跳转到主内容
加入维修社区 - 创建账户
Logitech G435 Battery Replacement
你所需要的
    1. Logitech G435 Battery Replacement, Prepare the headset for disassembly: 步骤 1 中的图像 1,1
      • Power off the headset and unplug all cables.
      询问修复机器人
      添加评论
    2. Logitech G435 Battery Replacement, Remove the ear pads: 步骤 2 中的图像 1,3 Logitech G435 Battery Replacement, Remove the ear pads: 步骤 2 中的图像 2,3 Logitech G435 Battery Replacement, Remove the ear pads: 步骤 2 中的图像 3,3
      • If you're replacing the headset battery, you only need to remove the left ear pad (the side containing the power button).
      • With one hand, firmly hold an ear cup steady.
      • With your free hand, slowly pull the ear pad away from the cup until it slides completely off its plastic lip.
      • Repeat the process to remove the other ear pad.
      询问修复机器人
      添加评论
    1. Logitech G435 Battery Replacement, Remove the screw sticker: 步骤 3 中的图像 1,2 Logitech G435 Battery Replacement, Remove the screw sticker: 步骤 3 中的图像 2,2
      • Use angled tweezers to peel up and remove the sticker covering the top-left speaker plate screw.
      询问修复机器人
      添加评论
    2. Logitech G435 Battery Replacement, Remove the speaker plate screws: 步骤 4 中的图像 1,1
      • Use a T5 Torx driver to remove the four 6.1 mm‑long screws securing the speaker plate.
      询问修复机器人
      添加评论
    3. Logitech G435 Battery Replacement, Secure the speaker plate: 步骤 5 中的图像 1,3 Logitech G435 Battery Replacement, Secure the speaker plate: 步骤 5 中的图像 2,3 Logitech G435 Battery Replacement, Secure the speaker plate: 步骤 5 中的图像 3,3
      • Don't try to fully remove the speaker plate—it's still attached by some wires.
      • Use your fingers to swing the speaker plate out of the housing.
      • Use some tape to secure the speaker plate to the headband. This keeps the speaker plate out of the way while preventing the speaker wire from being strained.
      询问修复机器人
      添加评论
    4. Logitech G435 Battery Replacement, Remove the circuit board screws: 步骤 6 中的图像 1,1
      • Use a Phillips screwdriver to remove the two 4.6 mm‑long screws securing the circuit board.
      询问修复机器人
      添加评论
    5. Logitech G435 Battery Replacement, Detach the circuit board: 步骤 7 中的图像 1,3 Logitech G435 Battery Replacement, Detach the circuit board: 步骤 7 中的图像 2,3 Logitech G435 Battery Replacement, Detach the circuit board: 步骤 7 中的图像 3,3
      • The circuit board is still connected by many wires. Be gentle as you move the board to prevent damaging any wires.
      • Use your fingers to lift the circuit board slightly out of its recess.
      • Flip the circuit board over so you can access the underside.
      询问修复机器人
      添加评论
    6. Logitech G435 Battery Replacement, Disconnect the battery: 步骤 8 中的图像 1,3 Logitech G435 Battery Replacement, Disconnect the battery: 步骤 8 中的图像 2,3 Logitech G435 Battery Replacement, Disconnect the battery: 步骤 8 中的图像 3,3
      • Use tweezers to firmly grip the edges of the battery connector.
      • Gently rock the connector side-to-side and slide it out of its socket.
      询问修复机器人
      添加评论
    7. Logitech G435 Battery Replacement, Remove the battery: 步骤 9 中的图像 1,3 Logitech G435 Battery Replacement, Remove the battery: 步骤 9 中的图像 2,3 Logitech G435 Battery Replacement, Remove the battery: 步骤 9 中的图像 3,3
      • The battery is lightly adhered to the ear cup.
      • Insert the flat end of a spudger underneath the battery.
      • Pry gently to release the battery from the ear cup.
      • Remove the battery.
      询问修复机器人
      添加评论
    8. Logitech G435 Battery Replacement, Transfer the battery pad: 步骤 10 中的图像 1,2 Logitech G435 Battery Replacement, Transfer the battery pad: 步骤 10 中的图像 2,2
      • Use your fingers to peel the foam pad from the battery.
