跳转到主内容
Nikon Coolpix S230 Motherboard Replacement
Chris Helms
Chris Helms5 其他贡献者
最后更新于 May 7, 2024
20分钟
困难
Is your camera no longer working? Did you recently damage your camera, like by dropping it or getting it wet? Your motherboard may be damaged. This guide will show you how to replace it.
你所需要的
工具
查看更多...
  1. Nikon Coolpix S230 Motherboard Replacement, LCD Screen: 步骤 1 中的图像 1,3 Nikon Coolpix S230 Motherboard Replacement, LCD Screen: 步骤 1 中的图像 2,3 Nikon Coolpix S230 Motherboard Replacement, LCD Screen: 步骤 1 中的图像 3,3
    • Ensure the camera is turned off and the battery is removed.
    • Using a Phillips #000 screwdriver, remove the four 2-mm screws from the side of the camera.
    • Remove the two 3-mm screws from the other side of the camera.
    • Finally, remove the three 4-mm screws from the bottom of the camera.
  2. Nikon Coolpix S230 Motherboard Replacement: 步骤 2 中的图像 1,3 Nikon Coolpix S230 Motherboard Replacement: 步骤 2 中的图像 2,3 Nikon Coolpix S230 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Insert the plastic opening tool into the seam where the front and back parts of the case meet on the bottom of the camera, and slide it along the bottom. Continue along the next side to separate the back part of the case.
    • If necessary, continue along the third and fourth sides until the case separates easily.
    • Lift the back off of the case.
  3. Nikon Coolpix S230 Motherboard Replacement: 步骤 3 中的图像 1,2 Nikon Coolpix S230 Motherboard Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Carefully lift the LCD screen to reveal two orange ribbons connecting the screen to the camera.
    • Use tweezers to carefully lift the blue retaining flap holding down the orange ribbon cable. (Flap can be seen open in the second photo)
    • Slowly wiggle the ribbon cable back and forth while pulling away from the zero insertion force (ZIF) connector to disconnect the cable.
  4. Nikon Coolpix S230 Motherboard Replacement: 步骤 4 中的图像 1,2 Nikon Coolpix S230 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Using tweezers, lift the black retaining flap holding down the larger orange ribbon cable.
    • Carefully remove the ribbon cable from the ZIF connector as before.
  5. Nikon Coolpix S230 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Lift the LCD screen away from the camera.
  6. Nikon Coolpix S230 Motherboard Replacement, Button Circuit Board: 步骤 6 中的图像 1,1
    • Lift the button circuit board by gently popping it out of its connector.
  7. Nikon Coolpix S230 Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,1
    • Using a #000 Phillips screwdriver, remove the four 4-mm screws from the metal plate.
  8. Nikon Coolpix S230 Motherboard Replacement: 步骤 8 中的图像 1,2 Nikon Coolpix S230 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Lift the plate from the camera to reveal the motherboard.
    • Once the plate is removed, the metal attachment for the camera strap on the side of the camera will no longer be secured to the device, and should be set aside.
  9. Nikon Coolpix S230 Motherboard Replacement: 步骤 9 中的图像 1,2 Nikon Coolpix S230 Motherboard Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to lift the black retaining flap for the larger ribbon cable connecting the motherboard to the lens.
    • Continue using the tweezers to gently pull the ribbon cable out of the ZIF connector.
  10. Nikon Coolpix S230 Motherboard Replacement: 步骤 10 中的图像 1,2 Nikon Coolpix S230 Motherboard Replacement: 步骤 10 中的图像 2,2
    • Use tweezers to lift the beige retaining flap for the smaller, orange ribbon cable that attaches the motherboard to the lens.
    • Use tweezers to gently pull the orange ribbon cable from the ZIF connector.
  11. Nikon Coolpix S230 Motherboard Replacement: 步骤 11 中的图像 1,2 Nikon Coolpix S230 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Remove the solder using a soldering iron by following the instructions in this guide.
    • Remove the solder connecting the motherboard to the speaker and mic to completely detach the motherboard.
结论
Chris Helms
于01/31/17注册
1 声望
创作了3篇指南
团队
Baylor, Team 3-1, Whitney Spring 2017 Baylor, Team 3-1, Whitney Spring 2017 的会员
BU-WHITNEY-S17S3G1
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 369
