跳转到主内容
Motorola Edge Battery Replacement
你所需要的
  1. Motorola Edge Battery Replacement, Heat the bottom edge: 步骤 1 中的图像 1,1
    • Completely power off your phone before you begin.
    • Heat an iOpener, then apply it along the bottom edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone because the display and internal battery are both susceptible to heat damage.
  2. Motorola Edge Battery Replacement, Separate the bottom adhesive: 步骤 2 中的图像 1,3 Motorola Edge Battery Replacement, Separate the bottom adhesive: 步骤 2 中的图像 2,3 Motorola Edge Battery Replacement, Separate the bottom adhesive: 步骤 2 中的图像 3,3
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  3. Motorola Edge Battery Replacement, Slice the bottom adhesive: 步骤 3 中的图像 1,3 Motorola Edge Battery Replacement, Slice the bottom adhesive: 步骤 3 中的图像 2,3 Motorola Edge Battery Replacement, Slice the bottom adhesive: 步骤 3 中的图像 3,3
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick in to prevent the adhesive from resealing.
  4. Motorola Edge Battery Replacement, Heat the right edge: 步骤 4 中的图像 1,1
    • Apply a heated iOpener to the back cover's right edge for two minutes.
  5. Motorola Edge Battery Replacement, Separate the corner adhesive: 步骤 5 中的图像 1,3 Motorola Edge Battery Replacement, Separate the corner adhesive: 步骤 5 中的图像 2,3 Motorola Edge Battery Replacement, Separate the corner adhesive: 步骤 5 中的图像 3,3
    • Rotate the opening pick around the bottom-right corner of the phone.
  6. Motorola Edge Battery Replacement, Separate the right adhesive: 步骤 6 中的图像 1,3 Motorola Edge Battery Replacement, Separate the right adhesive: 步骤 6 中的图像 2,3 Motorola Edge Battery Replacement, Separate the right adhesive: 步骤 6 中的图像 3,3
    • Insert a new opening pick into the gap you just created.
    • Slide the pick along the right edge of the phone to separate the adhesive.
    • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
  7. Motorola Edge Battery Replacement, Remove the back cover: 步骤 7 中的图像 1,3 Motorola Edge Battery Replacement, Remove the back cover: 步骤 7 中的图像 2,3 Motorola Edge Battery Replacement, Remove the back cover: 步骤 7 中的图像 3,3
    • Remove the back cover, taking care not to damage the components inside the phone.
  8. Motorola Edge Battery Replacement, Remove the motherboard's screws: 步骤 8 中的图像 1,1
    • Use a T5 Torx screwdriver to remove the twelve 3.4 mm-long screws securing the motherboard cover.
  9. Motorola Edge Battery Replacement, Remove the motherboard cover: 步骤 9 中的图像 1,3 Motorola Edge Battery Replacement, Remove the motherboard cover: 步骤 9 中的图像 2,3 Motorola Edge Battery Replacement, Remove the motherboard cover: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of blunt tweezers or your fingers to lift up and remove the motherboard cover.
    • The motherboard cover also contains the phone's flash.
  10. Motorola Edge Battery Replacement, Disconnect the battery cable's press connector: 步骤 10 中的图像 1,2 Motorola Edge Battery Replacement, Disconnect the battery cable's press connector: 步骤 10 中的图像 2,2
    • Use a spudger to pry up and disconnect the battery cable's press connector from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  11. Motorola Edge Battery Replacement, Remove the daughterboard's t5 screws: 步骤 11 中的图像 1,2 Motorola Edge Battery Replacement, Remove the daughterboard's t5 screws: 步骤 11 中的图像 2,2
    • Use a T5 Torx screwdriver to remove the nine 3.4 mm screws securing the daughterboard.
  12. Motorola Edge Battery Replacement, Remove the daughterboard cover: 步骤 12 中的图像 1,3 Motorola Edge Battery Replacement, Remove the daughterboard cover: 步骤 12 中的图像 2,3 Motorola Edge Battery Replacement, Remove the daughterboard cover: 步骤 12 中的图像 3,3
    • Use a spudger to pry up the plastic daughterboard cover and disconnect it from the rest of the phone.
  13. Motorola Edge Battery Replacement, Disconnect the interconnect cable from the motherboard: 步骤 13 中的图像 1,2 Motorola Edge Battery Replacement, Disconnect the interconnect cable from the motherboard: 步骤 13 中的图像 2,2
    • Use a spudger to pry up and disconnect the interconnect cable's press connector from the motherboard.
  14. Motorola Edge Battery Replacement, Disconnect the interconnect cable from the daughterboard: 步骤 14 中的图像 1,2 Motorola Edge Battery Replacement, Disconnect the interconnect cable from the daughterboard: 步骤 14 中的图像 2,2
    • Use a spudger to pry up and disconnect the interconnect cable's press connector from the daughterboard.
  15. Motorola Edge Battery Replacement, Remove the interconnect cable: 步骤 15 中的图像 1,2 Motorola Edge Battery Replacement, Remove the interconnect cable: 步骤 15 中的图像 2,2
    • Use your fingers to remove the interconnect cable after it has been disconnected from both the motherboard and daughterboard.
  16. Motorola Edge Battery Replacement, Weaken the battery's adhesive: 步骤 16 中的图像 1,1
    • Heat an iOpener and place it on the screen for two minutes in order to loosen the adhesive on the battery.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
  17. Motorola Edge Battery Replacement, Create a gap between the battery and the frame: 步骤 17 中的图像 1,2 Motorola Edge Battery Replacement, Create a gap between the battery and the frame: 步骤 17 中的图像 2,2
    • Wedge the pointed end of an opening pick between the right side of the battery and the midframe.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Be careful not to damage the screen's ribbon cable, which is located underneath the battery.
  18. Motorola Edge Battery Replacement, Switch to a plastic card: 步骤 18 中的图像 1,3 Motorola Edge Battery Replacement, Switch to a plastic card: 步骤 18 中的图像 2,3 Motorola Edge Battery Replacement, Switch to a plastic card: 步骤 18 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    • After making a gap between the battery and the frame, replace the opening pick with a plastic card.
    • A plastic card will help ensure that the battery is not bent or damaged while being removed.
  19. Motorola Edge Battery Replacement, Cut through the battery's adhesive: 步骤 19 中的图像 1,3 Motorola Edge Battery Replacement, Cut through the battery's adhesive: 步骤 19 中的图像 2,3 Motorola Edge Battery Replacement, Cut through the battery's adhesive: 步骤 19 中的图像 3,3
    • Carefully slide a plastic card underneath the battery to cut through the adhesive.
  20. Motorola Edge Battery Replacement, Remove the battery: 步骤 20 中的图像 1,3 Motorola Edge Battery Replacement, Remove the battery: 步骤 20 中的图像 2,3 Motorola Edge Battery Replacement, Remove the battery: 步骤 20 中的图像 3,3
    • Slide a plastic card under the battery, then carefully lift the battery up until the adhesive is loose enough to remove the battery.
  21. Motorola Edge Battery Replacement: 步骤 21 中的图像 1,3 Motorola Edge Battery Replacement: 步骤 21 中的图像 2,3 Motorola Edge Battery Replacement: 步骤 21 中的图像 3,3
    • Separate and remove the battery from the midframe.
    • If the battery is deformed, dented, or damaged in any way, don't reinstall it. Reinstalling a damaged battery is a potential safety hazard. Replace it with a new one.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card to reinstall the battery.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
另外一个人完成了本指南。
Jennifer Berg
于03/21/22注册
2,813 声望
创作了24篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 41
过去 30 天: 194
总计 9,968
