跳转到主内容
Meta Quest 2 Speaker Assembly Replacement
你所需要的
  1. Meta Quest 2 Speaker Assembly Replacement, Power off your Meta Quest 2: 步骤 1 中的图像 1,1
    • Hold the power button for three seconds to fully turn off your headset.
    • You'll hear a power down chime, and the LED next to the power button will turn off.
  2. Meta Quest 2 Speaker Assembly Replacement, Remove the facial interface: 步骤 2 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement, Remove the facial interface: 步骤 2 中的图像 2,2
    • Grasp and pull on the nose section of the facial interface to unclip it from the headset.
  3. Meta Quest 2 Speaker Assembly Replacement: 步骤 3 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement: 步骤 3 中的图像 2,2
    • Grasp and pull on the top section of the facial interface to unclip it from the headset.
  4. Meta Quest 2 Speaker Assembly Replacement: 步骤 4 中的图像 1,1
    • Remove the facial interface.
    • During reassembly, align the facial interface to the headset and use your fingers to press along the perimeter to clip it back in.
  5. Meta Quest 2 Speaker Assembly Replacement, Unclip the side straps: 步骤 5 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement, Unclip the side straps: 步骤 5 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement, Unclip the side straps: 步骤 5 中的图像 3,3
    • Use your fingers to grasp the right strap near the headset.
    • Peel the right strap away from the headset arm to unclip it.
  6. Meta Quest 2 Speaker Assembly Replacement: 步骤 6 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement: 步骤 6 中的图像 2,2
    • Repeat the procedure to peel the left strap away from the arm to unclip it.
  7. Meta Quest 2 Speaker Assembly Replacement, Remove the top strap: 步骤 7 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement, Remove the top strap: 步骤 7 中的图像 2,2
    • Separate the hook and loop strip on the top strap.
  8. Meta Quest 2 Speaker Assembly Replacement, Remove the head strap: 步骤 8 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement, Remove the head strap: 步骤 8 中的图像 2,2
    • Unthread the top strap from its bracket.
    • Remove the head strap.
  9. Meta Quest 2 Speaker Assembly Replacement, Remove the eyepiece trim screws: 步骤 9 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement, Remove the eyepiece trim screws: 步骤 9 中的图像 2,2
    • Use a Torx T2 driver to remove the six 3.5 mm‑long screws securing the eyepiece trim.
  10. Meta Quest 2 Speaker Assembly Replacement, Release the eyepiece trim clips: 步骤 10 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement, Release the eyepiece trim clips: 步骤 10 中的图像 2,2
    • Insert an opening pick into the seam between the eyepiece trim and white outer shell, near the nose cutout.
  11. Meta Quest 2 Speaker Assembly Replacement: 步骤 11 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 11 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 11 中的图像 3,3
    • Slide the opening pick to the right along the seam to release the clips securing the eyepiece trim.
    • Pry with the opening pick to release the clips securing the right side of the eyepiece trim.
    • Leave the opening pick in the seam to prevent the clips from reengaging.
  12. Meta Quest 2 Speaker Assembly Replacement: 步骤 12 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 12 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 12 中的图像 3,3
    • Repeat the prying procedure along the left edge to release the clips securing the eyepiece trim.
    • During reassembly, press your fingers along the perimeter of the eyepiece trim to clip it back in place.
  13. Meta Quest 2 Speaker Assembly Replacement, Reposition the eyepiece trim: 步骤 13 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement, Reposition the eyepiece trim: 步骤 13 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement, Reposition the eyepiece trim: 步骤 13 中的图像 3,3
    • Don’t try to fully remove the eyepiece trim in this step. It’s still connected to the headset by a short cable.
    • Lift the eyepiece trim slightly and tilt it towards the top edge of the headset.
    • Set the trim down on your work surface, making sure not to strain the cable.
  14. Meta Quest 2 Speaker Assembly Replacement, Disconnect the face sensor: 步骤 14 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement, Disconnect the face sensor: 步骤 14 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement, Disconnect the face sensor: 步骤 14 中的图像 3,3
    • Use the point of a spudger to flip open the black lock tab on the ZIF connector securing the face sensor cable.
  15. Meta Quest 2 Speaker Assembly Replacement: 步骤 15 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement: 步骤 15 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to pull the face sensor cable out of the ZIF connector.
