跳转到主内容
Nikon Coolpix P100 Viewfinder Replacement
Nghiem Ngo
Nghiem Ngo 另一个贡献者
最后更新于 July 6, 2020
15 - 30 分钟
困难
动态照片拍摄
This will show you how to open up the camera and replace the camera flash.
你所需要的
工具
  1. Nikon Coolpix P100 Viewfinder Replacement, Nikon Coolpix P100  Motherboard Access: 步骤 1 中的图像 1,1
    • Turn the front of the camera toward you.
  2. Nikon Coolpix P100 Viewfinder Replacement: 步骤 2 中的图像 1,3 Nikon Coolpix P100 Viewfinder Replacement: 步骤 2 中的图像 2,3 Nikon Coolpix P100 Viewfinder Replacement: 步骤 2 中的图像 3,3
    • On the left side of the camera, use a Phillips #00 Precision Screwdriver to remove the two marked screws.
  3. Nikon Coolpix P100 Viewfinder Replacement: 步骤 3 中的图像 1,1
    • On the right side of the camera, remove the first visible screw above the HDMI and A/V OUT cover.
  4. Nikon Coolpix P100 Viewfinder Replacement: 步骤 4 中的图像 1,1
    • Lift the HDMI and A/V OUT cover to access the hidden screw between the two ports.
    • Remove the screw
  5. Nikon Coolpix P100 Viewfinder Replacement: 步骤 5 中的图像 1,1
    • Flip the camera upside down and remove the seven marked screws.
  6. Nikon Coolpix P100 Viewfinder Replacement: 步骤 6 中的图像 1,2 Nikon Coolpix P100 Viewfinder Replacement: 步骤 6 中的图像 2,2
    • Turn the back of the camera toward you.
    • Lift the display panel and remove the two marked screws
  7. Nikon Coolpix P100 Viewfinder Replacement: 步骤 7 中的图像 1,3 Nikon Coolpix P100 Viewfinder Replacement: 步骤 7 中的图像 2,3 Nikon Coolpix P100 Viewfinder Replacement: 步骤 7 中的图像 3,3
    • Use a plastic iFixit opening tool to gently loosen the top and sides of the camera.
  8. Nikon Coolpix P100 Viewfinder Replacement: 步骤 8 中的图像 1,1
    • Before fully opening the camera, identify the two marked ribbon cables
    • Properly detach the ribbons before proceeding
  9. Nikon Coolpix P100 Viewfinder Replacement: 步骤 9 中的图像 1,1
    • Carefully open the camera.
    • Now you have partial access to the camera's motherboard.
  10. Nikon Coolpix P100 Viewfinder Replacement: 步骤 10 中的图像 1,1
    • Remove the five indicated screws that are attached to the metal plate.
  11. Nikon Coolpix P100 Viewfinder Replacement: 步骤 11 中的图像 1,1
    • Remove the hidden top screw that is attached to the metal plate.
  12. Nikon Coolpix P100 Viewfinder Replacement: 步骤 12 中的图像 1,1
    • Use a plastic iFixit opening tool to carefully loosen the metal plate.
    • Remove the metal plate to access the camera's motherboard.
  13. Nikon Coolpix P100 Viewfinder Replacement: 步骤 13 中的图像 1,1
    • Now you have access to the camera's motherboard
  14. Nikon Coolpix P100 Viewfinder Replacement, Viewfinder: 步骤 14 中的图像 1,1
    • Remove the screw that is located on the left of the view finder.
  15. Nikon Coolpix P100 Viewfinder Replacement: 步骤 15 中的图像 1,1
    • Carefully detach the two ribbon cables and detach the viewfinder.
结论
3等其他人完成本指南。
Nghiem Ngo
于01/15/15注册
330 声望
创作了2篇指南
团队
USF Tampa, Team 1-1, Tanski Winter 2015 USF Tampa, Team 1-1, Tanski Winter 2015 的会员
USFT-TANSKI-W15S1G1
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 24
总计 1,176
