跳转到主内容
加入维修社区 - 创建账户
Meta Quest 2 Front Cover Replacement
你所需要的
  1. Meta Quest 2 Front Cover Replacement, Power off your Meta Quest 2: 步骤 1 中的图像 1,1
    • Hold the power button for three seconds to fully turn off your headset.
    • You'll hear a power down chime, and the LED next to the power button will turn off.
  2. Meta Quest 2 Front Cover Replacement, Remove the facial interface: 步骤 2 中的图像 1,2 Meta Quest 2 Front Cover Replacement, Remove the facial interface: 步骤 2 中的图像 2,2
    • Grasp and pull on the nose section of the facial interface to unclip it from the headset.
  3. Meta Quest 2 Front Cover Replacement: 步骤 3 中的图像 1,2 Meta Quest 2 Front Cover Replacement: 步骤 3 中的图像 2,2
    • Grasp and pull on the top section of the facial interface to unclip it from the headset.
  4. Meta Quest 2 Front Cover Replacement: 步骤 4 中的图像 1,1
    • Remove the facial interface.
    • During reassembly, align the facial interface to the headset and use your fingers to press along the perimeter to clip it back in.
  5. Meta Quest 2 Front Cover Replacement, Unclip the side straps: 步骤 5 中的图像 1,3 Meta Quest 2 Front Cover Replacement, Unclip the side straps: 步骤 5 中的图像 2,3 Meta Quest 2 Front Cover Replacement, Unclip the side straps: 步骤 5 中的图像 3,3
    • Use your fingers to grasp the right strap near the headset.
    • Peel the right strap away from the headset arm to unclip it.
  6. Meta Quest 2 Front Cover Replacement: 步骤 6 中的图像 1,2 Meta Quest 2 Front Cover Replacement: 步骤 6 中的图像 2,2
    • Repeat the procedure to peel the left strap away from the arm to unclip it.
  7. Meta Quest 2 Front Cover Replacement, Remove the top strap: 步骤 7 中的图像 1,2 Meta Quest 2 Front Cover Replacement, Remove the top strap: 步骤 7 中的图像 2,2
    • Separate the hook and loop strip on the top strap.
  8. Meta Quest 2 Front Cover Replacement, Remove the head strap: 步骤 8 中的图像 1,2 Meta Quest 2 Front Cover Replacement, Remove the head strap: 步骤 8 中的图像 2,2
    • Unthread the top strap from its bracket.
    • Remove the head strap.
  9. Meta Quest 2 Front Cover Replacement, Remove the eyepiece trim screws: 步骤 9 中的图像 1,2 Meta Quest 2 Front Cover Replacement, Remove the eyepiece trim screws: 步骤 9 中的图像 2,2
    • Use a Torx T2 driver to remove the six 3.5 mm‑long screws securing the eyepiece trim.
  10. Meta Quest 2 Front Cover Replacement, Release the eyepiece trim clips: 步骤 10 中的图像 1,2 Meta Quest 2 Front Cover Replacement, Release the eyepiece trim clips: 步骤 10 中的图像 2,2
    • Insert an opening pick into the seam between the eyepiece trim and white outer shell, near the nose cutout.
  11. Meta Quest 2 Front Cover Replacement: 步骤 11 中的图像 1,3 Meta Quest 2 Front Cover Replacement: 步骤 11 中的图像 2,3 Meta Quest 2 Front Cover Replacement: 步骤 11 中的图像 3,3
    • Slide the opening pick to the right along the seam to release the clips securing the eyepiece trim.
    • Pry with the opening pick to release the clips securing the right side of the eyepiece trim.
    • Leave the opening pick in the seam to prevent the clips from reengaging.
  12. Meta Quest 2 Front Cover Replacement: 步骤 12 中的图像 1,3 Meta Quest 2 Front Cover Replacement: 步骤 12 中的图像 2,3 Meta Quest 2 Front Cover Replacement: 步骤 12 中的图像 3,3
    • Repeat the prying procedure along the left edge to release the clips securing the eyepiece trim.
    • During reassembly, press your fingers along the perimeter of the eyepiece trim to clip it back in place.