  16. Meta Quest 2 Speaker Assembly Replacement, Remove the eyepiece trim: 步骤 16 中的图像 1,1
    • Remove the eyepiece trim.
  17. Meta Quest 2 Speaker Assembly Replacement, Reassembly note: 步骤 17 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement, Reassembly note: 步骤 17 中的图像 2,2
    • During reassembly:
    • Make sure the lens spacing matches the spacing indicator. This allows the indicator peg to sit correctly in its notch.
    • If the lens spacing doesn't match the indicator, manually adjust the lens with your fingers.
  18. Meta Quest 2 Speaker Assembly Replacement, Reassembly note: 步骤 18 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement, Reassembly note: 步骤 18 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement, Reassembly note: 步骤 18 中的图像 3,3
    • During reassembly, the face sensor cable can be tricky to connect. Follow these tips to connect the cable:
    • Thread your fingers through the eyepiece trim’s eyeholes and grasp the edges of the sensor cable.
    • Slide the sensor cable into the socket until the first set of tabs rests in the socket. This should flip the lock tab down partially.
    • Use a spudger to press the lock tab down towards the cable to lock it in place.
  19. Meta Quest 2 Speaker Assembly Replacement, Remove the front cover screws: 步骤 19 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement, Remove the front cover screws: 步骤 19 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement, Remove the front cover screws: 步骤 19 中的图像 3,3
    • Use a Phillips screwdriver to remove the five 7.7 mm‑long screws securing the front cover to the headset:
    • One recessed in the top-left corner
    • One recessed in the top-right corner
    • Three along the lower edge
  20. Meta Quest 2 Speaker Assembly Replacement, Release the front cover clips: 步骤 20 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement, Release the front cover clips: 步骤 20 中的图像 2,2
    • The front cover is still held in place by clips along the bottom and side edges.
    • Insert an opening pick into the seam between the bottom edge of the front cover and the headset.
    • Pry with the opening pick to release the front cover clips.
  21. Meta Quest 2 Speaker Assembly Replacement: 步骤 21 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 21 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 21 中的图像 3,3
    • Slide the opening clip along the seam and pry to release all the clips securing the front cover.
  22. Meta Quest 2 Speaker Assembly Replacement, Remove the front cover: 步骤 22 中的图像 1,1
    • Remove the front cover.
  23. Meta Quest 2 Speaker Assembly Replacement, Disconnect the top right antenna: 步骤 23 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement, Disconnect the top right antenna: 步骤 23 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement, Disconnect the top right antenna: 步骤 23 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers to grasp the metal neck of the top-right antenna cable.
    • Lift the antenna connector straight up to disconnect it.
    • Guide the antenna cable out of its metal clip holding it in place.
  24. Meta Quest 2 Speaker Assembly Replacement, Remove the battery cable bracket: 步骤 24 中的图像 1,1
    • Use a Phillips screwdriver to remove the three screws securing the battery cable bracket:
    • One 4.4 mm‑long screw
    • Two 2.3 mm‑long screws
  25. Meta Quest 2 Speaker Assembly Replacement: 步骤 25 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 25 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 25 中的图像 3,3
    • Use tweezers or your fingers to grasp the battery cable bracket.
    • Twist the cable bracket slightly so that its bottom left corner unclips from the motherboard.
    • Remove the battery cable bracket.
  26. Meta Quest 2 Speaker Assembly Replacement, Disconnect the battery: 步骤 26 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement, Disconnect the battery: 步骤 26 中的图像 2,2
    • Use a spudger to pry up and disconnect the battery press connector from the motherboard.
    • The battery press connector can disconnect accidentally during reassembly. Check this connector before you attach the bracket.
  27. Meta Quest 2 Speaker Assembly Replacement, Disconnect the antenna: 步骤 27 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement, Disconnect the antenna: 步骤 27 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement, Disconnect the antenna: 步骤 27 中的图像 3,3
    在这个步骤中使用的工具:
    • Insert one arm of a pair of tweezers under the metal neck of the black antenna cable near the fan assembly.
