跳转到主内容
Nikon Coolpix S51c Lens Replacement
Ryan
Ryan11 其他贡献者
最后更新于 June 15, 2023
20分钟
中等
特色指南
正在学习的学生
If your Nikon Coolpix S51c camera is producing photos that are blurry or show scratches or marks on the photo, the camera lens may be damaged. You can replace the camera lens by following this guide.
Disconnect your camera from its charger before starting this repair. There are delicate ribbons and wires inside the camera, so be careful not to rip them.
你所需要的
工具
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
查看更多...
  1. Nikon Coolpix S51c Lens Replacement, Back Cover: 步骤 1 中的图像 1,2 Nikon Coolpix S51c Lens Replacement, Back Cover: 步骤 1 中的图像 2,2
    • First, use a Phillips #00 screwdriver to remove all five screws that are located at the bottom of the camera.
  2. Nikon Coolpix S51c Lens Replacement: 步骤 2 中的图像 1,1
    • Next, slide the battery door open in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
    • Remove this screw using the Phillips #00 screwdriver.
  3. Nikon Coolpix S51c Lens Replacement: 步骤 3 中的图像 1,1
    • Rotate the camera to find the side panel with the lanyard attachment.
    • Detach the side panel by the lifting bottom corner slightly with the spudger.
  4. Nikon Coolpix S51c Lens Replacement: 步骤 4 中的图像 1,1
    • Lift the back cover.
    • Be careful not to rip the orange cables between the camera and the back cover.
  5. Nikon Coolpix S51c Lens Replacement: 步骤 5 中的图像 1,1
    • With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger.
    • Carefully remove the back cover.
  6. Nikon Coolpix S51c Lens Replacement, Lens: 步骤 6 中的图像 1,3 Nikon Coolpix S51c Lens Replacement, Lens: 步骤 6 中的图像 2,3 Nikon Coolpix S51c Lens Replacement, Lens: 步骤 6 中的图像 3,3
    • Remove the five screws on the metal plate.
    • One of them is in a hole in the corner of the metal plate.
    • Remove the screw at the bottom of the camera.
    • Carefully lift the metal plate from the right side to reveal a ribbon connected to the motherboard.
  7. Nikon Coolpix S51c Lens Replacement: 步骤 7 中的图像 1,2 Nikon Coolpix S51c Lens Replacement: 步骤 7 中的图像 2,2
    • Lift the white flap with the spudger to release the ribbon.
    • Remove the back metal plate.
  8. Nikon Coolpix S51c Lens Replacement: 步骤 8 中的图像 1,3 Nikon Coolpix S51c Lens Replacement: 步骤 8 中的图像 2,3 Nikon Coolpix S51c Lens Replacement: 步骤 8 中的图像 3,3
    • Lift the two ribbons with the spudger to disconnect the lens and pull it out.
结论
另外一个人完成了本指南。
Ryan
于04/12/11注册
155 声望
创作了6篇指南
团队
Cal Poly, Team 18-24, Garner Spring 2011 Cal Poly, Team 18-24, Garner Spring 2011 的会员
CPSU-GARNER-S11S18G24
4 名成员
创作了6篇指南
2指南评论
question: any source for replacement lens block ? can't find any on the internet
Cyrille Dupuydauby - 回复
question: any source for lens block ? I can't find any on the internet
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 36
总计 1,578
