跳转到主内容
加入维修社区 - 创建账户
Logitech M125 Power Cord Replacement
你所需要的
  1. Logitech M125 Power Cord Replacement, Button Plate: 步骤 1 中的图像 1,3 Logitech M125 Power Cord Replacement, Button Plate: 步骤 1 中的图像 2,3 Logitech M125 Power Cord Replacement, Button Plate: 步骤 1 中的图像 3,3
    • Turn the device over and remove the two 0.5mm screws near the front of the mouse by using a Phillips #0 screwdriver.
    • The black screws used in the Logitech M125 frame are all the same size and do not need special consideration for keeping them separated. Silver colored screws are used on the circuit board and have broader heads.
    • Once the screws are removed, open the mouse from the front as it pivots at the rear.
    询问修复机器人
    添加评论
  2. Logitech M125 Power Cord Replacement: 步骤 2 中的图像 1,2 Logitech M125 Power Cord Replacement: 步骤 2 中的图像 2,2
    • Once the mouse is opened, remove the two black 0.5mm screws located towards the back of the mouse. These are the retention screws for the mouse button plate.
    • These screws will also require the Phillips #0 screwdriver.
    询问修复机器人
    添加评论
  3. Logitech M125 Power Cord Replacement: 步骤 3 中的图像 1,3 Logitech M125 Power Cord Replacement: 步骤 3 中的图像 2,3 Logitech M125 Power Cord Replacement: 步骤 3 中的图像 3,3
    • There are two tabs that further secure the mouse buttons to the frame. They are located on either side of the mouse cord retracting mechanism.
    • The tighter confines of the mouse interior will be easier to navigate with metal prying tools. While plastic tools are preferred for most plastic devices, they are too large to access the left tab in the picture.
    • To dislodge the tabs, use a prying tool while pressing down on the back of the mouse. When prying, push the tab towards the outside of the mouse.
    询问修复机器人
    添加评论
  4. Logitech M125 Power Cord Replacement: 步骤 4 中的图像 1,2 Logitech M125 Power Cord Replacement: 步骤 4 中的图像 2,2
    • To finish removing the button plate, continue lifting the rear of the plate until the tabs have fully left their slots.
    • Once the tabs are clear, push the plate towards the front of the mouse and lift.
    询问修复机器人
    添加评论
  5. Logitech M125 Power Cord Replacement: 步骤 5 中的图像 1,1
    • The mouse button plate has now been fully removed. In order to install the replacement, follow the instructions for this guide in reverse.
    询问修复机器人
    添加评论
  6. Logitech M125 Power Cord Replacement, Power Cord: 步骤 6 中的图像 1,2 Logitech M125 Power Cord Replacement, Power Cord: 步骤 6 中的图像 2,2
    • Using a Phillips #0 screwdriver, unscrew the three black 0.5mm screws from the frame to remove the power cord housing
    • Set mouse plate aside after unscrewing the cord housing from the plate
    询问修复机器人
    添加评论
  7. Logitech M125 Power Cord Replacement: 步骤 7 中的图像 1,3 Logitech M125 Power Cord Replacement: 步骤 7 中的图像 2,3 Logitech M125 Power Cord Replacement: 步骤 7 中的图像 3,3
    • Unscrew the silver 0.25mm screws to remove the circuit board from the mouse base with the same screwdriver.
    • Once unscrewed, remove the circuit board.
    • Circuit board needs to be lifted from the front before being pulled forward to remove it
    询问修复机器人
    添加评论
  8. Logitech M125 Power Cord Replacement: 步骤 8 中的图像 1,1
    • The cable is soldered into the board and will require a soldering iron to replace.
    • To continue further, please refer to the following guide on how to solder connectors: 如何焊接和拆焊.
    • Follow these steps in reverse to reassemble the mouse.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Bee Pines
于07/25/19注册
97 声望
撰写一个指南
团队
UW Tacoma, Team S1-G2, Liner Summer 2019 UW Tacoma, Team S1-G2, Liner Summer 2019 的会员
UWT-LINER-SU19S1G2
5 名成员
创作了9篇指南
1指南评论
That's a nice guide, thanks :)
Where do you get the replacement cable from?
dC7 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 23
总计 1,035
