跳转到主内容
加入维修社区 - 创建账户
Linksys WAP54g LED Lights Replacement
你所需要的
    1. Linksys WAP54g LED Lights Replacement, Top Casing: 步骤 1 中的图像 1,1
      • Power down and unplug the device.
      询问修复机器人
      添加评论
    2. Linksys WAP54g LED Lights Replacement: 步骤 2 中的图像 1,1
      询问修复机器人
      添加评论
    3. Linksys WAP54g LED Lights Replacement: 步骤 3 中的图像 1,1
      • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
      询问修复机器人
      添加评论
    4. Linksys WAP54g LED Lights Replacement: 步骤 4 中的图像 1,1
      • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
      询问修复机器人
      添加评论
    5. Linksys WAP54g LED Lights Replacement: 步骤 5 中的图像 1,1
      • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
      • This may require a bit of force.
      询问修复机器人
      添加评论
    6. Linksys WAP54g LED Lights Replacement: 步骤 6 中的图像 1,1
      • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
      询问修复机器人
      添加评论
    7. Linksys WAP54g LED Lights Replacement: 步骤 7 中的图像 1,2 Linksys WAP54g LED Lights Replacement: 步骤 7 中的图像 2,2
      • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
      询问修复机器人
      添加评论
    8. Linksys WAP54g LED Lights Replacement: 步骤 8 中的图像 1,2 Linksys WAP54g LED Lights Replacement: 步骤 8 中的图像 2,2
      • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
      • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
      • Once the top panel is removed the main board will still be attached to the bottom panel.
      询问修复机器人
      添加评论
    1. Linksys WAP54g LED Lights Replacement, Bottom Casing/Motherboard: 步骤 9 中的图像 1,2 Linksys WAP54g LED Lights Replacement, Bottom Casing/Motherboard: 步骤 9 中的图像 2,2
      • Unscrew the two screws that connect the motherboard to the bottom casing.
      • The motherboard and bottom casing should be completely separated at this point. This allows for replacement of the motherboard and/ or its components as well as the bottom casing.
      询问修复机器人
      添加评论
    1. Linksys WAP54g LED Lights Replacement, LED Lights: 步骤 10 中的图像 1,1
      • Using a soldering iron, desolder the LED lights from the bottom of the logic board.
      • For help with soldering or desoldering refer to ifixit's soldering guide: 如何焊接和拆焊
      询问修复机器人
      添加评论
    2. Linksys WAP54g LED Lights Replacement: 步骤 11 中的图像 1,1
      • Place new LED lights through holes created by desoldering and removing old lights.
      询问修复机器人
      添加评论
    3. Linksys WAP54g LED Lights Replacement: 步骤 12 中的图像 1,2 Linksys WAP54g LED Lights Replacement: 步骤 12 中的图像 2,2
      • Solder the lights onto the bottom of the board to solidify the connection and make electrical contact.
      • Follow the Installing the Casing guide in reverse to re-assemble your device.
      询问修复机器人
      添加评论
结论
Once the soldering is complete, the device should work and the LED lights should light up.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Derek Myers
于10/04/11注册
288 声望
创作了5篇指南
团队
Cal Poly, Team 21-21, Maness Fall 2011 Cal Poly, Team 21-21, Maness Fall 2011 的会员
CPSU-MANESS-F11S21G21
5 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 23
总计 2,431