  28. Meta Quest 2 Speaker Assembly Replacement, Loosen the front antenna assembly: 步骤 28 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement, Loosen the front antenna assembly: 步骤 28 中的图像 2,2
    • Use a Phillips screwdriver to remove the eight screws securing the antenna assembly to the headset:
    • Four 4.4 mm‑long screws
    • Two 4.8 mm‑long screws
    • Two 10.7 mm‑long screws
  29. Meta Quest 2 Speaker Assembly Replacement: 步骤 29 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement: 步骤 29 中的图像 2,2
    • Use your fingers to flip up the antenna assembly enough to access the cable underneath it.
  30. Meta Quest 2 Speaker Assembly Replacement: 步骤 30 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement: 步骤 30 中的图像 2,2
    • Use tweezers to unclip the antenna cable from its metal clip.
  31. Meta Quest 2 Speaker Assembly Replacement, Remove the front antenna assembly: 步骤 31 中的图像 1,1
    • Remove the front antenna assembly.
  32. Meta Quest 2 Speaker Assembly Replacement, Disconnect the fan: 步骤 32 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement, Disconnect the fan: 步骤 32 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to grab the fan connector and carefully slide it out of its socket.
  33. Meta Quest 2 Speaker Assembly Replacement, Loosen the LED flex cable: 步骤 33 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement, Loosen the LED flex cable: 步骤 33 中的图像 2,2
    • Use the point of an opening pick to loosen the adhesive securing the LED flex cable from the top of the fan assembly.
  34. Meta Quest 2 Speaker Assembly Replacement, Remove the fan assembly: 步骤 34 中的图像 1,1
    • Remove the two screws securing the fan assembly to the headset:
    • One 4.4 mm‑long Phillips screw
    • One 3.6 mm‑long Torx T2 screw
  35. Meta Quest 2 Speaker Assembly Replacement: 步骤 35 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 35 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 35 中的图像 3,3
    • Lift the fan assembly and remove it.
  36. Meta Quest 2 Speaker Assembly Replacement, Remove the heat sink: 步骤 36 中的图像 1,1
    • Use a Phillips screwdriver to remove the four 2.3 mm‑long screws securing the heat sink to the motherboard.
  37. Meta Quest 2 Speaker Assembly Replacement: 步骤 37 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement: 步骤 37 中的图像 2,2
    在这个步骤中使用的工具:
    iFixit Thermal Putty
    $9.95
    • Use your fingers to lift the heat sink and remove it.
    • You may feel a bit of resistance. This is normal since the midframe is slightly bonded to the heat sink with thermal paste.
    • You can reuse the thermal paste if you keep it clean. Otherwise, use a spudger to scrape off the old paste and apply a small amount of thermal putty or viscous thermal compound (such as K5 Pro) to the processor.
  38. Meta Quest 2 Speaker Assembly Replacement, Reassembly note: 步骤 38 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement, Reassembly note: 步骤 38 中的图像 2,2
    • During reassembly, stop here and check if these twelve connectors are properly connected to the motherboard:
    • Two speaker connectors
    • Seven ZIF connectors
    • Two press connectors
    • One antenna connector
    • There are additional connectors on the motherboard, but they shouldn't be connected at this point.
  39. Meta Quest 2 Speaker Assembly Replacement, Disconnect the speaker connectors: 步骤 39 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement, Disconnect the speaker connectors: 步骤 39 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement, Disconnect the speaker connectors: 步骤 39 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers to grip the left speaker cables at the base of their motherboard connector.
    • Lift the connector gently straight up to disconnect it.
    • During reassembly, use the flat end of a spudger to press the speaker cable into the rubber holding clip.
  40. Meta Quest 2 Speaker Assembly Replacement: 步骤 40 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 40 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 40 中的图像 3,3
    • Repeat the disconnection procedure for the right speaker connector.
  41. Meta Quest 2 Speaker Assembly Replacement, Disconnect the ZIF socket flex cables: 步骤 41 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement, Disconnect the ZIF socket flex cables: 步骤 41 中的图像 2,2
    • Use tweezers to gently peel the black tape covering the two top flex cables.
    • Set the tape aside to be reused during reassembly.
  42. Meta Quest 2 Speaker Assembly Replacement: 步骤 42 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 42 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 42 中的图像 3,3
    • Use a clean fingernail or a spudger to pry up the lock tab securing the top left camera cable.
  43. Meta Quest 2 Speaker Assembly Replacement: 步骤 43 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement: 步骤 43 中的图像 2,2
    • Grasp the top left camera cable with tweezers and slide it out of its ZIF connector.
