      添加评论
    6. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 6 中的图像 1,1
      • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
      添加评论
    7. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 7 中的图像 1,1
      • Pull the eyepiece cover up to remove it.
      询问修复机器人
      添加评论
    8. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 8 中的图像 1,1
      • Remove two 6 mm J000 screws from behind the eyepiece cover.
      • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
      添加评论
    9. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 9 中的图像 1,1
      • Open the SD card cover by pushing slightly down with your thumb and sliding up.
      询问修复机器人
      添加评论
    10. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 10 中的图像 1,1
      • Remove four 6 mm J000 screws that secure the SD card cover.
      添加评论
    11. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 11 中的图像 1,1
      • Gently pull the SD card cover off.
      添加评论
    12. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 12 中的图像 1,1
      • Remove the following screws that secure the back case:
      • One 6 mm J000 screw.
      • One 3 mm J000 screw.
      添加评论
    13. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 13 中的图像 1,1
      • Carefully lift the back case off.
      询问修复机器人
      添加评论
    14. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 14 中的图像 1,3 Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 14 中的图像 2,3 Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 14 中的图像 3,3
      • Disconnect the following two ribbon cables from the motherboard.
      • See our Cable Connector Guide for help with ribbon cable connectors!
      添加评论
    15. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 15 中的图像 1,2 Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 15 中的图像 2,2
      • Remove the following screws securing the left motherboard shield:
      • One 2 mm J000 screw (on the bottom).
      • One 3.5 mm J000 screw (on the back).
      • Be careful of the grounding clips on the motherboard.
      询问修复机器人
      添加评论
    16. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 16 中的图像 1,1
      • Gently pry and lift the left motherboard shield off.
      添加评论
    17. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 17 中的图像 1,1
      • Remove one 3.5 mm J000 screw securing the right motherboard shield.
      添加评论
    18. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 18 中的图像 1,1
      • Gently lift the right motherboard shield off with the tip of a spudger.
      询问修复机器人
      添加评论
    19. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 19 中的图像 1,3 Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 19 中的图像 2,3 Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 19 中的图像 3,3
      • Disconnect remaining ribbon cables.
      添加评论
    20. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 20 中的图像 1,2 Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 20 中的图像 2,2
      添加评论
    21. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 21 中的图像 1,1
      • Carefully disconnect the red connector with tweezers.
      询问修复机器人
      添加评论
    22. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 22 中的图像 1,1
      • Remove four 3.5 mm J000 screws securing the motherboard.
      询问修复机器人
      添加评论
    23. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 23 中的图像 1,1
      • Gently pull the port side cover away from the motherboard.
      询问修复机器人
      添加评论
    24. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 24 中的图像 1,1
      • Lift the motherboard off.
      询问修复机器人
      添加评论
    1. Nikon D7000 Mirror Box & Viewfinder Replacement, Tripod Plate: 步骤 25 中的图像 1,1
      • Remove four 6 mm J000 screws securing the tripod plate.
      添加评论
    2. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 26 中的图像 1,1
      • Carefully lift the tripod plate from the backside of the camera and slide out the grounding clip from under the lens mount.
      添加评论
    1. Nikon D7000 Mirror Box & Viewfinder Replacement, Image Sensor: 步骤 27 中的图像 1,2 Nikon D7000 Mirror Box & Viewfinder Replacement, Image Sensor: 步骤 27 中的图像 2,2
      • Disconnect black and white speaker cable.
      询问修复机器人
      添加评论
    2. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 28 中的图像 1,1
      • Remove three 6 mm J000 screws securing the image sensor.
      添加评论
    3. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 29 中的图像 1,1
      • Carefully lift the image sensor plate out of the camera.
      询问修复机器人
      添加评论
    1. Nikon D7000 Mirror Box & Viewfinder Replacement, Shutter Assembly: 步骤 30 中的图像 1,1
      • Manually pop up flash by inserting a screw driver to the left of the viewfinder and pressing on the metal lever.
      • It won't take much pressure. Press carefully and the flash will pop up when you find the right spot.
      询问修复机器人
      添加评论
    2. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 31 中的图像 1,1
      • Remove two 5 mm J000 screws from under the flash.
      添加评论
    3. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 32 中的图像 1,1
      • Remove two 3 mm J000 screws securing the front cover.
      添加评论
    4. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 33 中的图像 1,2 Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 33 中的图像 2,2
      • Remove the front cover.
