跳转到主内容
Nikon Coolpix L32 LCD Replacement
Sherika Jacobs
Sherika Jacobs4 其他贡献者
最后更新于 June 26, 2020
15分钟
困难
If the Nikon Coolpix L32 suffered from physical damages and it remains dark after trying to power it on, consider replacing the LCD Screen. No hazards are associated with this replacement.
你所需要的
工具
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
查看更多...
  1. Nikon Coolpix L32 LCD Replacement, Front Panel: 步骤 1 中的图像 1,3 Nikon Coolpix L32 LCD Replacement, Front Panel: 步骤 1 中的图像 2,3 Nikon Coolpix L32 LCD Replacement, Front Panel: 步骤 1 中的图像 3,3
    • Remove the six(3.93mm screws) on the outside of the camera using a Phillips 00 screwdriver.
  2. Nikon Coolpix L32 LCD Replacement: 步骤 2 中的图像 1,1
    • Open the battery compartment door and pull the black back face apart from the front red face.
  3. Nikon Coolpix L32 LCD Replacement, LCD: 步骤 3 中的图像 1,1
    • Using the spudger, gently pull the LCD screen from the tray holding it.
    • Do not pull the LCD screen far from the camera because there is a ribbon cable connected to it.
  4. Nikon Coolpix L32 LCD Replacement: 步骤 4 中的图像 1,1
    • Use the spudger to lift up the small white retaining flap on the motherboard that is connected to the LCD screen's ribbon cable.
  5. Nikon Coolpix L32 LCD Replacement: 步骤 5 中的图像 1,1
    • With the small retaining white flap up, remove the LCD screen ribbon cable from the motherboard by sliding it out.
结论
另外一个人完成了本指南。
Sherika Jacobs
于09/15/16注册
348 声望
创作了3篇指南
团队
USF Tampa, Team 2-4, Blackwell Fall 2016 USF Tampa, Team 2-4, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S2G4
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 893
