跳转到主内容
Motorola Moto E5 Play Screen Replacement
Craig Lloyd
Craig Lloyd4 其他贡献者
最后更新于 June 24, 2024
30分钟 - 2小时
中等
Follow this guide to replace the screen for the Motorola Moto E5 Play.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
For your safety, discharge your existing battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
  1. Motorola Moto E5 Play Screen Replacement, Back Cover: 步骤 1 中的图像 1,2 Motorola Moto E5 Play Screen Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom right corner of the phone.
    • Pry with your fingernail or twist the spudger to release the back cover's clips from the phone.
  2. Motorola Moto E5 Play Screen Replacement: 步骤 2 中的图像 1,2 Motorola Moto E5 Play Screen Replacement: 步骤 2 中的图像 2,2
    • Insert your fingernail or the flat end of a spudger into the seam on the bottom of the phone and slide it along the edge to release the clips holding the back cover to the phone.
  3. Motorola Moto E5 Play Screen Replacement: 步骤 3 中的图像 1,2 Motorola Moto E5 Play Screen Replacement: 步骤 3 中的图像 2,2
    • Continue sliding your fingernail or spudger along the seam around the rest of the phone to release the remaining clips.
  4. Motorola Moto E5 Play Screen Replacement: 步骤 4 中的图像 1,2 Motorola Moto E5 Play Screen Replacement: 步骤 4 中的图像 2,2
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto E5 Play Screen Replacement, Battery: 步骤 5 中的图像 1,2 Motorola Moto E5 Play Screen Replacement, Battery: 步骤 5 中的图像 2,2
    • Insert your fingernail or the flat end of the spudger into the notch at the bottom of the battery.
    • Pry with your fingernail or spudger to free the battery from its recess.
  6. Motorola Moto E5 Play Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins in the top right of the battery compartment.
  7. Motorola Moto E5 Play Screen Replacement, Screen: 步骤 7 中的图像 1,2 Motorola Moto E5 Play Screen Replacement, Screen: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the thirteen 3.5 mm-long T5 Torx screws securing the motherboard and daughterboard covers to the phone's frame.
    • A couple of screws are hidden under "S" stickers. It may help to remove these stickers with a pair of tweezers before removing the screws.
  8. Motorola Moto E5 Play Screen Replacement: 步骤 8 中的图像 1,3 Motorola Moto E5 Play Screen Replacement: 步骤 8 中的图像 2,3 Motorola Moto E5 Play Screen Replacement: 步骤 8 中的图像 3,3
    • Insert the flat end of a spudger into the seam on the bottom of the daughterboard cover.
    • Twist the spudger slightly to unclip the daughterboard cover.
    • Remove the daughterboard cover.
  9. Motorola Moto E5 Play Screen Replacement: 步骤 9 中的图像 1,2 Motorola Moto E5 Play Screen Replacement: 步骤 9 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the antenna cable from the daughterboard.
  10. Motorola Moto E5 Play Screen Replacement: 步骤 10 中的图像 1,2 Motorola Moto E5 Play Screen Replacement: 步骤 10 中的图像 2,2
    • Use a spudger to pry up and disconnect the motherboard flex cable connector from the daughterboard.
  11. Motorola Moto E5 Play Screen Replacement: 步骤 11 中的图像 1,1
    • Remove the 3 mm-long T5 Torx screws securing the daughterboard to the phone's frame.
  12. Motorola Moto E5 Play Screen Replacement: 步骤 12 中的图像 1,3 Motorola Moto E5 Play Screen Replacement: 步骤 12 中的图像 2,3 Motorola Moto E5 Play Screen Replacement: 步骤 12 中的图像 3,3
    • Insert the flat end of a spudger into the gap below the daughterboard and to the left of the charging port.
    • Pry the daughterboard up slightly with the spudger to loosen it from its recess.
    • Lift and remove the daughterboard, taking care not to snag any cables.
  13. Motorola Moto E5 Play Screen Replacement: 步骤 13 中的图像 1,2 Motorola Moto E5 Play Screen Replacement: 步骤 13 中的图像 2,2
    • Use the point of a spudger to pry up and loosen the vibration motor from its recess.
  14. Motorola Moto E5 Play Screen Replacement: 步骤 14 中的图像 1,3 Motorola Moto E5 Play Screen Replacement: 步骤 14 中的图像 2,3 Motorola Moto E5 Play Screen Replacement: 步骤 14 中的图像 3,3
    • Use an opening pick to carefully slice the adhesive underneath the vibration motor's contact pads.
    • Remove the vibration motor.
  15. Motorola Moto E5 Play Screen Replacement: 步骤 15 中的图像 1,2 Motorola Moto E5 Play Screen Replacement: 步骤 15 中的图像 2,2
    • Insert an opening tool into the seam on the right side of the phone near the top.
    • Gently pry upwards until the hidden clip on the motherboard cover releases.
  16. Motorola Moto E5 Play Screen Replacement: 步骤 16 中的图像 1,2 Motorola Moto E5 Play Screen Replacement: 步骤 16 中的图像 2,2
    • Insert an opening tool into the seam on the top of the phone, to the right of the indentation.
  17. Motorola Moto E5 Play Screen Replacement: 步骤 17 中的图像 1,2 Motorola Moto E5 Play Screen Replacement: 步骤 17 中的图像 2,2
    • Make sure the three clips on the motherboard cover have not re-engaged.
    • Lift the motherboard cover from the top and remove it.
  18. Motorola Moto E5 Play Screen Replacement: 步骤 18 中的图像 1,2 Motorola Moto E5 Play Screen Replacement: 步骤 18 中的图像 2,2
    • Take note of which socket the antenna cable is attached to on the motherboard.
