跳转到主内容
Nikon Coolpix B700 Internal Bracket Replacement
Carlos Salgado
Carlos Salgado6 其他贡献者
最后更新于 January 5, 2021
没有估计
中等
不正确的工具
缺少细节
To perform most replacements in the Nikon Coolpix B700, the back cover must be removed and the internal metal bracket needs to be released. This is required before replacing the motherboard, lens, button assembly, or other components.
你所需要的
工具
查看更多...
  1. Nikon Coolpix B700 Internal Bracket Replacement, Back Frame Assembly: 步骤 1 中的图像 1,1
    • Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
  2. Nikon Coolpix B700 Internal Bracket Replacement: 步骤 2 中的图像 1,1
    • Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
  3. Nikon Coolpix B700 Internal Bracket Replacement: 步骤 3 中的图像 1,2 Nikon Coolpix B700 Internal Bracket Replacement: 步骤 3 中的图像 2,2
    • Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
    • Open the HDMI flap to remove a 5.5mm screw.
    • Don't forget to replace the hidden screw under the HDMI flap during reassembly.
  4. Nikon Coolpix B700 Internal Bracket Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
  5. Nikon Coolpix B700 Internal Bracket Replacement: 步骤 5 中的图像 1,3 Nikon Coolpix B700 Internal Bracket Replacement: 步骤 5 中的图像 2,3 Nikon Coolpix B700 Internal Bracket Replacement: 步骤 5 中的图像 3,3
    • Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
    • While twisting, pry apart the shell to split the camera in half.
  6. Nikon Coolpix B700 Internal Bracket Replacement: 步骤 6 中的图像 1,1
    • Be careful not to damage the ribbons that connect the halves together.
  7. Nikon Coolpix B700 Internal Bracket Replacement: 步骤 7 中的图像 1,2 Nikon Coolpix B700 Internal Bracket Replacement: 步骤 7 中的图像 2,2
    • Place the pry tool under the black latch. Lift gently until the latch flips up.
    • Gently pull the ribbon away from the latch.
    • Be gentle when taking ribbons out and apart because they are fragile.
  8. Nikon Coolpix B700 Internal Bracket Replacement, Internal Bracket: 步骤 8 中的图像 1,1
    • Use the Phillips screwdriver to remove the remaining five 5.55mm screws.
    • Remove the single 6mm screw.
  9. Nikon Coolpix B700 Internal Bracket Replacement: 步骤 9 中的图像 1,1
    • Insert the pry tool under the latch and gently lift up to remove the ribbon.
  10. Nikon Coolpix B700 Internal Bracket Replacement: 步骤 10 中的图像 1,1
    • Move the ribbon out of the way to reveal the hidden screw.
  11. Nikon Coolpix B700 Internal Bracket Replacement: 步骤 11 中的图像 1,1
    • Lift the button assembly gently to give access to remove the 4mm screw.
  12. Nikon Coolpix B700 Internal Bracket Replacement: 步骤 12 中的图像 1,1
    • On the top of the camera, remove the 6mm screw.
  13. Nikon Coolpix B700 Internal Bracket Replacement: 步骤 13 中的图像 1,2 Nikon Coolpix B700 Internal Bracket Replacement: 步骤 13 中的图像 2,2
    • With the spudger tool gently pry off the white tap holding in the bracket.
    • Use the same tool to remove the glued-on ribbon.
  14. Nikon Coolpix B700 Internal Bracket Replacement: 步骤 14 中的图像 1,2 Nikon Coolpix B700 Internal Bracket Replacement: 步骤 14 中的图像 2,2
    • Gently lift up the button assembly to slide the bracket out.
  15. Nikon Coolpix B700 Internal Bracket Replacement: 步骤 15 中的图像 1,2 Nikon Coolpix B700 Internal Bracket Replacement: 步骤 15 中的图像 2,2
    • With the pry tool gently lift up the latch and pull the cable toward the lens assembly.
    • Use the pry tool again and place it under the ribbon and lift straight up to disconnect the ribbon.
终点
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 337