      • Transfer the pad onto the same side of the replacement battery.
      询问修复机器人
      添加评论
    9. Logitech G435 Battery Replacement, Attach the battery: 步骤 11 中的图像 1,3 Logitech G435 Battery Replacement, Attach the battery: 步骤 11 中的图像 2,3 Logitech G435 Battery Replacement, Attach the battery: 步骤 11 中的图像 3,3
      在这个步骤中使用的工具:
      Tesa 61395 Tape
      $2.95
      • Cut and attach a small strip of double-sided tape onto the battery.
      • Use your finger to press the battery onto the ear cup such that the wires face towards the circuit board socket.
      询问修复机器人
      添加评论
    10. Logitech G435 Battery Replacement, Reconnect the battery: 步骤 12 中的图像 1,2 Logitech G435 Battery Replacement, Reconnect the battery: 步骤 12 中的图像 2,2
      • Use your fingers to slide the battery connector fully into its circuit board socket.
      询问修复机器人
      添加评论
    11. Logitech G435 Battery Replacement, Install the circuit board: 步骤 13 中的图像 1,2 Logitech G435 Battery Replacement, Install the circuit board: 步骤 13 中的图像 2,2
      • Use your fingers to gently flip the circuit board back over its recess.
      询问修复机器人
      添加评论
    12. Logitech G435 Battery Replacement: 步骤 14 中的图像 1,3 Logitech G435 Battery Replacement: 步骤 14 中的图像 2,3 Logitech G435 Battery Replacement: 步骤 14 中的图像 3,3
      • Align the circuit board notch on the right side of the USB-C port to the ridge on the ear cup.
      • Insert the circuit board at a downward angle and guide the USB-C port into its cutout.
      • Press the bottom edge of the board against the ear cup and tilt the board down.
      • This is a tight fit, as the board has to clear the screw post next to the port to be properly seated.
      询问修复机器人
      添加评论
    13. Logitech G435 Battery Replacement: 步骤 15 中的图像 1,1
      • Use a Phillips screwdriver to install the two 4.6 mm‑long screws to secure the circuit board.
      询问修复机器人
      添加评论
    14. Logitech G435 Battery Replacement, Install the speaker plate: 步骤 16 中的图像 1,2 Logitech G435 Battery Replacement, Install the speaker plate: 步骤 16 中的图像 2,2
      • Use your fingers to swing the speaker plate back into place.
      询问修复机器人
      添加评论
    15. Logitech G435 Battery Replacement: 步骤 17 中的图像 1,1
      • Use a T5 Torx driver to install the four 6.1 mm‑long screws to secure the speaker plate.
      询问修复机器人
      添加评论
    1. Logitech G435 Battery Replacement, Install the ear pad: 步骤 18 中的图像 1,3 Logitech G435 Battery Replacement, Install the ear pad: 步骤 18 中的图像 2,3 Logitech G435 Battery Replacement, Install the ear pad: 步骤 18 中的图像 3,3
      • Installing an ear pad onto the cup can be tricky. Be patient and work slowly—it may take a couple tries.
      • Orient the ear pad so the wider part is at the top.
      • With your free hand, place the pad over the top of the cup, so the black fabric flap slips over the cup's plastic lip.
      • The ear pad has a clear plastic stiffener. This piece should not slip over the ear cup lip.
      询问修复机器人
      添加评论
    2. Logitech G435 Battery Replacement: 步骤 19 中的图像 1,2 Logitech G435 Battery Replacement: 步骤 19 中的图像 2,2
      • Thread the rest of the flap over the lip, working your way around the entire cup. Gently stretch the pad as necessary.
      • Check the entire perimeter of the cup to make sure the ear pad is fully on. If any of the fabric flap is sticking out, try to push it over the lip or remove the ear pad and try again.
      询问修复机器人
      添加评论
结论
Congratulations on completing your repair!
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Arthur Shi
于01/03/18注册
345,213 声望
创作了915篇指南
2指南评论
Sehr gute Beschreibung - In 15min war alles fertig! TOP
BigRob - 回复 分享
Thank you very much. This was an easy repair thanks to your guide.
Thanks Logitech for doing the right thing as well.
Robert Basantsov - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 125
过去 30 天: 507
总计 3,485
