简介
This installation guide will help you replace the motherboard of your Nikon Coolpix 4600. Before getting to the motherboard of the camera. You will need to remove the rear and front cases.9084 to follow the steps.
你所需要的
Find the six screws on the exterior of the camera: two 3.3 mm screws on the bottom and two 5.25 mm screws on both the left and right sides.
Using a Phillips 00 screwdriver, remove all of the six screws.
Examine the connection between the ribbon cable and the motherboard closely. Identify the two grey tabs on each side of the connecting bracket.
Slide the grey tabs toward the bottom of the camera to release the ribbon cable. Gently disconnect the ribbon cable from the motherboard.
Once the ribbon cable is disconnected, you can now carefully separate the back case from the front case.
With the lens facing down and the bottom of the camera facing away from you, lift up the right edge of the LCD screen (left side of the screen will be glued down).
Insert plastic tool under the screen and gently pry up the left side of the screen until the glue seal is broken.
Locate and remove the four 4.25 mm screws on the motherboard using a Phillips 00 screw driver.