      询问修复机器人
      添加评论
    5. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 34 中的图像 1,1
      • Carefully remove the port cover.
      询问修复机器人
      添加评论
    6. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 35 中的图像 1,1
      • Deroute the microphone cable.
      询问修复机器人
      添加评论
    7. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 36 中的图像 1,1
      • Remove one 4 mm J000 screw from the front.
      询问修复机器人
      添加评论
    8. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 37 中的图像 1,1
      • Remove one 8.5 mm J000 screw from the battery compartment.
      询问修复机器人
      添加评论
    9. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 38 中的图像 1,1
      • Remove the grip carefully.
      询问修复机器人
      添加评论
    10. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 39 中的图像 1,1
      • Remove one 4 mm J000 screw securing the top case (under right strap hook).
      询问修复机器人
      添加评论
    11. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 40 中的图像 1,1
      • Remove one 4 mm J000 screw securing the top case (under left strap hook).
      询问修复机器人
      添加评论
    12. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 41 中的图像 1,1
      • Remove the sticker covering the diopter adjust screw.
      询问修复机器人
      添加评论
    13. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 42 中的图像 1,1
      • Remove one 8.0 mm J000 screw.
      • Remove the Diopeter Adjust.
      询问修复机器人
      添加评论
    14. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 43 中的图像 1,1
      • Remove the top case.
      添加评论
    15. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 44 中的图像 1,1
      • Remove the Black, Yellow, Green cable from the top case board.
      添加评论
    16. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 45 中的图像 1,3 Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 45 中的图像 2,3 Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 45 中的图像 3,3
      • Remove two 6.5 mm J000 screws securing the viewfinder.
      • Remove the viewfinder cover.
      添加评论
    17. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 46 中的图像 1,1
      • Remove one 3 mm J000 screw from the bottom left side of the camera.
      添加评论
    18. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 47 中的图像 1,1
      • Remove two 6 mm J000 screws from the left of the shutter.
      添加评论
    19. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 48 中的图像 1,1
      • Remove two 6.5 mm J000 screws from beneath the lens mount.
      询问修复机器人
      添加评论
    20. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 49 中的图像 1,1
      • Remove two screws from just below and to the sides of the viewfinder.
      询问修复机器人
      添加评论
    21. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 50 中的图像 1,1
      • Remove one 5 mm J000 screw from the top right of the camera.
      询问修复机器人
      添加评论
    22. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 51 中的图像 1,1
      • Carefully peel back ribbon cable on the bottom left of camera.
      询问修复机器人
      添加评论
    23. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 52 中的图像 1,2 Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 52 中的图像 2,2
      • Remove the left front ribbon cable from top right of circuit board.
      添加评论
    24. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 53 中的图像 1,1
      • Remove all three wire connectors.
      询问修复机器人
      添加评论
    25. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 54 中的图像 1,1
      • Separate the shutter assembly from the camera body.
      添加评论
    1. Nikon D7000 Mirror Box & Viewfinder Replacement, Mirror Box & Viewfinder: 步骤 55 中的图像 1,1
      • Pull out ribbon cable from circuit asembly near front left of device.
      添加评论
    2. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 56 中的图像 1,1
      • Desolder red & black power leads.
      • Check out our soldering guide for help!
      添加评论
    3. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 57 中的图像 1,1
      • Disconnect ribbon cable at the top right of camera.
      添加评论
    4. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 58 中的图像 1,1
      • Disconnect ribbon cable at top right of camera.
      询问修复机器人
      添加评论
    5. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 59 中的图像 1,1
      • Disconnected ribbon cable at rear right of viewfinder.
      询问修复机器人
      添加评论
    6. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 60 中的图像 1,1
      • Remove the two 5.5mm J000 screws
      询问修复机器人
      添加评论
    7. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 61 中的图像 1,1
      • Remove the 5.5 mm J000 screw.
      询问修复机器人
      添加评论
    8. Nikon D7000 Mirror Box & Viewfinder Replacement: 步骤 62 中的图像 1,1
      • Remove the viewfinder from the mirror box assembly.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
团队
Cal Poly, Team 24-6, Lancaster Spring 2015 Cal Poly, Team 24-6, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S24G6
3 名成员
创作了45篇指南
1指南评论
now I know why my camera failed,, the motor overheated
sir francis - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 68
总计 13,856
