跳转到主内容
Nikon Coolpix S33 Speaker Replacement
Maria Frias
Maria Frias6 其他贡献者
最后更新于 July 24, 2020
30分钟
中等
If the sound in your camera is distorted or there is no sound in videos, the speaker may need to be replaced. This guide will show how to remove the speaker and insert a new one.
你所需要的
工具
查看更多...
  1. Nikon Coolpix S33 Speaker Replacement, Back Cover: 步骤 1 中的图像 1,2 Nikon Coolpix S33 Speaker Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove battery before initiating this step to avoid the possibility of electric shock.
    • Remove all four T5 Torx screws from the exterior of the camera.
    • Remove all three T5 Torx screws located at the bottom of the camera next to the battery compartment.
  2. Nikon Coolpix S33 Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the two screws located above the HDMI and USB logos that are inside the camera's battery compartment using a JIS000 screwdriver.
  3. Nikon Coolpix S33 Speaker Replacement: 步骤 3 中的图像 1,2 Nikon Coolpix S33 Speaker Replacement: 步骤 3 中的图像 2,2
    • Using a plastic opening tool, gently remove the back cover from the camera.
  4. Nikon Coolpix S33 Speaker Replacement, LCD: 步骤 4 中的图像 1,1
    • Be sure to have followed the steps to remove the Back Cover of your camera before beginning to replace the LCD Screen. This guide will cover just the replacement of the LCD Screen.
    • Using a plastic opening tool, pry the LCD screen out of its slot inside of the camera.
  5. Nikon Coolpix S33 Speaker Replacement: 步骤 5 中的图像 1,1
    • Before pulling the LCD Screen out of the camera, you will need to disconnect the ribbon connector that attaches the screen to the camera.
    • Gently pull the ribbon connector out of it's slot. You should be able to remove it without the need of any tools.
  6. Nikon Coolpix S33 Speaker Replacement, Speaker: 步骤 6 中的图像 1,2 Nikon Coolpix S33 Speaker Replacement, Speaker: 步骤 6 中的图像 2,2
    • Remove the screws. Gently pry off the LCD holder using a plastic opening tool.
  7. Nikon Coolpix S33 Speaker Replacement: 步骤 7 中的图像 1,2 Nikon Coolpix S33 Speaker Replacement: 步骤 7 中的图像 2,2
    • After removing the LCD holder, you can begin the process of removing the speaker from the camera.
    • Remove the 15'' Phillips screw using a PH#00 screwdriver.
    • Gently pry off the green flap to get access to the speaker port.
  8. Nikon Coolpix S33 Speaker Replacement: 步骤 8 中的图像 1,1
    • Gently pull out the speaker using the green and white wires.
    • Disconnect these wires from the motherboard.
结论
Maria Frias
于02/18/16注册
564 声望
创作了4篇指南
团队
USF Tampa, Team 16-3, Blackwell Winter 2016 USF Tampa, Team 16-3, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S16G3
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 662
