跳转到主内容
Motorola Moto G6 Battery Replacement
你所需要的
  1. Motorola Moto G6 Battery Replacement, Remove the Rear Glass: 步骤 1 中的图像 1,1
    • Power your phone off before you begin.
    • If possible, drain the battery before disassembly. When the battery is charged, there's an increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
    • If the rear glass is cracked, completely cover it with packing tape to contain the glass shards and avoid injury.
    • Prepare an iOpener and heat the back of the phone along its bottom edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the rear glass.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    At what temperature shold the glass be heated to? My heat gun goes from 250 up to 1350.
    Miles Raymond - 回复
    START LOW.
    These plastics can be almost endlessly remelted, held at temp, etc., if done gently.
    With a heat gun, I'd hesitate to go too far past 250°F/115°C too quickly until I was comfortable with the material.
    Plastic WILL begin to burn and permanently deteriorate at 350-400°F or so.
    Silicone can handle up to 400-500°F.
    (Get a cast iron pot or pan to roughly 250°F/110°C, then invert and put a silicone cookie sheet on it to make a work surface that will make life waaaaaay easier. Preheat the device along with the pan for a few minutes, too.)
    Filthy Pazuzu - 回复
  2. Motorola Moto G6 Battery Replacement: 步骤 2 中的图像 1,3 Motorola Moto G6 Battery Replacement: 步骤 2 中的图像 2,3 Motorola Moto G6 Battery Replacement: 步骤 2 中的图像 3,3
    • Apply a suction cup to the bottom edge of the rear glass.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the frame.
    • If the glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool.
    • If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
    • Insert an opening pick into the gap you created under the rear glass.
    I'm stuck on this step (literally and figuratively). I've heated it pretty hot and pulled pretty hard on the suction cup, but I can't see a gap…
    Andy Mach - 回复
    I used a piece of laminating plastic instead of the pick and managed to slide it in!
    Andy Mach -
    My back delaminated at this point. That is, the clear plastic started to come away leaving the paint layer behind. Mine is (was) the indigo blue one.
    Neil Hoskins - 回复
  3. Motorola Moto G6 Battery Replacement: 步骤 3 中的图像 1,3 Motorola Moto G6 Battery Replacement: 步骤 3 中的图像 2,3 Motorola Moto G6 Battery Replacement: 步骤 3 中的图像 3,3
    • Slide the pick all along the bottom edge of the phone to slice through the adhesive securing the rear glass.
    • Slow down and slice very carefully as you get to the corners. The curved part of the glass along the left and right edges can crack very easily if the pick pushes up against the curved glass.
    • After being cut, the adhesive will sometimes stick back together as it cools. To prevent this you can leave the pick in this edge after cutting, and continue the next steps with a new pick. Repeat this with each edge, leaving a pick and continuing with a new one.
  4. Motorola Moto G6 Battery Replacement: 步骤 4 中的图像 1,1
    • Heat the right edge of the back of the phone to soften the adhesive underneath.
  5. Motorola Moto G6 Battery Replacement: 步骤 5 中的图像 1,3 Motorola Moto G6 Battery Replacement: 步骤 5 中的图像 2,3 Motorola Moto G6 Battery Replacement: 步骤 5 中的图像 3,3
    • Slide the pick along the right edge of the rear glass to separate the adhesive underneath.
  6. Motorola Moto G6 Battery Replacement: 步骤 6 中的图像 1,1
    • Heat the top edge of the back of the phone to soften the rear glass adhesive.
  7. Motorola Moto G6 Battery Replacement: 步骤 7 中的图像 1,3 Motorola Moto G6 Battery Replacement: 步骤 7 中的图像 2,3 Motorola Moto G6 Battery Replacement: 步骤 7 中的图像 3,3
    • Slide the pick all along the top edge of the phone to slice through the adhesive securing the rear glass.
  8. Motorola Moto G6 Battery Replacement: 步骤 8 中的图像 1,1
    • Heat the left edge of the back of the phone to soften the adhesive underneath.
  9. Motorola Moto G6 Battery Replacement: 步骤 9 中的图像 1,3 Motorola Moto G6 Battery Replacement: 步骤 9 中的图像 2,3 Motorola Moto G6 Battery Replacement: 步骤 9 中的图像 3,3
    • Slide a pick along the left edge of the phone to slice through the rear glass adhesive.
  10. Motorola Moto G6 Battery Replacement: 步骤 10 中的图像 1,2 Motorola Moto G6 Battery Replacement: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $5.99
    购买
    • If the glass remains stuck, re-heat and slice the adhesive repeatedly as needed.
    • Lift the rear glass carefully, making sure it's fully separated from any adhesive.
    • Remove the rear glass.
    • During reassembly, pause here to replace the adhesive on the rear glass using a precut adhesive card or high-strength double-sided adhesive tape, such as Tesa 61395.
    • After closing your device back up during reassembly, stack something heavy, like a textbook or two, on top of the device for 30-60 minutes. This ensures a strong adhesive bond.
    When cleaning old adhesive off the back glass, be careful not to scratch the inner coating of the glass. If you scratch this coating with tweezers, it will leave visible “nicks” on the back glass.
    Sarah Braden - 回复
  11. Motorola Moto G6 Battery Replacement, Remove the Battery Tape: 步骤 11 中的图像 1,2 Motorola Moto G6 Battery Replacement, Remove the Battery Tape: 步骤 11 中的图像 2,2
    • Use a pair of tweezers to carefully peel up the black tape covering the battery.
    • Remove the tape.
    • If possible, keep the tape intact so it can be reused during reassembly.