    • Use the point of a spudger to pry up and disconnect the antenna cable from the motherboard.
    • Be sure to attach the antenna cable to the same socket during reassembly.
  19. Motorola Moto E5 Play Screen Replacement: 步骤 19 中的图像 1,2 Motorola Moto E5 Play Screen Replacement: 步骤 19 中的图像 2,2
    • Use the point of a spudger to lift up the locking mechanism securing the ribbon cable to the ZIF connector.
  20. Motorola Moto E5 Play Screen Replacement: 步骤 20 中的图像 1,3 Motorola Moto E5 Play Screen Replacement: 步骤 20 中的图像 2,3 Motorola Moto E5 Play Screen Replacement: 步骤 20 中的图像 3,3
    • Slide an opening pick between the ribbon cable and the motherboard to remove the cable from its connector.
  21. Motorola Moto E5 Play Screen Replacement: 步骤 21 中的图像 1,2 Motorola Moto E5 Play Screen Replacement: 步骤 21 中的图像 2,2
    • Use a spudger to pry up and disconnect the display connector from the motherboard.
  22. Motorola Moto E5 Play Screen Replacement: 步骤 22 中的图像 1,1
    • Remove the two 3 mm-long T5 Torx screws securing the motherboard to the phone's frame.
  23. Motorola Moto E5 Play Screen Replacement: 步骤 23 中的图像 1,3 Motorola Moto E5 Play Screen Replacement: 步骤 23 中的图像 2,3 Motorola Moto E5 Play Screen Replacement: 步骤 23 中的图像 3,3
    • Insert the flat end of a spudger underneath the motherboard, anywhere near the top edge of the phone.
    • Lift the spudger slightly to loosen the motherboard from the frame.
    • Remove the motherboard from the phone.
    • The underside of the motherboard is still connected to the phone by the daughterboard flex cable connector near the bottom. Lifting up on the motherboard should disconnect it. If not, use the flat end of a spudger near the connector to disconnect it.
  24. Motorola Moto E5 Play Screen Replacement: 步骤 24 中的图像 1,3 Motorola Moto E5 Play Screen Replacement: 步骤 24 中的图像 2,3 Motorola Moto E5 Play Screen Replacement: 步骤 24 中的图像 3,3
    • Use the flat end of a spudger to pry up and loosen the earpiece module from its recess.
    • Use your fingers or a pair of tweezers to remove the earpiece module.
  25. Motorola Moto E5 Play Screen Replacement: 步骤 25 中的图像 1,3 Motorola Moto E5 Play Screen Replacement: 步骤 25 中的图像 2,3 Motorola Moto E5 Play Screen Replacement: 步骤 25 中的图像 3,3
    • Insert an opening pick in between the frame and button assembly.
    • Carefully slide the opening pick underneath the button assembly to slice the adhesive.
    • Remove the button assembly.
  26. Motorola Moto E5 Play Screen Replacement: 步骤 26 中的图像 1,3 Motorola Moto E5 Play Screen Replacement: 步骤 26 中的图像 2,3 Motorola Moto E5 Play Screen Replacement: 步骤 26 中的图像 3,3
    • Use the point of a spudger to pry up a corner of the black battery mat.
    • Use your fingers to slowly peel the battery mat from the frame.
    • There is a flex cable underneath the mat, and portions may stick to the mat as you peel it off. If that happens, carefully loosen the cable from the mat as you peel.
    It is not clear that the flex cable under the battery mat can easily tear near the end that is in the middle of the phone. There is a little tab at 90 degrees to the cable that is stuck to the back of the mat, but the rest of the cable is stuck to the phone body, and since it is not in any of the photos, you won’t know it’s there until it is torn. It’s unclear if you peel the mat all the way off, or just partially peel it back.
    Roger - 回复
    Hi Roger,
    Thanks for the feedback! I’ll adjust the step instructions to incorporate your notes.
    Arthur Shi -
  27. Motorola Moto E5 Play Screen Replacement: 步骤 27 中的图像 1,3 Motorola Moto E5 Play Screen Replacement: 步骤 27 中的图像 2,3 Motorola Moto E5 Play Screen Replacement: 步骤 27 中的图像 3,3
    • Use your fingers or a pair of tweezers to lift and de-route the antenna cable from its groove on the right edge of the phone.
  28. Motorola Moto E5 Play Screen Replacement: 步骤 28 中的图像 1,2 Motorola Moto E5 Play Screen Replacement: 步骤 28 中的图像 2,2
    • Insert an opening pick underneath the daughterboard flex cable.
    • Slide the pick along the underside of the cable, slicing the adhesive and removing the cable from the phone.
  29. Motorola Moto E5 Play Screen Replacement: 步骤 29 中的图像 1,1
    • Only the frame and the LCD screen and digitizer assembly remain. Double-check that you removed all of the necessary components.
结论
Repair didn’t go as planned? Check out our Motorola Moto E5 Play Answers community for troubleshooting help.
16等其他人完成本指南。
Craig Lloyd
于02/10/16注册
39,082 声望
创作了82篇指南
6指南评论
How do i get the screen out of the frame?
Benjamin Lucas - 回复
It’s all one component! I suppose it’s possible to separate them, but the part we sell includes the screen and the frame in one piece.
Craig Lloyd -
Yup, screen and frame comes as one piece. Just completed!
Indian Bill -
Thank you, but now I need how to put this all back together lmao —~—
Xcooki - 回复
Do I need any adhesive to put it on the new frame? If so, what type and where does it go? Thanks!
christcansaveyou - 回复
No adhesive required!
Craig Lloyd -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 67
总计 9,621
