跳转到主内容
加入维修社区 - 创建账户
MacBook Air 11" Mid 2012 Solid-State Drive Replacement
你所需要的
    1. MacBook Air 11" Mid 2012 Solid-State Drive Replacement, Lower Case: 步骤 1 中的图像 1,1
      在这个步骤中使用的工具:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      • Shut down and close your computer. Lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 8 mm 5-point Pentalobe screws
      • Eight 2.5 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
      添加评论
    2. MacBook Air 11" Mid 2012 Solid-State Drive Replacement: 步骤 2 中的图像 1,1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      添加评论
    1. MacBook Air 11" Mid 2012 Solid-State Drive Replacement, Battery: 步骤 3 中的图像 1,2 MacBook Air 11" Mid 2012 Solid-State Drive Replacement, Battery: 步骤 3 中的图像 2,2
      • In this step you will disconnect the battery to help avoid shorting out any components during service.
      • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
      • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
      添加评论
    1. MacBook Air 11" Mid 2012 Solid-State Drive Replacement, Solid-State Drive: 步骤 4 中的图像 1,1
      • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
      询问修复机器人
      添加评论
    2. MacBook Air 11" Mid 2012 Solid-State Drive Replacement: 步骤 5 中的图像 1,2 MacBook Air 11" Mid 2012 Solid-State Drive Replacement: 步骤 5 中的图像 2,2
      • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
      • Do not lift the end of the SSD excessively.
      • Pull the drive straight out of its socket and remove it from the logic board.
      • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
      添加评论
结论
取消:我没有完成这个指南。
52等其他人完成本指南。
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了63,709篇指南
4指南评论
Excellent instructions. Very easy to do. I used this screwdriver to remove the screws from the bottom of the case: https://www.amazon.com/gp/product/B00N1R...
and I used the Pentalobe-6 from this set to remove the screw holding in the OEM SSD:
https://www.amazon.com/gp/product/B01FE2...
After removing the stock drive, I installed a Samsung M.2 EVO 850 512Gb drive. It is working quite well. I used this adapter so that the M.2 drive fit in my 2012 Macbook Air:
https://www.amazon.com/gp/product/B01NH2...
feinberj - 回复 分享
How do we reinstall MacOS?
Philippe Morin - 回复 分享
I am 10 years old I fixed the mac I did this even the Geek squad couldn’t do it and now it works! without your guide.
admin free - 回复 分享
I have a MBA mid 2012 11” which no longer powers up. The battery has been in bad condition since a while and now the charging indicator remains amber no matter how long I charge it. So I assume it might be a battery issue. Unfortunately, I cannot find a supplier shipping batteries to Hawaii, but I found an identical machine on ebay (that will ship to Hawaii), except that it has 4GB RAM instead of 8GB. Provided my SSD is functional (which I assume) can I simply put my SSD into that 4GB RAM machine, and it will start up without any further modification?
Guido eMail - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 39
过去 30 天: 179
总计 88,115