  44. Meta Quest 2 Speaker Assembly Replacement: 步骤 44 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement: 步骤 44 中的图像 2,2
    • Move counter-clockwise around the motherboard and disconnect the remaining six ZIF connectors:
    • Power button and LED board
    • Bottom left camera
    • Bottom right camera
    • Top right camera
    • Face sensor interconnect cable
    • Indicator LED cable
  45. Meta Quest 2 Speaker Assembly Replacement, Disconnect the press connectors: 步骤 45 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement, Disconnect the press connectors: 步骤 45 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement, Disconnect the press connectors: 步骤 45 中的图像 3,3
    • Use a spudger to pry up and disconnect the display cable.
  46. Meta Quest 2 Speaker Assembly Replacement: 步骤 46 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 46 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 46 中的图像 3,3
    • Use a spudger to pry up and disconnect the USB‑C and headphone jack cable.
  47. Meta Quest 2 Speaker Assembly Replacement: 步骤 47 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 47 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 47 中的图像 3,3
    • Insert one arm of a pair of tweezers under the metal neck of the side antenna cable.
  48. Meta Quest 2 Speaker Assembly Replacement, Remove the motherboard: 步骤 48 中的图像 1,1
    • Remove the five screws securing the motherboard to the headset:
    • Four 3.8 mm‑long Phillips screws
    • One 6 mm‑long 3.5 mm hex standoff screw
  49. Meta Quest 2 Speaker Assembly Replacement: 步骤 49 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement: 步骤 49 中的图像 2,2
    • At this point, the motherboard should be loose, with some thermal paste sticking it to the headset.
    • Use a spudger to pry up and separate the motherboard from the headset.
    • If it feels like the motherboard is caught on something, check that all the cables are disconnected from it.
  50. Meta Quest 2 Speaker Assembly Replacement: 步骤 50 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement: 步骤 50 中的图像 2,2
    在这个步骤中使用的工具:
    $9.95
    • Remove the motherboard.
  51. Meta Quest 2 Speaker Assembly Replacement, Remove the camera covers: 步骤 51 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement, Remove the camera covers: 步骤 51 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement, Remove the camera covers: 步骤 51 中的图像 3,3
    在这个步骤中使用的工具:
    • Use your fingers or tweezers to peel and remove the two camera covers from the top cameras.
    • During reassembly, align the cutouts on the camera covers to their respective pegs on the headset.
    • The camera covers have different alignment cutouts and aren't interchangeable.
  52. Meta Quest 2 Speaker Assembly Replacement, Loosen the screen and lens assembly: 步骤 52 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement, Loosen the screen and lens assembly: 步骤 52 中的图像 2,2
    • Peel and remove the black tape covering the antenna cable.
    • Set this tape aside to be reused during reassembly.
  53. Meta Quest 2 Speaker Assembly Replacement: 步骤 53 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 53 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 53 中的图像 3,3
    • Use tweezers to lift and unclip the black antenna cable from the metal grounding clips.
  54. Meta Quest 2 Speaker Assembly Replacement: 步骤 54 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 54 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 54 中的图像 3,3
    • Use a spudger to pry up the black lock tab securing the left microphone flex cable to the left interconnect cable.
    • Use your fingers or tweezers to slide the microphone cable out of the ZIF connector.
  55. Meta Quest 2 Speaker Assembly Replacement: 步骤 55 中的图像 1,1
    • Repeat the procedure to disconnect the right microphone cable.
  56. Meta Quest 2 Speaker Assembly Replacement: 步骤 56 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement: 步骤 56 中的图像 2,2
    • Slide the point of an opening pick underneath the battery flex cable to loosen the adhesive securing it from the headset.
  57. Meta Quest 2 Speaker Assembly Replacement: 步骤 57 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 57 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 57 中的图像 3,3
    • Some interconnect cables have been removed in the following images for clarity purposes. You don't have to remove them as part of the procedure.
    • Use a Phillips screwdriver to remove the four screws securing the screen and lens assembly to the frame:
    • Two 6.5 mm‑long screws
    • Two 7.7 mm‑long screws
  58. Meta Quest 2 Speaker Assembly Replacement, Remove the screen and frame assembly: 步骤 58 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement, Remove the screen and frame assembly: 步骤 58 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement, Remove the screen and frame assembly: 步骤 58 中的图像 3,3
    • Grasp the screen and lens assembly with your fingers.
