跳转到主内容
Linksys WRT54GS v2 Antenna Ports Replacement
Allian Roman
Allian Roman6 其他贡献者
最后更新于 January 31, 2023
没有估计
中等
You will be desoldering the antenna ports.
你所需要的
工具
查看更多...
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Linksys WRT54GS v2 Antenna Ports Replacement, Front Case: 步骤 1 中的图像 1,1
    • Turn the router over so that all four of its feet are facing upwards.
  2. Linksys WRT54GS v2 Antenna Ports Replacement: 步骤 2 中的图像 1,1
    • Remove the rubber inserts inside the the two purple feet located on the router's front case.
    • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
  3. Linksys WRT54GS v2 Antenna Ports Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
  4. Linksys WRT54GS v2 Antenna Ports Replacement: 步骤 4 中的图像 1,1
    • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
  5. Linksys WRT54GS v2 Antenna Ports Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Slide the board unit out and up.
  6. Linksys WRT54GS v2 Antenna Ports Replacement: 步骤 6 中的图像 1,1
    • Flip the circuit board over and use a Phillips #2 Screwdriver to remove the 6.9mm screw holding the board to the back case.
    • Slide the back cover out and away from the circuit board.
  7. Linksys WRT54GS v2 Antenna Ports Replacement, Antenna Ports: 步骤 7 中的图像 1,2 Linksys WRT54GS v2 Antenna Ports Replacement, Antenna Ports: 步骤 7 中的图像 2,2
    • Turn the circuit board over and identify which solder connection you will desolder.
    • The solder connections shown in red hold the right antenna port in place. There is one more attachment for this antenna on the other side of the board.
    • The solder connections shown in blue hold the left antenna port in place. Desolder these 4 points to remove the antenna port.
  8. Linksys WRT54GS v2 Antenna Ports Replacement: 步骤 8 中的图像 1,1
    • Turn on your soldering iron and allow it to get to its highest temperature setting (minimum 600ºF).
  9. Linksys WRT54GS v2 Antenna Ports Replacement: 步骤 9 中的图像 1,1
    • Desolder the connection by following iFixit's guide to repairing soldered connections: 如何焊接和拆焊.
结论
2等其他人完成本指南。
Allian Roman
于10/12/11注册
276 声望
创作了5篇指南
团队
Cal Poly, Team 3-4, Regan Fall 2011 Cal Poly, Team 3-4, Regan Fall 2011 的会员
CPSU-REGAN-F11S3G4
4 名成员
创作了12篇指南
一条评论
Most do not have removeable antennae ports
tom - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 3,286
