跳转到主内容
Nikon COOLPIX P2 Case Replacement
Jessica Brough
Jessica Brough11 其他贡献者
最后更新于 July 7, 2020
没有估计
中等
Replace the outer casing of your camera if it is damaged.
你所需要的
工具
查看更多...
  1. Nikon COOLPIX P2 Case Replacement, Case: 步骤 1 中的图像 1,1
    • Remove the screw located near the speaker port using a Phillips 00 screwdriver.
  2. Nikon COOLPIX P2 Case Replacement: 步骤 2 中的图像 1,1
    • Turn camera upside down so that the battery compartment is facing you.
    • Remove all four screws from the bottom of the camera with a Phillips 00 screwdriver.
  3. Nikon COOLPIX P2 Case Replacement: 步骤 3 中的图像 1,1
    • Rotate the camera to the opposite side where the A/V outlet is located.
    • Unscrew and remove all four screws with a Phillips 00 screwdriver.
  4. Nikon COOLPIX P2 Case Replacement: 步骤 4 中的图像 1,1
    • Turn the camera so that the Wi-Fi adapter is facing you.
  5. Nikon COOLPIX P2 Case Replacement: 步骤 5 中的图像 1,3 Nikon COOLPIX P2 Case Replacement: 步骤 5 中的图像 2,3 Nikon COOLPIX P2 Case Replacement: 步骤 5 中的图像 3,3
    • Using a plastic opening tool, pry the front casing of the camera.
    • Continue this motion all around the front casing of the camera.
    • Gently pull apart the front casing from the rest of the camera.
  6. Nikon COOLPIX P2 Case Replacement: 步骤 6 中的图像 1,1
    • Using the plastic opening tool pry the back casing of the camera.
  7. Nikon COOLPIX P2 Case Replacement: 步骤 7 中的图像 1,1
    • Orange ribbon is fragile
    • Carefully pull apart the back casing of the camera from the front of the camera without tearing the orange ribbon.
  8. Nikon COOLPIX P2 Case Replacement: 步骤 8 中的图像 1,2 Nikon COOLPIX P2 Case Replacement: 步骤 8 中的图像 2,2
    • Pull down the on the black latch to carefully separate the orange ribbon from the motherboard.
    • Pull apart the orange ribbon and front casing from the rest of the camera.
结论
Jessica Brough
于01/22/12注册
135 声望
创作了2篇指南
团队
Cal Poly, Team 3-28, Amido Winter 2012 Cal Poly, Team 3-28, Amido Winter 2012 的会员
CPSU-AMIDO-W12S3G28
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 1,185