    • Slowly lift and separate the assembly from the outer shell, taking care to reposition any cables that get in the way.
    • Remove the screen and lens assembly.
  59. Meta Quest 2 Speaker Assembly Replacement, Reassembly note: 步骤 59 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement, Reassembly note: 步骤 59 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement, Reassembly note: 步骤 59 中的图像 3,3
    • During reassembly, be careful not to trap the twelve cables as you insert the lens assembly into the outer shell:
    • Three cables along the top edge—two flex cables and one LED flex cable
    • Two cables in the top right corner—the battery connector and an antenna cable
    • Two cables along the right edge—an antenna cable and a wide flex cable
    • Two flex cables along the bottom edge
    • Three cables along the left edge—one antenna cable, one flex cable, and one speaker cable
    • You can use a rubber band to help secure the cables out of the way.
  60. Meta Quest 2 Speaker Assembly Replacement, Unclip the speaker cable: 步骤 60 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement, Unclip the speaker cable: 步骤 60 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement, Unclip the speaker cable: 步骤 60 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers or your fingers to guide the speaker cable out of its two plastic clips.
    • Clip this cable neatly into the guide clips to prevent it from getting pinched by the screen and lens assembly.
    • The first guide clip should clip behind the rubber stop on the speaker cable. This anchors the cable while giving it enough slack for the speaker arm to swivel.
  61. Meta Quest 2 Speaker Assembly Replacement, Unscrew the speaker assembly: 步骤 61 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement, Unscrew the speaker assembly: 步骤 61 中的图像 2,2
    • Use a Phillips screwdriver to remove the four 4.5 mm‑long screws securing the outer speaker bracket to the outer shell.
  62. Meta Quest 2 Speaker Assembly Replacement: 步骤 62 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 62 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 62 中的图像 3,3
    • Use a spudger to pry the outer speaker bracket off of the gaskets securing it to the speaker assembly.
    • Remove the outer speaker bracket.
  63. Meta Quest 2 Speaker Assembly Replacement: 步骤 63 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 63 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 63 中的图像 3,3
    • Four metal clips secure the inner speaker bracket to the speaker assembly.
    • Insert one arm of a pair of tweezers under the lip of a metal clip.
    • Use tweezers to grasp the clip by the lip and pull out the clip from its recess.
    • These clips can be difficult to pull out because they have a small locking tab on the back. If you have trouble, you can wiggle the clip back and forth as you pull. To get a better grip, use needle nose pliers.
    • Repeat the process for the three remaining clips.
    • During reassembly, use the flat end of a spudger to fully press each clip into its recess.
  64. Meta Quest 2 Speaker Assembly Replacement: 步骤 64 中的图像 1,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 64 中的图像 2,3 Meta Quest 2 Speaker Assembly Replacement: 步骤 64 中的图像 3,3
    • Grasp the inner speaker bracket with your fingers and twist it counterclockwise to unlock it from the speaker assembly.
    • If you have trouble rotating the bracket, you can brace a spudger against the bracket while you twist the speaker arm.
    • During reassembly, twist the inner speaker bracket clockwise onto the speaker assembly until it won’t turn anymore. If it’s not fully twisted, you’ll have a difficult time reinstalling the four metal clips.
  65. Meta Quest 2 Speaker Assembly Replacement, Remove the speaker assembly: 步骤 65 中的图像 1,2 Meta Quest 2 Speaker Assembly Replacement, Remove the speaker assembly: 步骤 65 中的图像 2,2
    • Thread the speaker assembly wire through the inner speaker bracket.
    • Remove the speaker assembly.
结论
3等其他人完成本指南。
Arthur Shi
于01/03/18注册
309,604 声望
创作了701篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,608篇指南
3指南评论
I followed these directions which were amazing and very helpful, but after reassembling the headset it won’t turn on. Any ideas on why? I rechecked the power flex & it’s in there.
Stephanie - 回复
The directions were amazing was able to do this fairly quick only thing was is the volume buttons wouldn’t work went back through a second time. Made sure all connections were secure. Turned VR back on after reassembling and volume button still don’t work. It was not my main issue before.😔 please help
Stirlingblue - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 74
过去 30 天: 290
总计 5,124
