跳转到主内容
Nikon Coolpix S230 Button Circuit Board Replacement
Collin Rapp
Collin Rapp2 其他贡献者
最后更新于 July 21, 2020
10分钟
中等
If the buttons on your Coolpix S230 are not working like they should, the button circuit board may be broken. This guide will show you how to replace the circuit board that connects the buttons to the motherboard.
你所需要的
工具
查看更多...
  1. Nikon Coolpix S230 Button Circuit Board Replacement, LCD Screen: 步骤 1 中的图像 1,3 Nikon Coolpix S230 Button Circuit Board Replacement, LCD Screen: 步骤 1 中的图像 2,3 Nikon Coolpix S230 Button Circuit Board Replacement, LCD Screen: 步骤 1 中的图像 3,3
    • Ensure the camera is turned off and the battery is removed.
    • Using a Phillips #000 screwdriver, remove the four 2-mm screws from the side of the camera.
    • Remove the two 3-mm screws from the other side of the camera.
    • Finally, remove the three 4-mm screws from the bottom of the camera.
  2. Nikon Coolpix S230 Button Circuit Board Replacement: 步骤 2 中的图像 1,3 Nikon Coolpix S230 Button Circuit Board Replacement: 步骤 2 中的图像 2,3 Nikon Coolpix S230 Button Circuit Board Replacement: 步骤 2 中的图像 3,3
    • Insert the plastic opening tool into the seam where the front and back parts of the case meet on the bottom of the camera, and slide it along the bottom. Continue along the next side to separate the back part of the case.
    • If necessary, continue along the third and fourth sides until the case separates easily.
    • Lift the back off of the case.
  3. Nikon Coolpix S230 Button Circuit Board Replacement: 步骤 3 中的图像 1,2 Nikon Coolpix S230 Button Circuit Board Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Carefully lift the LCD screen to reveal two orange ribbons connecting the screen to the camera.
    • Use tweezers to carefully lift the blue retaining flap holding down the orange ribbon cable. (Flap can be seen open in the second photo)
    • Slowly wiggle the ribbon cable back and forth while pulling away from the zero insertion force (ZIF) connector to disconnect the cable.
  4. Nikon Coolpix S230 Button Circuit Board Replacement: 步骤 4 中的图像 1,2 Nikon Coolpix S230 Button Circuit Board Replacement: 步骤 4 中的图像 2,2
    • Using tweezers, lift the black retaining flap holding down the larger orange ribbon cable.
    • Carefully remove the ribbon cable from the ZIF connector as before.
  5. Nikon Coolpix S230 Button Circuit Board Replacement: 步骤 5 中的图像 1,1
    • Lift the LCD screen away from the camera.
  6. Nikon Coolpix S230 Button Circuit Board Replacement, Button Circuit Board: 步骤 6 中的图像 1,1
    • Lift the button circuit board by gently popping it out of its connector.
结论
Collin Rapp
于02/01/17注册
1 声望
撰写一个指南
团队
Baylor, Team 3-1, Whitney Spring 2017 Baylor, Team 3-1, Whitney Spring 2017 的会员
BU-WHITNEY-S17S3G1
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 370