    On my phone the sticker was covered by another NFC tag that was attached to the board under the cover. I yanked it out, breaking it in the process, but if you peel that sticker off the batter sticker first and leave it attached at the end, you should have more success.
    Stuart - 回复
    Yes, there's the NFC tag that isn't mentioned, with its connection to the left. Thanks for the tip, Stuart; I gently lifted mine to the left and it seems to be intact. I guess I won't know until I try to pay for something.
    Neil Hoskins - 回复
  12. Motorola Moto G6 Battery Replacement, Remove the Plastic Cover: 步骤 12 中的图像 1,1
    • Use a Phillips driver to remove seventeen screws securing the plastic cover:
    • Eleven grey 3 mm-long screws
    • Five black 2.5 mm-long screws
    • One silver 3.5 mm-long screw
    The holes for the black screws are marked with a small triangle to differentiate them from the holes for the gray ones. I found this super helpful when reassembling!
    Jamie Bell - 回复
  13. Motorola Moto G6 Battery Replacement: 步骤 13 中的图像 1,3 Motorola Moto G6 Battery Replacement: 步骤 13 中的图像 2,3 Motorola Moto G6 Battery Replacement: 步骤 13 中的图像 3,3
    • Insert the pointed end of a spudger into the notch at the top left edge of the plastic cover.
    • Pry up with the spudger to lift the upper edge of the cover and release the clips holding the cover down.
    • Remove the plastic cover.
    When reinstalling plastic cover, alignment is critical for underlying contacts to line up. Test all functions before sealing up the phone. If camera or speaker don’t work, recheck plastic cover installation and correct until all phone functions operate.
    Eric Oberer - 回复
  14. Motorola Moto G6 Battery Replacement, Disconnect the Battery: 步骤 14 中的图像 1,2 Motorola Moto G6 Battery Replacement, Disconnect the Battery: 步骤 14 中的图像 2,2
    • Use the pointed end of a spudger to pry up the battery connector and disconnect it.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    What is the black part the battery is connects to called? The black part connected to the body of the phone.
    Slippery Steve - 回复
    Be very careful on this step! If you pry it out too roughly the connector will break. If you aren't very precise when putting the plug back in you will smash either the tiny tabs on the plug or the connector itself.
    rami.slicer - 回复
  15. Motorola Moto G6 Battery Replacement, Soften the Battery Adhesive: 步骤 15 中的图像 1,1
    • Prepare an iOpener and apply it to the right half of the screen for at least two minutes, in order to soften the battery adhesive underneath. Reheat and reapply the iOpener as needed.
    • Be careful not to overheat the battery or display with the iOpener. If you notice the battery swelling at all, immediately remove any heat and let the battery cool down.
    • Alternatively, apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
  16. Motorola Moto G6 Battery Replacement, Remove the Battery: 步骤 16 中的图像 1,3 Motorola Moto G6 Battery Replacement, Remove the Battery: 步骤 16 中的图像 2,3 Motorola Moto G6 Battery Replacement, Remove the Battery: 步骤 16 中的图像 3,3
    • Use an opening pick to steadily pry the battery up, starting from the outer edge of the battery.
    • You may need to reheat and reapply the iOpener repeatedly to further soften the adhesive. The adhesive is tough and it may take a few tries to get the pick started under the battery. If the battery begins bend out of shape, apply more heat or isopropyl alcohol and pry slower.
    • Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    • Remove the battery.
    • Reinstalling a damaged or deformed battery is a safety hazard. Replace it with a new battery.
    • During reassembly, remove any remaining tape under the battery and clean any residual adhesive with isopropyl alcohol. If you are reusing the screen assembly, apply new precut battery adhesive or high-strength double-sided tape to the battery well before pressing the new battery into place.
    I found it easier to remove the battery after I removed the mother board.
    Clinton King - 回复
    It’s much easier to remove the battery after the motherboard is removed from the opposite side
    Marc Keirn - 回复
    Merci. La batterie est difficile À décoller Mais tout été parfait.
    Didier Isoard - 回复
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto G6 Answers community for help.
35等其他人完成本指南。
Tarun Thiruma
于11/20/19注册
35,352 声望
创作了134篇指南
8条评论
This is a beautifully done tutorial. I have written over 100 service manuals, and have seen few procedures described better than this.
Edward Coan - 回复
One of the best instructions that I have used and the Ifixit tool kit was perfect and the price for everything was very good.
Steve Rickman - 回复
One of the best tutorials I have followed. Even this 73 year old was able to easily follow and finish the project without difficulty. Thank you, I now have a new battery in my cell phone. Happy customer.
Ann Stickel - 回复
Moto G6 charging problem
Kumar. Kumar Kumar - 回复
thank you for writing this up. I could follow your steps without any issue. The telephone is glued together really well, it took me many attempts to take off the back cover glass and also the battery. Just keep (re)heating the phone and slowly work with the picks, it will come off eventually.
doj - 回复
Changed battery successfully and it is charging! Will also calibrate in order to set the battery to indicate charge correctly. I kept both a youtube tutorial and this tutorial up and doublechecked myself thoughout, it worked really well. Thank you so much, Ifixit, your instructions on various things have helped me through multiple projects.
Audrey L - 回复
Thank you for such an excellent tutorial. It along with the excellent kit for the Moto G6 battery made the job easy...
Dik Harrison - 回复
I praised too soon! Now when I try to charge the phone I get the message "charging will continue after the phone has cooled down", but the phone is not even warm.  I have tried all the suggested solutions I could find, to no avail.  I finally did a restore to factory defaults, again to no avail.  Also when the phone boots up it immediately shuts down once booting is completed.
Dik Harrison -
添加评论
浏览统计数据:
过去 24 小时: 19
过去 7 天: 82
过去 30 天: 436
总计 42,471
