跳转到主内容
Nikon Coolpix L830 LCD Monitor Replacement
Blake Johnson
Blake Johnson3 其他贡献者
最后更新于 July 3, 2020
20分钟
简单
If the LCD monitor on your Nikon Coolpix L830 is corrupted or completely blank, replacement is necessary. Following these steps will allow you to replace the broken screen with a new one to allow complete monitor functionality to return.
你所需要的
工具
查看更多...
  1. Nikon Coolpix L830 LCD Monitor Replacement, LCD Monitor: 步骤 1 中的图像 1,1
    • Use a Phillips head P000 screwdriver to remove the four 3.0 mm Phillips screws on the back of the monitor.
  2. Nikon Coolpix L830 LCD Monitor Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips head P000 screwdriver to remove the two 3.0 mm Phillips screws on the hinge cover.
  3. Nikon Coolpix L830 LCD Monitor Replacement: 步骤 3 中的图像 1,2 Nikon Coolpix L830 LCD Monitor Replacement: 步骤 3 中的图像 2,2
    • Remove the top hinge cover.
    • The top hinge cover contains screw holes.
    • Remove the bottom hinge cover.
    • The bottom hinge cover contains no screw holes.
  4. Nikon Coolpix L830 LCD Monitor Replacement: 步骤 4 中的图像 1,1
    • Remove the back cover of the LCD monitor with your hands or a plastic opening tool.
    • The cover will slide down the hinge, but it will not be completely removed.
  5. Nikon Coolpix L830 LCD Monitor Replacement: 步骤 5 中的图像 1,2 Nikon Coolpix L830 LCD Monitor Replacement: 步骤 5 中的图像 2,2
    • Use your thumb to gently pull the small flex ribbon wire connector from its socket.
    • Use your thumb to gently pull the wide flex ribbon wire connector from its socket.
  6. Nikon Coolpix L830 LCD Monitor Replacement: 步骤 6 中的图像 1,1
    • Use a plastic opening tool to remove the front cover of the LCD monitor, allowing the monitor to be completely be released.
  7. Nikon Coolpix L830 LCD Monitor Replacement: 步骤 7 中的图像 1,1
    • Gently remove the old, damaged LCD monitor.
结论
另外一个人完成了本指南。
Blake Johnson
于10/28/16注册
347 声望
创作了2篇指南
团队
Baylor, Team 4-4, Williams Fall 2016 Baylor, Team 4-4, Williams Fall 2016 的会员
BU-WILLIAMS-F16S4G4
3 名成员
创作了10篇指南
2指南评论
I cant remove two of the screws. Help
jo Hogan - 回复
Très bien pour démonter , mais pour remonter les nappes, notamment la moins large, je n'arrive pas à l'insérer !
Avez vous une technique à me proposer ?
Michel Cassel - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 27
总计 2,771