  13. Meta Quest 2 Front Cover Replacement, Reposition the eyepiece trim: 步骤 13 中的图像 1,3 Meta Quest 2 Front Cover Replacement, Reposition the eyepiece trim: 步骤 13 中的图像 2,3 Meta Quest 2 Front Cover Replacement, Reposition the eyepiece trim: 步骤 13 中的图像 3,3
    • Don’t try to fully remove the eyepiece trim in this step. It’s still connected to the headset by a short cable.
    • Lift the eyepiece trim slightly and tilt it towards the top edge of the headset.
    • Set the trim down on your work surface, making sure not to strain the cable.
  14. Meta Quest 2 Front Cover Replacement, Disconnect the face sensor: 步骤 14 中的图像 1,3 Meta Quest 2 Front Cover Replacement, Disconnect the face sensor: 步骤 14 中的图像 2,3 Meta Quest 2 Front Cover Replacement, Disconnect the face sensor: 步骤 14 中的图像 3,3
    • Use the point of a spudger to flip open the black lock tab on the ZIF connector securing the face sensor cable.
  15. Meta Quest 2 Front Cover Replacement: 步骤 15 中的图像 1,2 Meta Quest 2 Front Cover Replacement: 步骤 15 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to pull the face sensor cable out of the ZIF connector.
  16. Meta Quest 2 Front Cover Replacement, Remove the eyepiece trim: 步骤 16 中的图像 1,1
    • Remove the eyepiece trim.
  17. Meta Quest 2 Front Cover Replacement, Reassembly note: 步骤 17 中的图像 1,2 Meta Quest 2 Front Cover Replacement, Reassembly note: 步骤 17 中的图像 2,2
    • During reassembly:
    • Make sure the lens spacing matches the spacing indicator. This allows the indicator peg to sit correctly in its notch.
    • If the lens spacing doesn't match the indicator, manually adjust the lens with your fingers.
  18. Meta Quest 2 Front Cover Replacement, Reassembly note: 步骤 18 中的图像 1,3 Meta Quest 2 Front Cover Replacement, Reassembly note: 步骤 18 中的图像 2,3 Meta Quest 2 Front Cover Replacement, Reassembly note: 步骤 18 中的图像 3,3
    • During reassembly, the face sensor cable can be tricky to connect. Follow these tips to connect the cable:
    • Thread your fingers through the eyepiece trim’s eyeholes and grasp the edges of the sensor cable.
    • Slide the sensor cable into the socket until the first set of tabs rests in the socket. This should flip the lock tab down partially.
    • Use a spudger to press the lock tab down towards the cable to lock it in place.
  19. Meta Quest 2 Front Cover Replacement, Remove the front cover screws: 步骤 19 中的图像 1,3 Meta Quest 2 Front Cover Replacement, Remove the front cover screws: 步骤 19 中的图像 2,3 Meta Quest 2 Front Cover Replacement, Remove the front cover screws: 步骤 19 中的图像 3,3
    • Use a Phillips screwdriver to remove the five 7.7 mm‑long screws securing the front cover to the headset:
    • One recessed in the top-left corner
    • One recessed in the top-right corner
    • Three along the lower edge
  20. Meta Quest 2 Front Cover Replacement, Release the front cover clips: 步骤 20 中的图像 1,2 Meta Quest 2 Front Cover Replacement, Release the front cover clips: 步骤 20 中的图像 2,2
    • The front cover is still held in place by clips along the bottom and side edges.
    • Insert an opening pick into the seam between the bottom edge of the front cover and the headset.
    • Pry with the opening pick to release the front cover clips.
  21. Meta Quest 2 Front Cover Replacement: 步骤 21 中的图像 1,3 Meta Quest 2 Front Cover Replacement: 步骤 21 中的图像 2,3 Meta Quest 2 Front Cover Replacement: 步骤 21 中的图像 3,3
    • Slide the opening clip along the seam and pry to release all the clips securing the front cover.
  22. Meta Quest 2 Front Cover Replacement, Remove the front cover: 步骤 22 中的图像 1,1
    • Remove the front cover.
结论
Arthur Shi
于01/03/18注册
315,095 声望
创作了729篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,855篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 43
过去 30 天: 239
总计 3,766
