跳转到主内容
Nikon COOLPIX S610c LCD Replacement
你所需要的
  1. Nikon COOLPIX S610c LCD Replacement, Battery: 步骤 1 中的图像 1,1
    • On the bottom right of the camera, locate the battery flap switch.
  2. Nikon COOLPIX S610c LCD Replacement: 步骤 2 中的图像 1,1
    • Move this switch to the right so the battery flap can flip open.
  3. Nikon COOLPIX S610c LCD Replacement: 步骤 3 中的图像 1,1
    • Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
  4. Nikon COOLPIX S610c LCD Replacement, Rear Casing: 步骤 4 中的图像 1,1
    • Remove the three 3x3mm screws attached to the rear casing.
  5. Nikon COOLPIX S610c LCD Replacement: 步骤 5 中的图像 1,1
    • The panel can be identified by the wifi logo on its upper half on the camera's side.
    • Remove the 5x3mm screw holding down the panel on the side closest to the lens.
  6. Nikon COOLPIX S610c LCD Replacement: 步骤 6 中的图像 1,1
    • Pry the panel off from the bottom using your fingernail.
  7. Nikon COOLPIX S610c LCD Replacement: 步骤 7 中的图像 1,1
    • Remove the 3x2mm screw underneath the panel near the top of the camera.
  8. Nikon COOLPIX S610c LCD Replacement: 步骤 8 中的图像 1,2 Nikon COOLPIX S610c LCD Replacement: 步骤 8 中的图像 2,2
    • Remove the 4x3mm on the opposite side near the selector wheel.
    • Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
  9. Nikon COOLPIX S610c LCD Replacement: 步骤 9 中的图像 1,2 Nikon COOLPIX S610c LCD Replacement: 步骤 9 中的图像 2,2
    • Pry the back panel away from the body of the camera, using the space you just opened up.
    • Be careful not to damage the ribbon cable on the opposite end of the camera.
    • A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
  10. Nikon COOLPIX S610c LCD Replacement: 步骤 10 中的图像 1,2 Nikon COOLPIX S610c LCD Replacement: 步骤 10 中的图像 2,2
    • Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
    • The center connector is detached by flipping the black latch up and away from the center of the camera.
    • The smaller connector is detached by flipping the tan latch up and away from the edge of the camera.
  11. Nikon COOLPIX S610c LCD Replacement, LCD: 步骤 11 中的图像 1,2 Nikon COOLPIX S610c LCD Replacement, LCD: 步骤 11 中的图像 2,2
    • Pry the display from the rear casing using a spudger.
结论
Kevin Backers
于01/26/12注册
304 声望
创作了4篇指南
团队
Cal Poly, Team 9-5, Regan Winter 2012 Cal Poly, Team 9-5, Regan Winter 2012 的会员
CPSU-REGAN-W12S9G5
5 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 718
