跳转到主内容
Nikon Coolpix L810 Flash Replacement
Emilio Mena
Emilio Mena2 其他贡献者
最后更新于 June 30, 2020
10分钟
中等
Is your flash not lighting up? This guide will show you how to replace the flash from your camera.
你所需要的
工具
查看更多...
  1. Nikon Coolpix L810 Flash Replacement, Flash: 步骤 1 中的图像 1,1
    • Remove two 5 mm Phillips #000 screws below the flash component.
    • In order to complete this step the flash must be open. To open the flash press the button located above the lens on the leftward side of the camera.
  2. Nikon Coolpix L810 Flash Replacement: 步骤 2 中的图像 1,1
    • Use blue plastic opening tool to pry open the casing for the flash.
  3. Nikon Coolpix L810 Flash Replacement: 步骤 3 中的图像 1,1
    • Remove the plastic casing surrounding the flash.
  4. Nikon Coolpix L810 Flash Replacement: 步骤 4 中的图像 1,2 Nikon Coolpix L810 Flash Replacement: 步骤 4 中的图像 2,2
    • Pull the wires connecting the flash out of the camera.
  5. Nikon Coolpix L810 Flash Replacement: 步骤 5 中的图像 1,3 Nikon Coolpix L810 Flash Replacement: 步骤 5 中的图像 2,3 Nikon Coolpix L810 Flash Replacement: 步骤 5 中的图像 3,3
    • Unsolder the wires that connect the flash component.
结论
2等其他人完成本指南。
Emilio Mena
于01/14/15注册
776 声望
创作了4篇指南
团队
UW Tacoma, Team 3-1, Rose Winter 2015 UW Tacoma, Team 3-1, Rose Winter 2015 的会员
UWT-ROSE-W15S3G1
4 名成员
创作了8篇指南
4指南评论
It's not a comment, but where did you obtain the replacement flashbulb?
hgdddee - 回复
the heading says no parts required. but I think i need a new flashbulb? any idea what the type is or where to buy it ?
wildstreaksavannahs - 回复
I can't get into bulb
Szabolcs Demeter - 回复
<a href="https://www.w3schools.com/">Visit W3Schools.com!</a> n advmd vdsm vs ds m
nirik - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 26
总计 2,325
