跳转到主内容
Nikon CoolPix S600 Lens Assembly Replacement
andreas anggasastra
andreas anggasastra5 其他贡献者
最后更新于 January 6, 2015
30分钟
困难
需要更好的图片
更好的介绍
你所需要的
工具
  1. Nikon CoolPix S600 Lens Assembly Replacement, Front and Rear Casing: 步骤 1 中的图像 1,1
    • With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
  2. Nikon CoolPix S600 Lens Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove the chrome side cover from the body of the camera.
  3. Nikon CoolPix S600 Lens Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the four 3.2 mm screws on the bottom of the camera.
  4. Nikon CoolPix S600 Lens Assembly Replacement: 步骤 4 中的图像 1,2 Nikon CoolPix S600 Lens Assembly Replacement: 步骤 4 中的图像 2,2
    • Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward)
    • Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
  5. Nikon CoolPix S600 Lens Assembly Replacement: 步骤 5 中的图像 1,2 Nikon CoolPix S600 Lens Assembly Replacement: 步骤 5 中的图像 2,2
    • Gently separate the back cover from the body of the camera.
    • The back casing will still be connected to the circuit board by a ribbon
  6. Nikon CoolPix S600 Lens Assembly Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    • Use the tweezers to disconnect the ribbon from the circuit board.
  7. Nikon CoolPix S600 Lens Assembly Replacement: 步骤 7 中的图像 1,1
    • Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
  8. Nikon CoolPix S600 Lens Assembly Replacement: 步骤 8 中的图像 1,2 Nikon CoolPix S600 Lens Assembly Replacement: 步骤 8 中的图像 2,2
    • Gently separate the front cover from the body of the camera.
    • The front casing will still be connected to the circuit board by a few wires
  9. Nikon CoolPix S600 Lens Assembly Replacement: 步骤 9 中的图像 1,1
    • Remove the two 3.2 mm screws that hold the flash to the front cover.
  10. Nikon CoolPix S600 Lens Assembly Replacement: 步骤 10 中的图像 1,3 Nikon CoolPix S600 Lens Assembly Replacement: 步骤 10 中的图像 2,3 Nikon CoolPix S600 Lens Assembly Replacement: 步骤 10 中的图像 3,3
    • Use the Spudger to remove the copper colored light bulb clip.
    • Remove the front cover entierly from the camera body.
  11. Nikon CoolPix S600 Lens Assembly Replacement, Lens Assembly: 步骤 11 中的图像 1,2 Nikon CoolPix S600 Lens Assembly Replacement, Lens Assembly: 步骤 11 中的图像 2,2
    • From the top view of the camera, remove the one 5.8 mm screw.
    • From the top view of the camera, remove the one 2.8 mm screw
  12. Nikon CoolPix S600 Lens Assembly Replacement: 步骤 12 中的图像 1,1
    • Remove the three 3.4 mm screws from the back side of the camera.
  13. Nikon CoolPix S600 Lens Assembly Replacement: 步骤 13 中的图像 1,1
    • Remove the two 3.4 mm screws from the side of the camera.
  14. Nikon CoolPix S600 Lens Assembly Replacement: 步骤 14 中的图像 1,1
    • Separate the two metal body pieces from the rest of the camera.
  15. Nikon CoolPix S600 Lens Assembly Replacement: 步骤 15 中的图像 1,2 Nikon CoolPix S600 Lens Assembly Replacement: 步骤 15 中的图像 2,2
    • Gently remove the two ribbons connecting the lens to the mother board.
  16. Nikon CoolPix S600 Lens Assembly Replacement: 步骤 16 中的图像 1,2 Nikon CoolPix S600 Lens Assembly Replacement: 步骤 16 中的图像 2,2
    • Gently separate the camera lens from the mother board.
结论
2等其他人完成本指南。
团队
Cuesta, Team 1-6, Zipperian Fall 2011 Cuesta, Team 1-6, Zipperian Fall 2011 的会员
CUESTA-ZIPPERIAN-F11S1G6
2 名成员
创作了6篇指南
一条评论
Any place where I could buy a new lens for the camera nowadays?
thesilver - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 19
总计 3,366
